Results 1 to 25 of 25
08-10-2019, 06:53 PM #1
When a tuner pushes for a dyno 'record' - PTF BM3 tuned MKV 2020 Supra posts 485 rwhp B58 software only on E30
Dyno records can be misleading. The truth is that most people regard tune X as better than tune Y if tune X is making more power. Unfortunately, most people just look at peak figures. PTF (ProTuning Freaks) is running around claiming a Toyota Supra B58 tuning world record with the dyno pulls below.
Is PTF superior to every other tuner in the world? Of course not. Are they better than AMS Performance for example who got less peak horsepower out of their MKV Supra? Not a chance.
AMS took their car off the dyno and proved their tune in the real world on the dragstrip setting the Supra 1/4 mile record. That is very different from increasing timing on ethanol to eek out some more horses to claim a record for marketing purposes.
Tuners go about things in different ways. AMS Performance prefers to set records on the strip and this what real enthusiasts value. Real world, proven, performance.
PTF already had B58 motor failures pushing OTS tunes. Their OTS tunes showed more peak power than most competitors. So what though if the engine did not hold together?
Making power on a Dynojet which is not load bearing but inertia based is completely different from applying that power in the real world and more importantly having the motor last with the tune. Any tuner can hit this peak output with the B58 on the factory turbo like PTF did. There is no magic they found in the turbocharger. Maybe there is a reason literally all other tuners are not pushing to hit these figures?
Is this a game of playing with the safety margin with some ethanol for Dynojet glory numbers or a real world proven reliable and sustainable performance level? Frankly, it needs to be proven off the dyno.
08-10-2019, 08:35 PM #2Member
- Aug 2018
- 237
- 314.4
08-10-2019, 08:42 PM #3
08-10-2019, 09:07 PM #4
08-10-2019, 09:09 PM #5
08-11-2019, 11:04 AM #6Member
- Jun 2011
- Denver, CO
- 1,984
- 2,740.4
- 16 Post(s)
- 28
08-11-2019, 11:21 AM #7
I would love to see logs. That is the best indicator of whether or not the tune is safe (for current weather & altitude, anyway). Otherwise, it is all just speculation. As far as performance, I agree the track is king!
08-11-2019, 11:26 AM #8
Also, Sticky, did you just throw down a $5,000 challenge to PTF and AMS for the best E.T. & trap at a track meet-up?
08-11-2019, 12:08 PM #9Member
- 2,060
- 1,685.1
- 23 Post(s)
- 17
08-13-2019, 03:59 PM #10
Bitch please. Go look at every post @Sticky made propping up PTF until they stopped being a vendor here. All of a sudden he starts releasing article after article claiming PTF is trash.
@Sticky, like many have stated, its insavory to blame a tuning platform for the quality of tuners using it. PTF provides capabilities, you pick your tuner.
If other tuning companies want to charge a premium to curate their tuners, so have it, but i dont see it as a requirement. People that are lazy and dont know $#@! about cars can continue to throw their money at people like Cobb. I'll glady choose a platform that allows me to either tune myself, or choose who i want to tune the car.
Seems the problem is no one who can afford these platforms actually knows anything about tuning/the cars they are driving...
Dzenno rose from the ranks of this very forum. Hard to believe people cant see what a great platform he made and support him for it.2015 F10 M5 \ Alpinweiss
08-13-2019, 04:02 PM #11
Not true. I posted valid questions about their screening process after an engine blew. You act like I went and made the guy have his engine throw up its internals on the ground after he switches to what was a very early PTF OTS revision.
You want me to what, look the other way? Seriously?
IT WAS A PTF OTS TUNE.
I'm not saying it is a requirement but it is perfectly fair to point out some outfits are more professional than others in how they go about business.BRAND NEW IN BOX 991.2 standard/non-pse SPW cat bypass pipe for sale - $899 shipped
08-13-2019, 04:11 PM #12
Every tuner has blown a motor, either through their own fault or some other means. Alot of idiots out there not taking care of their vehicles that want to dump the blame on the tuner.
