Results 1 to 10 of 10
    MHD N54 E85 flex fuel tuning finally reaches beta release
    This has been in development forever seemingly with it being 'officially released' back in March of this year except that was not exactly the case. The reason? The software to go with it was not ready despite some software people at Motiv making unsubstantiated claims and even now it is being called a beta release by MHD.
    Nobody said this stuff was easy and MHD deserves credit for sticking with it and making it work on the software side.
    What you need to get started:
    Click here to enlarge Originally Posted by MHD
    We are proud to announce the next level in N54 tuning.It is a fully implemented flex fuel solution, running on the stock DME! The benefits here are never having to reflash when changing ethanol blends again (or even worry about mixing the correct blend), and take advantage of the extra power allowed by e85. Go from straight pump gas to a E85 mix on your desired map (stage 1 to 2+).
    Some overall highlights and features of this accomplishment:
    - first DME integration with a 3rd party sensor
    - first large scale rewrite and modification of DME logic
    - direct logging of Ethanol Content % in MHD
    - seamless blending between maps* for any ethanol content
    - support for v8 ots maps and custom tunes.
    High and low pressure fuel pump limitations are still present, so we recommend an upgraded low pressure fuel pump and use e50 max (2 third of e85 on third pump gas) .
    Now its time for a public beta release!
    Requirements:
    - Flexfuel kit: https://www.motivmotorsport.com/…/motiv-motorsport-mhd-tuni…
    - MHD Flexfuel software module ($99)
    - either FF custom tune, or a MHD OTS pump gas maps pack + the ethanol mix pack.
    If you want to participate then join the beta channel and update the app:
    https://play.google.com/apps/testing...hd.flasher.n54
    If you have any questions feel free to ask @martial@mhd and keep in mind this is still in a beta phase
    May 2016
    'Straya
    Need this for F80!
    Jul 2017
    30 Post(s)
    So far to date I have a handful of cars completed tuning and a ST 335is coming soon with MHD/Motiv FF setup. Everything turned out fantastic. The FF setup performed as promise.
    Mar 2015
    22 Post(s)
    How does the flex fuel box connect to the DME?
    I assume we have to buy a special MHD "map"?
    Dec 2016
    15 Post(s)
    You add /replace some wires on the dme, and connect the box to a continental ethanol sensor.
    If you get a custom tune it's not beta. Not sure if the ots maps are fully available yet.
    It works great and makes filling up so much nicer not having to figure out the mix.
    I don't have pi, so the highest ethanol I can run before the hpfp isn't happy is e40. Above that target load/boost stats lowering to keep the hpfp happy. Beautiful system.
    May 2014
    16 Post(s)
    I've had this setup since the closed beta started earlier this year. Tuning done myself, MMP stage 3's with PI and the flex fuel setup works perfectly. Love being able to just toss in 93 for long road trips then add a few gallons of e and power gets turned up automatically without having to do any cal changes. Dialing in the AIC map takes a little bit, but overall the system was super easy to install and tune
    Jun 2014
    Nj
    10 Post(s)
    Just ordered all my parts I was accepted as a tester so ill be up in the mix soon.
    May 2014
    39 Post(s)
    Click here to enlarge Originally Posted by noorj Click here to enlarge
    How have your MMP stage 3 turbos been treating you? I have been following some threads and social media. Good to see some people still doing well. The first releases with the welds were kind of scary and made me stay away. Glad it’s worked out so far. I hope to see people with MMP 1ks chime up a bit.
    May 2014
    16 Post(s)
    Click here to enlarge Originally Posted by ///MPOSTER Click here to enlarge
    Pretty great, I'll agree that the welded turbine housing isn't the most professional or pretty approach but it works. I've talked to guys with 30k+ miles on them without issues. Mine have done about 15k, with the last 8k miles being >600whp. Yeah I'll be interested to see results from them, honestly I don't see them putting down 850 or even 800whp I think closer to 750whp will be realistic
    Jul 2015
    Southern PA
    4 Post(s)
    Are any of the guys running these on a built motor? I imagine you would bend a rod before you get to 800 on a stock motor
