Results 1 to 22 of 22
02-12-2019, 08:01 PM #1
Official - The 2020 F97 X3M and F98 X4M models - S58 motor 473 hp standard, 503 Competition models - Specifications list
Well, here they are. The new and quite strikingly good looking F97 X3M and F98 X4M models. The output will no doubt get the majority of attention as BMW went big with 473 horsepower in standard form and 503 horsepower for their Competition models.
The engine code is not stated which is interesting but it is an S58. BMW calls the engine an M TwinPower Turbo. That is fine. What the motor really shows is a preview of what we can expect for the G80 M3 much like how the S63 engine in the E70 X5M previewed the F10 M5's S63TU.
Let's go over the specs:
3.0L Twin Power Turbo inline 6 cylinder (S58) engine
473 HP / 442 LB-FT (Standard model)
503 HP (Competition model)
0-60 in 4.1 seconds (standard model)
0-60 in 4.0 seconds (Competition model)
155 MPH top speed (electronically limited)
174 MPH top speed (for standard model if optioned with M Driver's Package)
177 MPH top speed (for Competition model if optioned with M Driver's Package)
Production begins April 2019
Engine / Exhaust
473 HP (standard model) and 503 HP (Competition model) from 6250-7200 RPM
442 LB-FT torque from 2600-5600 RPM (standard model) and 2600-5950 RPM (Competition model)
Forged crankshaft
7200 RPM redline
Closed deck design
Wire-arc sprayed-on iron coating for cylinder walls
3D printing technology cuts weight of cylinder heads
Two mono-scroll turbochargers
350 bar maximum fuel injection pressure
Valvetronic and Double-VANOS variable camshaft timing
100 mm exhaust tailpipes
M Sport exhaust system standard for Competition models
Transmission / Cooling
8 Speed M Steptronic transmission with three shift modes
M xDrive intelligent all-wheel-drive system
Active M Differential (allows rear lockup between 0-100%)
Cooling
One large central radiator and two smaller radiators sides
Engine oil cooler and a separate transmission oil cooler
Lightweight oil sump has two separate chambers and an integrated suction channel
Chassis / Suspension
Strut brace in the engine compartment that links the shock towers
Carbon fiber strut brace will be available as an option beginning August 2019
A-strut in front section near the firewall, with two further struts increasing stiffness between the shock towers and the front of the car
Large rear brace and model- specific rear axle control arms
Double-joint spring strut front suspension and Five-link rear suspension feature model- specific bushings
Custom-made swivel bearings, torque arms and wishbones in front suspension
Increased front wheel camber
Model-specific components and custom bushings in rear suspension
Stiff camber arm
M-specific rubber mounts for all control arms and the rear suspension subframe
Model-specific anti-roll bars (larger bars on the Competition models)
Adaptive M Suspension controls damping forces for each wheel individually
Steering
M Servotronic system combines speed-sensitive power assistance and a variable ratio
Steering response can be varied by pushing a button to select one of three settings
Brakes / Wheels / Tires
Four- piston fixed front calipers and single-piston floating rear calipers at the rear
Drilled, inner-vented brake discs measure 395 millimeters (15.6 inches) in diameter at the front and 370 millimeters (14.6 inches) at the rear
Cast- iron brake discs with aluminum hubs
M light-alloy wheels in V-spoke design and mixed size high-performance tires (non-runflat)
20-inch wheels in polished Orbit Grey finish with 255/45 ZR20 tires at the front and 265/45 ZR20 tires at the rear (standard model)
21-inch wheels with a polished Jet Black finish with 255/40 ZR21 tires at the front and 265/40 ZR21 at the rear (Competition model)
Exterior / Colors
Seven exterior colors, including new Toronto Red metallic and M-exclusive Donington Grey metallic.
Competition Model
Standard equipment on the Competition models includes:
21-inch M light-alloy wheels in polished Black
M Sport exhaust system with tailpipes in Black Chrome
Specially designed door sill plates and model badging
M Carbon Exterior Package
Optional M Carbon exterior package (expected to be available from August 2019), will feature design elements in carbon fiber- reinforced plastic (CFRP) for the front air intakes, the air blades in the front apron, the rear diffuser and the exterior mirror caps
On the BMW X4 M and BMW X4 M Competition, these elements will be joined by a CFRP rear spoiler
Interior
Standard: heated sports seats in Vernasca leather with embossed M logo
Optional: M Sport seats in extended Merino leather (standard on Competition model)
Vernasca leather upholstery in a choice of Black or Oyster with an embossed M logo at the top of the backrests,
Interior trim strips in Aluminum carbon structure.
Competition X3M and X4M come standard with M Sport seats in extended Merino leather upholstery that can be specified in either Black or bi-color choices in Sakhir Orange/Black or Adelaide Grey (optionally available for standard models)
Optional extras include BMW Individual extended Merino leather upholstery in Ivory White and Tartufo (only in conjunction with the M Sport seats) and Carbon Fiber interior trim strips.
Extended Merino leather upholstery in the new Midrand Beige/Black color choice with Alcantara applications is available exclusively for the BMW X3 M Competition and BMW X4 M Competition models
Standard and Optional Equipment
Standard:
Adaptive Full LED lights
Harman Kardon surround sound audio system
SiriusXM Satellite radio with 1 year subscription
Navigation with Apple Car Play compatibility
Comfort Access keyless entry
Full array of advanced driver assist systems including Active Guard, Active Protection Active Driving Assistant and Frontal Collision Warning with City collision mitigation.