Alot of people running ethanol on non ethanol rated injectors, but no one wants to point that out. Alot of reasons a motor lets go; to blindly blame the tune is intellectually lazy.
Should i start writing blog posts about how $#@!ty your forum is since it doesnt have a proper mobile app?
I really think you're being overly criticla for no good reason.
If you decided to write an article pointing out the value of other tuning platforms that curated their tuners vs those who didnt, i could see that as beneficial to the community. You're just throwing stones while living in a glass house at this point. When i look around this place I see alot of dust on the shelves and cobwebs in the corners...2015 F10 M5 \ Alpinweiss
08-13-2019, 04:21 PM #13
Do I not always point this out?
That doesn't absolve bad tuning though.
It's like you robbing someone and saying, hey, it happens to everyone.
Ok but that isn't what the owner said happened.
This is what he said happened:
So this is how it started I was doing a pull down the road using my new bm3 stage 2 tune I have an
I started the pull at 50 mph and went to about 5500rpm before seeing a huge cloud of smoke out the back and what sounded like dropping a bunch of nuts and bolts on the floor
You seem to be going out of your way to defend engine failures, why? Shouldn't you be going out of your way to demand higher standard OTS tune testing?
How does that make for $#@!ty content? What mobile device are you browsing on that doesn't work? My Ipad and Iphone both load the forum just fine.
I am all for an app but I don't have a developer that can do it and it also costs money. Is it worth the investment? You tell me.
I disagree.
Here is what Mission Performance says regarding the B58:
Unfortunately, there is much more power left to be had Safely since turbo is a limiting factor. Fuel pressures are steady, but after 6k we are leaving turbo’s ability to flow.
Now, would you like to dispute their reasoning and if so ok let's have a discussion on where the B58 can be tuned to safely. Reducing safety margin for peak HP and hoping for the best is not a good tuning practice IMO.
Where are you looking? There are currently 1109 users online. 42 members and 1067 guests
Also, you're the one throwing stones and not stating what you would like to see beyond a mobile app.
Hey, when you build a forum that generates six figures, maybe then you actually can throw stones?BRAND NEW IN BOX 991.2 standard/non-pse SPW cat bypass pipe for sale - $899 shipped
08-16-2019, 03:02 AM #14Member
- Apr 2010
- 191
- 218.8
- 10 Post(s)
08-16-2019, 01:08 PM #15Guest Vendor
- Aug 2012
- Hayward, CA
- 9,218
- 3,666.1
- 349 Post(s)
Of course they did, this click bait post is abusurd, and outline Joe's ongoing beef with Dzenno. Not only did they run a 10's they have run mulitple 10 second passes and not only hold the dyno record, they hold the 1/4 mile record as well. These kinds of posts are why fewer, and fewer people hang out here...
08-16-2019, 09:24 PM #16
08-17-2019, 03:15 PM #17Member
- Apr 2010
- 191
- 218.8
- 10 Post(s)
08-17-2019, 07:58 PM #18
08-17-2019, 08:06 PM #19
08-17-2019, 08:34 PM #20
This is why you don't run your mouth.
This tune did not run 10's and was not run at the track.
The car that ran 10's had a cat delete, removed rear section, and nitrous: https://www.boostaddict.com/content....d-now-10-7-128BRAND NEW IN BOX 991.2 standard/non-pse SPW cat bypass pipe for sale - $899 shipped
08-18-2019, 03:49 AM #21Member
- Apr 2010
- 191
- 218.8
- 10 Post(s)
08-22-2019, 12:16 AM #22Member
- Jul 2013
- NJ | NYC
- 512
- 202.3
08-22-2019, 12:20 AM #23
08-22-2019, 12:27 AM #24Member
- Jul 2013
- NJ | NYC
- 512
- 202.3
08-22-2019, 12:30 AM #25
Hey daddyw00d:...
NOOOOB: daddyw00d
