Results 101 to 122 of 122
11-17-2017, 06:42 AM #101Member
- Mar 2014
- 812
- 1,205.0
- 37 Post(s)
- 13
Yeah I'm pretty close. I know the group they're in. Have tested some that turned out to be not right. I haven't got back to looking at that yet. Once I get the TCU tune fairly well sorted and after I get automatic upshifts in M stopped, I'll have another go at slowing torque re-introduction.
11-17-2017, 10:22 AM #102Guest Vendor
- 2,495
- 1,970.5
- 204 Post(s)
You think all those features happen with a magic XDF? Lol.
Chris has them because he is my go-to tester / guinea pig, and has been since day 1. Jake H has them as they we tested at a 1/2 mile race. Don't worry, they will certainly be released for all to enjoy! And you're missing a few from your list
x1000.
11-17-2017, 11:22 AM #103Member
- Mar 2014
- 166
- 306.0
11-20-2017, 06:58 AM #104Member
- Mar 2014
- 812
- 1,205.0
- 37 Post(s)
- 13
I double-checked the VAG and E60 OLS files and those addresses absolutely must be the ones for that name BUT I found another table for each upshift titled "factor for return ramp at torque increase" and the factor at any torque above 80nm is 0! Fingers crossed that increasing that factor make the ramp time a factor of the previously found tables and using them in conjunction with each other could allow us to shape our timing increase rate.
11-20-2017, 03:13 PM #105Member
- Mar 2014
- 166
- 306.0
Brad, I was looking at that table recently and saw the 80nm you're referring to. If you try it, lmk how it goes. Ideally a slow ramp rate back to the timing from the Timing (main) for that load/rpm would be perfect.
11-20-2017, 04:20 PM #106Member
- Mar 2014
- 812
- 1,205.0
- 37 Post(s)
- 13
I'm hoping that another potential contributor to post-shift knock isn't a big contributor to it and that's super heated exhaust valves and cylinder temps in general from the negative timing during a shift. Fingers crossed. I'll be able to test the ramp factor tables about 9 hours from now.
11-21-2017, 02:25 AM #107Member
- Mar 2014
- 812
- 1,205.0
- 37 Post(s)
- 13
I'm shattered. I left my tablet with xhp on it at work! I'm not going back there now.
If anyone is willing to test more torque ramp tables, please let me know.
11-21-2017, 03:03 AM #108Member
- Feb 2017
- 293
- 483.1
11-21-2017, 03:10 AM #109Member
- Mar 2014
- 812
- 1,205.0
- 37 Post(s)
- 13
11-21-2017, 01:39 PM #110
11-21-2017, 02:54 PM #111Member
- Mar 2014
- 166
- 306.0
11-22-2017, 04:40 AM #112Member
- Mar 2014
- 812
- 1,205.0
- 37 Post(s)
- 13
Well I changed the values in the recently discovered tables and no noticeable change AGAIN.
So the folder of tables is titled "Schaltablauf Motoreingriff 1 -> 2" (and 2 -> 3 etc.) which translates to "Switching sequence engine intervention 1 -> 2". Every table to do with "Motoreingriff" definitely is to do with requesting torque reduction from the engine.
I changed the following tables:
Dauer Rampe ME bei Schaltungsende
Duration Ramp ME (engine intervention) at the end of the circuit
From 90ms to 180ms
AND
Faktor fuer Ruecknamerampe bei Momentenerhoehung
Factor for return ramp at torque increase
From 0% at all torque levels above 80nm to 100% at all torque levels above 80nm
It's like the above tables are just a starting point but the transmission still ramps up torque as hard as possible if it doesn't detect slip.
We might need to limit the torque increase rate after a shift on the DME side after all. It might come with its own side effects because on the DME side is just a single cell item that applies to all revs and loads.
11-22-2017, 06:09 AM #113Member
- Feb 2017
- 293
- 483.1
Are there any other tables that would mean that these ones aren’t accessed for your test ? For example temp?
11-22-2017, 07:04 AM #114Member
- Mar 2014
- 812
- 1,205.0
- 37 Post(s)
- 13
11-22-2017, 02:13 PM #115
11-22-2017, 03:12 PM #116Member
- Mar 2014
- 812
- 1,205.0
- 37 Post(s)
- 13
11-23-2017, 04:20 AM #117Member
- Feb 2014
- 432
- 408.0
- 58 Post(s)
03-29-2018, 08:28 AM #118Member
- Mar 2018
- 1
- 2.0
has anyone looked at any VAG original files? im just wondering if anyone has as im struggling to find anyway to tune the trans in my RS6, frustrating as we do probably 3-4 a week in fords with HPtuners and SCT. You guys have done a great job with the BMW stuff.
if anyone remotely interested here is the ori file.
facebook.com/groups/737420992943719/1972499522769187/
Cheers Trent
04-10-2018, 04:13 PM #119
@bradsm87 so did we ever get anywhere with this?
04-10-2018, 04:40 PM #120Member
- Mar 2014
- 812
- 1,205.0
- 37 Post(s)
- 13
Not anything of use to tuning. Several more tables found and tested in the hope to stop automatic upshift but none worked. Same for limiting rate of torque increase post-shift but in practice, these tables have no effect. Likely disabled via switches elsewhere in the rom. Again so very dissappointing that the TCU remap project started as an open community project then it went commercial, the ones with the key skills needed to further it got silenced and the devs do not take important feature requests that affect literally every N54 user seriously.
I'll post a link to a full map list with automatic translations shortly and ppl are free to go through it and identify any tables of interest and I can try and define them but I haven't seen anything else of great interest to tuning that actually works over what we already have.
04-10-2018, 04:49 PM #121
04-10-2018, 07:50 PM #122Member
- Mar 2014
- 812
- 1,205.0
- 37 Post(s)
- 13
I did buy another car but not for that reason. F11 LCI 535i N55 with 8AT transmission. Heaps of space for the kids and all the new gimmicks etc. It's a lot slower than the turbo upgraded N54 335i that's for sure!
The commercialisation thing is what it is. What bugs me is there have been threads about post-shift knock since the first announcement of XHP and they're still being started to this day but they have no intention to use their resources and have a proper go at it. Too busy making quick tunes for more car models to make more money.
The E60 6HP is probably the most similar to ours. Here is a map list with automatic language translations. If anybody notices a table that looks of use to you and you're willing to test it, let me know and I'll have a go at defining it.
https://docs.google.com/spreadsheets...it?usp=sharing