Optional packages include:
Driving Assistance Plus Package with Active Cruise Control with Stop & Go and Extended Collision Mitigation
Executive Package with heated steering wheel, heated front and rear seats, parking assistant plus, head-up display, wireless charging, WiFi hotspot and gesture control.
BMW likely has a winner on their hands here although it will not match the RS Q3 although that model is positioned against smaller BMW SUV's anyway. In this particular segment, all BMW has to fear is the GLC63 AMG which the X3M and X4M may put up quite a fight against.
02-12-2019, 08:58 PM #2
- Nov 2017
- 711
- 1,079.3
- 11
02-12-2019, 09:02 PM #3
02-12-2019, 11:03 PM #4
- Nov 2017
- 711
- 1,079.3
- 11
02-12-2019, 11:05 PM #5
02-12-2019, 11:16 PM #6
- 2,060
- 1,685.1
- 23 Post(s)
- 17
0-60 in 4 sec flat for the comp at 4,600lbs, the m3/m4 being 1000lbs lighter will be amazing!
02-12-2019, 11:29 PM #7
- Nov 2017
- 711
- 1,079.3
- 11
02-12-2019, 11:39 PM #8
02-12-2019, 11:53 PM #9
- Nov 2017
- 711
- 1,079.3
- 11
02-12-2019, 11:54 PM #10
02-12-2019, 11:59 PM #11
- Nov 2017
- 711
- 1,079.3
- 11
I don't think you have to worry for a few reasons:
1) I didn't know the next gen m3 would be an AWD, I heard the guys at M through a new post say they would continue supporting an M3 in a rwd manual format called the m3/m4 pure, hence why I thought that the next gen car would be RWD only. So you shouldn't need to worry too much about the xdrive hindering the handling if there is an alternate option.
2) They'll probably do it like the m5 to avoid the heat from the fans, where you can switch off and on the Xdrive at will to get the RWD experience if desired. If this is the case the only draw back is the weight and the fact it's going to be an auto (may or may not be a torque converter auto).
3) A benefit out of all of this is for guys that see a crap ton of snow, we finally can have a sporty ///M model to drive year round as a daily, instead of having to opt one level lower to get the 3 series to have X drive.
Either way I'm all for it, as long as they have an option to get RWD back and have a manual option for the hardcore as well. Otherwise they're killing off the M3 imo. I do wonder what is planned for the m2 as well.
02-13-2019, 12:08 AM #12
No. Hence the AWD/RWD versions.
Yes, the pure M3 will be detuned though which is lame instead of making it a hardcore and lightweight M3 like they could.
I get it but the M3 isn't supposed to be a car that gets you through the winter. It's a track car.
You haven't been reading enough BimmerBoost or BoostAddict: https://www.boostaddict.com/content....-AWD-automatic
02-13-2019, 12:19 AM #13
- Nov 2017
- 711
- 1,079.3
- 11
Actually not true, just because they make a separate rwd version doesn't mean they won't enable the RWD function in an AWD car. The reason is because it is much simpler to make the manual version RWD only so they don't have to mess with a different version of the manual (new gear box is probably needed which is more development money on a gear box not many opt for) to send power to the front. Same reason why the m5 doesn't have a dct because it's cheaper to reuse the torque converter autos from the X5m. So essentially it's easier to just drop the Xdrive for a manual to save on engineering cost, but it doesn't mean the auto can't switch to RWD.
Most likely they won't go all out crazy even if the next gen car is RWD only, because they still have to appeal to the masses who want a soft version of the car... They'll save the hardcore varients for limited production like the m4 gts.
In terms of winter usage, most people aren't fortunate enough to live in a warm climate all year round and can only chose to have one car. So they may need to drive their track car all year round as a sacrifice. So it will be a good balance.
I just use bimmerboost for the forum only, not really into reading the news articles as there are other sites I frequent more to deliver news as it's more conveniently linked to my phones google now news feed, and I only really pay attention to the M2 stuff.
02-13-2019, 03:37 AM #14
- May 2011
- 1,000
- 715.7
- 16 Post(s)
02-13-2019, 09:23 AM #15
- Dec 2013
- 77
- 64.4
I was waiting for the X3M comp, but I just pulled the trigger and got Rebel Ram 19" so probably will replace my 335i F30 with G80 M3 looks promising, the interior in this X3M is amazing.
side note: stated is 7200rpm, but power figures state peak horsepower until 7300 weird.
02-13-2019, 11:45 AM #16
- Oct 2010
- 1,574
- 1,903.2
- 22 Post(s)
- 20
Interior/dash looks like 2016 M4 except for the vent hood. Exterior looks nice tho. Hope they didn't stretch that back area in the X3M as the space looks decent.
02-13-2019, 07:12 PM #17
It is true. It's why they are producing separate models.
M=Motorsport. M does not equal Winter. Buy an Audi.
Take a look and see if maybe you're missing things you're into: www.boostaddict.com
02-13-2019, 07:12 PM #18
02-13-2019, 07:58 PM #19
- Nov 2017
- 711
- 1,079.3
- 11
02-13-2019, 07:59 PM #20
02-13-2019, 10:08 PM #21
- Nov 2017
- 711
- 1,079.3
- 11
02-14-2019, 01:29 AM #22
- Sep 2015
- 55
- 190.6
- 4 Post(s)
This could make for a difficult choice in the future. I have been waiting for the x3m for a long time but a couple weeks ago I drove the glc63 and it sounds amazing. Handling and power were on point and a tune gives them a healthy bump in power. It will be a good competition.
