Results 1 to 11 of 11
Thread: B5 S4 Hillclimb
01-11-2011, 12:52 PM #1
B5 S4 Hillclimb
Here is a cool B5 S4 hill-climb video. Stock internals, 376whp and 3170lbs. Using Motec engine management. He was supposed to run again in 2010 with some more upgrades and power, but I can't find anything else at the moment
Here you go:
01-11-2011, 02:56 PM #2
Not stock turbos, right?
01-11-2011, 03:40 PM #3
Hmm, not too sure, but those numbers look attainable on stock turbos. The Z32 300zx has stock turbos of nearly the same size, and is a V6 with only 300cc more displacement, DOHC, the S4 has a bit higher compression ratio but it's almost the same motor, and the stock turbo 300zx has hit the record of 520whp with water/meth injection, so 376whp though stock turbos on the S4 sounds resonable.
If they are after-market they must be fairly small because it spools very quick!
Later I will try to email the guy and see if he has any more recent videos and get more details.
01-11-2011, 04:12 PM #4
I think 370 whp probably means k04's.
01-11-2011, 04:39 PM #5
I thought they were two K04s stock? Are they K03s? I know the B5 A4 uses one K04, because the Jetta guys would upgrade to it, they came stock with K03s.
I personally would not take the time to upgrade from a K03 to a K04. There are many better choices, and you wouldn't gain that much.
01-11-2011, 04:41 PM #6BRAND NEW IN BOX 991.2 standard/non-pse SPW cat bypass pipe for sale - $899 shipped
01-21-2011, 02:08 PM #7Member
- Jun 2010
- 67
- 62.3
k03s come stock on the s4 and you can push them to 300whp on a set in good condition. k04s spool very quick as well. the only question i have is why does it sound like the car has bovs when audis use dvs, they could be splitter dvs like forge makes but on a performance car why would you use splitter valves?
01-21-2011, 02:16 PM #8Member
- Jun 2010
- 67
- 62.3
k04s used to be and still are a very big upgrade for the b5 s4. k04 cars usually put down anywhere from 400awhp to 440awhp, on meth maybe a little more.
01-21-2011, 02:44 PM #9CDT Technology
- Sep 2010
- CA and AZ
- 233
- 148.7
- 14 Post(s)
Cool vid! I always enjoy watching a good hill climb clip. Reminds me of the spectre 341 runs.
Mustang gt making about 440 to the wheels:
01-23-2011, 04:06 AM #10
01-23-2011, 06:46 AM #11Member
- Jun 2010
- 67
- 62.3
