Results 1 to 17 of 17
09-14-2018, 02:45 AM #1
DIY S55 Water/air intercooler retrofits for N54/N55
Ran across this guy who did this a while ago and another guy attempting it.
The obvious idea is to retrofit the S55 setup but easier said than done.
Originally Posted by jturboawd
And:
Originally Posted by Bantam
10-15-2018, 05:39 PM #2Member
- May 2011
- 1,000
- 715.7
- 16 Post(s)
10-16-2018, 09:35 PM #3
09-16-2021, 05:17 AM #4Member
- Sep 2021
- 1
- 12.1
It sticks up pretty high compared to the S55, is there any way to make it more flat?
09-16-2021, 01:23 PM #5
I think it is neat but I am not sure it is worth the hassle. A large IC + meth works just fine and is much less complicated with less points to fail.
10-17-2021, 09:40 PM #6Member
- May 2011
- 1,000
- 715.7
- 16 Post(s)
But there are no invisible flames with this set up. And you won't have to be explaining anything to your insurance company if something happens.
10-18-2021, 11:19 AM #7
The 1st post mentions/suggests using this A2W IC and meth together for best results.
Meth is very safe as long as you install it correctly. My points in my last post remain unchanged: less expensive, less complicated and more reliable, better results.
It's in Bantam's post he specifically says Drawbacks:
1) Weight
2) System Complexity
3) Cost
Lets add weight, cost, and complexity(and more failure points) to an n54.
Bantam goes on to say this is not really the best way from a $$$ perspective and the listed benefits are marginal over a FMIC. The fact you need to fabricate parts to make this work and it costs more than IC + meth? For 99% of people it does not make sense to go this route and again a large FMIC + meth is simpler, has significantly more gains all around, and is a fraction of the price requiring no fabrication.
To each their own.
10-18-2021, 07:52 PM #8Member
- Nov 2017
- 711
- 1,079.3
- 11
Not entirely true, if you perfectly install a garbage meth kit with a garbage controller and garbage hardware then it won't matter. If something goes wrong your engine is done.
If you use good quality hardware, and a good controller then you will be fine. Currently there is only 2 controllers on the market I would classify as good: Aquamist HSF4 and torqbyte cm5 lts. Maybe the motive reflex - but I don't know enough about it yet.
10-19-2021, 10:50 AM #9
100% Correct. I when I said 'install it correctly' I meant using only compression fittings, no push locks. Use a SS braided meth line and run it correctly not where it will get pinches or likely to contact anything warm. Use the right type of nozzles for your application i.e. checkballs in them if you need them. Install the meth bungs correctly and in the correct locations, calculate the about of nozzle you really need when factoring in your max boost, etc. etc.
I would add JB4 to your list. I can't imagine the reflex would have problems given how advanced it is and we are just sending a signal to a pump. Worst comes to worst the controller dumps meth when it shouldn't or does not inject when it should. When I said safe I was thinking mainly in response to the 'invisible flames' comment above. It might not be safe for your engine if your tune is relying on the meth for fuel and you run super lean because you have a $#@! controller! I have the HS4 and it is a great kit.
10-19-2021, 12:14 PM #10
Yeaaahh, this doesn't seem worth the time, effort and money at all to me
10-19-2021, 04:30 PM #11Member
- Nov 2017
- 711
- 1,079.3
- 11
Also run filters, just in case.
In terms of why I don't know if the reflex kit is good yet, is if it supports additional sensors such as a flow sensor. This is critical imo, because if you have a leak down steam the flow sensor will detect it and trigger a fail safe long before the engine knocks. Torqbyte is developing an IR flow sensor as well which will be even more accurate than the traditional wheel flow sensor, so I'm excited for that.
In terms of jb4, there really is no need on a properly flashed tuned car with a good meth controller. I used to run jb4 back in the day on my m235i, but imo flashing has gotten so good piggy backs don't add any value anymore.
11-06-2021, 08:42 PM #12
Water-to-air will not lower IAT’s any more than air-to-air unless you are running a reservoir that allows you to fill with ice. Otherwise, both systems are limited by the ambient temp. If you’re running enough water in the system, it will keep IAT’s from creeping up as quickly, however it also takes longer to recover after a pull. So as previously posted, this mod is not worth the effort (or extra weight). Looks like he did a really good job on this install, though!
12-20-2021, 04:03 PM #13Member
- Feb 2018
- 11
- 45.8
I did it on my 235 because I had to, you guys are making statements that you cannot prove or support with hard data. At the moment I'm only running 8 psi boost and my intake temps stay between 38 and 42 degrees C, I will be posting facts when I eventually get the boost up
12-20-2021, 05:14 PM #14Member
- Nov 2017
- 711
- 1,079.3
- 11
Not to be a douche bag, but those iat numbers are really really really bad for 8 psi of boost. My m2 on 16 psi of boost and a bms intercooler doing back to back pulls at 24C ambient gets to 45C tops, and these numbers are pretty average with a 5" step core intercooler with a large intercooler these numbers get even better. At steady state my IAT's do not get hotter than 38C and thats with a 30C ambient temperature.
What conditions are you getting these IAT's at? Steady state? Pulls? What is the ambient temperature?
12-21-2021, 10:31 PM #15
Thermal dynamics can in fact be proven. Water and air both absorb heat and both are merely a vehicle for transferring heat from the intake charge to the atmosphere. Although liquid absorbs heat better than air, you are still limited by how much heat the atmospheric air can absorb from your heat exchanger. AIR —> LIQUID —> AIR is the same result as AIR —> AIR when it comes to IAT’s. There are advantages and disadvantages to both.
12-22-2021, 07:03 PM #16Member
- Feb 2018
- 11
- 45.8
[QUOTE=F87Source;866521]Not to be a douche bag, but those iat numbers are really really really bad for 8 psi of boost. My m2 on 16 psi of boost and a bms intercooler doing back to back pulls at 24C ambient gets to 45C tops, and these numbers are pretty average with a 5" step core intercooler with a large intercooler these numbers get even better. At steady state my IAT's do not get hotter than 38C and thats with a 30C ambient temperature.
What conditions are you getting these IAT's at? Steady state? Pulls? What is the ambient temperature?[/QUOTE
I wouldn't call you names but you are clearly not objective or fair with your statement, I am very happy that you intercooler performs as well as you claim it does but I do not ever experience 24 deg. C days, I am located in the Caribbean and the average ambient temperature here is between 32 and 35 degrees C. The important factor in any type of intercooler system is the delta T. , anything under 20 degrees is excellent.
12-22-2021, 10:23 PM #17Member
- Nov 2017
- 711
- 1,079.3
- 11
[QUOTE=Dumaurier7;866628]That's why I asked what your ambient temps and if it was under steady state to be more fair... Initially I thought you had around 25C temps in that case it was really bad, even at 32C ambient a 10C delta is kind of high with only 8 psi of boost. This either means your pump speed isn't high enough or your hear exchanger is too small.
And it's under 20F delta which is considered to be excellent, not 20C, a 20C delta is horrible.
Also there's an f30 n55 owner with an air to air intercooler that was able to hit 5F delta at steady state, now that's impressive.
Let's point and laugh at Slaphappypal
