Results 1 to 22 of 22
Thread: JB4 issues
    Apr 2013
    Flexing in the mirror
    26 Post(s)
    JB4 issues
    I have no luck with JB4
    Single turbo, MHD backend flash, map 1
    AFR's are fine on start up then start jumping around eventually pegging 20, shudder, misfires, stalls
    Any ideas? I've swapped the 02s in to different banks but same issues. Currently running grey 02 in bank 2
    http://datazap.me/u/rgasmar/log-1460...g=0&data=18-24
    Daily - '11 F02, 22" HR springs+links Click here to enlarge N54
    See if you still have o2 sensor fault codes stored... Without fully functional o2 sensors nothing is going to work.
    Apr 2013
    26 Post(s)
    2a2b Fuel mixture control only code showing
    Apr 2013
    26 Post(s)
    Map 0, same thing.
    Ran code checker on MHD
    Definitely something bizarre still with the o2 sensors. The JB4 tuning is disabled on map0 and map1 with single turbos. Don't see how it could be having any effect on the sensor outputs but you could put the small black subconnector only back to stock, which is where the o2 sensor signals ride, just to be 100% sure its not related.
    This is with brand new primary o2 sensors? Did you disconnect 19&20 on small black to disable rear sensor signals?
    Apr 2013
    26 Post(s)
    I removed 19 and 20. Started it up and AFR's are perfect and match. About 15 - 20 seconds after bank 1 goes haywire again.
    2016-04-13_19_43_35[1].csv
    http://datazap.me/u/rgasmar/log-1460...data=1-4-18-24
    No codes on JB4 read out now
    Sep 2015
    Down Under
    32 Post(s)
    Sounds like what happened to me, did you get a backfire at all
    cracked intake manifold or a bad vacuum leak on the manifold
    it will send your afrs haywire
    check cylinder one on the manifold along the plastic welds especially
    Click here to enlarge Originally Posted by R.G. Click here to enlarge
    If you have more time than money then maybe swap the sensors from bank1 to bank2 to see if issue moves with the sensor? If more money than time just replace both sensors.
    Apr 2013
    26 Post(s)
    Click here to enlarge Originally Posted by martymil Click here to enlarge
    Checked it, all looks clear.
    I've already ordered 02s but am wanting to confirm if that is the issue while the car is down.
    I'll swap the 02s and see if it follows and have removed the JB4 completely
    Apr 2013
    26 Post(s)
    Swapped 02s and issue stayed with bank 1
    Nothing is ever that simple with this car.
    Apr 2013
    26 Post(s)
    Sep 2015
    Down Under
    32 Post(s)
    you swapped the sensors but did you swap the connections otherwise the readings will stay the same.
    But I'm not sure if you can switch the connections
    Terry chime in here.
    We swapped out a faulty front sensor on a mates car as it was going ballistic
    after that all good.
    Apr 2013
    26 Post(s)
    So swap the connections near the fuel rail also?
    Feb 2012
    Boston, Ma
    32 Post(s)
    If you have access to a smoke tester, I would smoke test the intake manifold. Could be a leak in the gasket between the head and manifold. When swapping o2's if you are testing to see if the sensor is bad, swap the sensor and wires to see if the issue is isolated to that specific sensor.
    2010 AW/BLK 135i VM 6465 Single Turbo w/ OCDworks Modified T51r Housing, JB4 + MHD, VRSF CP & Tial, Big Tom, Fuel-It PI + Stage 3 + Return + Ethanol Sensor, BMW PE, MFactory LSD, Spec 3+ & MFactory SMFW, RB External PCV, ADV sensors, and many more....
    RIP Click here to enlarge2008 AW/BL 135i
    Apr 2013
    26 Post(s)
    Would rep you guys again if I could.
    Didn't even cross my mind to swap wires too. The issue followed the sensor after I swapped the wires. New sensor should be here tomorrow and hopefully resolves issue.
    http://datazap.me/u/rgasmar/log-1460...0&data=4-17-21
    Feb 2012
    Boston, Ma
    32 Post(s)
    Nice! Hopefully that was it then which is a relatively simple fix. Keep us updated.
    Feb 2016
    6 Post(s)
    Sub'd. Curious to know what I'm in for when the car gets over to the shop for install with my kit.
    '08 Barbera Red 335Xi 6AT: DOCRace ST 6266, VRSF 7" FMIC, VRSF CP + Synapse Bov, MHD tuned by Wedge Performance, Fuel-it! Stage 2, BMS Cowl, Turner MS Boost Gauge, xHP TCU Flash, Earl's Oil Cooler, AD-E Engine Mounts, H&R Xi Coilovers, Stoptech Stage 2 Brakes, Renn Motorsport RS-51 19" Satin Grey Wheels (Staggered 235/265).
    Fastest Standing Mile and Half Mile 335Xi in Colorado: 168.2 MPH Verified @ The Colorado Mile/147.4 MPH Verified @ Shift-S3ctor
    Apr 2013
    26 Post(s)
    Just a faulty 02. Swapped bank 1 sensor and all back to normal. Back to tuning now.
    Definitely buy Chris's ADV sensors. His sensors are better in so many aspects. Worth the investment
    Feb 2016
    6 Post(s)
    Probably will later in June. Just focusing on getting the car up and running right now. Trying to figure out how I'm gonna setup the JB4 so it doesn't mess with anything the shop is doing with their Cobb livetuning. My head hurts from all the reading I've done today. lol
    Unrelated: The kit doesn't come with a MAC Solenoid right?
    Nov 2014
    7 Post(s)
    I repped them all for you, except for Terry - I couldn't rep him again. I think I got him yesterday in another thread.
    Pretty impressed with the way they gang-tackled the issue and didn't let go until it was solved.
    Well done, gentlemen.
    Happy to help although still confused why the thread is labeled "JB4 problems" instead of "o2 sensor code problems". Click here to enlarge
    Apr 2013
    26 Post(s)
    The only variable that changed from running well to not was JB4 settings. Turned out to be a component failure.
    @Alpine Correct, Mac doesn't come with the kit
