Results 26 to 30 of 30
08-16-2016, 05:04 PM #26
- Jun 2016
- 217
- 391.2
A quick update, I checked the Lambdasonde menu in my German version INPA, the bank 1 appears completely dead whereas bank 2 fluctuates with the engine. I then went to reset adaptations and got a script error. I then put INPA in sleep mode, chose DME reset and nothing happened, the connection was idle not green as with other modes when connecting. I believe the INPA isn't to blame because all else works. I have an MSD81 rather than MSD80 if that makes any difference, I noticed most of the INPA refers to MSD80. I have v5.06 of INPA.
Still to check the DME connectors then I guess I may just live with running in open-loop if that doesn't sort it.
08-16-2016, 06:13 PM #27
08-17-2016, 03:09 AM #28
- Jun 2016
- 217
- 391.2
08-17-2016, 04:48 AM #29
Tell me you've since flashed a different map.
I would first flash a stock file. Drive the car a bit and see if any issues pop up. That will remove that variable. That is STEP ONE
Do not give up and drive the car OL.
Step by step.2010 N54 - DocRace - Motiv - CKI - TCKR - Volk - ER - CSF - Vorsteiner
Daily - '11 F02, 22" HR springs+links
N54
11-13-2016, 06:58 PM #30
- Jun 2016
- 217
- 391.2
HI - further update, I flashed back to stock, still had lambda (o2) sensor faults, and I've now got through THREE oxygen sensors finally finding one that works for my wideband on bank 1.
http://datazap.me/u/threetirtyfive/l...&data=16-17-23
What a mission to fix this problem. I guess it's safer to now have close loop AFR monitoring.
I have another question- my other wideband o2 sensor (the one that was working) on bank 2 spikes at over 200 - is this normal?
It's not dead as it otherwise follows engine behaviour. Fairly sure i've seen one of you guys with the same thing in another car's log. (end of this log from someone else shows same extreme readings http://datazap.me/u/rsicks/pull?log=0&data=4-18-19-24)
Is that when it's flooded with fuel for example, dodgy connection or something else?335I xxxwhp, Chinesium FCBO. AliExpress 19t turbos. JE forged pistons, FCP engineering forged rods, king sv bearings, Vargas spline lock crank hub built block. 2x DO12 charge pipe 6x port meth injection. Stock charge pipe.
Quote
