Page 18 of 21 FirstFirst ... 81617181920 ... LastLast
Results 426 to 450 of 520
  1. #426
    Oct 2014
    27 Post(s)
    Click here to enlarge Originally Posted by 7plagues Click here to enlarge
    https://www.facebook.com/photo.php?f...e=3&permPage=1
    some images of the kit hosted up with fitment.
    Just looked at those...some stuff looks good, but I'm betting cars running that kit burn up water pumps or go into limp mode faster due to lack of coolant flow. You can't downsize the feed to the block like that without reducing the flow. Also looks like solid mounts are a must to maintain any clearance from the frame rail, unless the engine torques the other way...haven't even looked at my car in a good while.
  2. #427
    Aug 2012
    Hayward, CA
    349 Post(s)
    Click here to enlarge Originally Posted by The Convert Click here to enlarge
    I was thinking the same, but then I realized the fitting you are seeing is most likely for the turbo. My guess is the other side of that block is a 1-1.25" opening like stock for the water pipe, its just not on there yet. If that is a -8 feed, its going to do more than burn up water pumps, its going to overheat the motor, that is not enough flow.
  3. #428
    Oct 2014
    27 Post(s)
    Click here to enlarge Originally Posted by Tony@VargasTurboTech Click here to enlarge
    Looking again and closer, it does look like he has room on the forward side to put the pipe. I thought the wastegate actuator was in the way at first. Gonna be tight.
  4. #429
    Apr 2014
    8 Post(s)
    Click here to enlarge Originally Posted by The Ghost Click here to enlarge
    I dunno. I found the 6466G2 to spool about as fast as my 20T twins (20psi at 3300rpms on the street), 300ft lbs at 2700 rpms on a non-loaded dyno, with only 7 degrees advance. The 6466 is a lot bigger than the M750 turbo as well. It'd be cool to overlay the charts (I'm at 26psi).
    did you notice much difference with iat's b/w the 6466 & 2+ at the same boost level? or too many variables to be objective?
  5. #430
    Jan 2015
    6 Post(s)
    3 out of 3 members liked this post. Yes Reputation No
    Water outlet is 1 inch folks. The small fitting at the back is for the turbo. The car will be running very soon so you find out whether I know what I am doing. FWIW I'm perfectly confident.
  6. #431
    Aug 2012
    Hayward, CA
    349 Post(s)
    0 out of 1 members liked this post. Yes Reputation No
    Click here to enlarge Originally Posted by steedspeed Click here to enlarge
    This is exactly what I thought on the water. Leen, no one is doubting you know what you are doing, but you will not get stock spool out of a 9180, or 9174. Just not going to happen, I do not care how good the manifold is.
  7. #432
    Sep 2011
    27 Post(s)
    Click here to enlarge Originally Posted by rac Click here to enlarge
    I will have to look through my logs to compare. Twins max-out in the upper 20s psi, so you'd expect higher IAT near any turbo's flow limit.
    '10 335i - 830whp (Bruce Lee)
  8. #433
    Aug 2012
    Hayward, CA
    349 Post(s)
    I am running ours consistently over 30 psi for testing, and seeing very low IAT's. But I am using that ridiculously large AD FMIC which is huge. I am sure that is helping keep the IAT's down
  9. #434
    Dec 2014
    Any updates/ results? Waiting to see results before I make a decision on what set up to purchase.
  10. #435
    Click here to enlarge Originally Posted by rileyg Click here to enlarge
    I'll see what he has to say.
    People are still recovering from the holidays. I wouldn't expect things to get back into the normal swing until next week.
  11. #436
    Jun 2014
    Nj
    10 Post(s)
    Already ordered my kit but id still like to see results
  12. #437
    Oct 2015
    Raleigh, NC
    Got any more info on the intercooler you are referring to? I couldn't find it on their site.
  13. #438
    Aug 2012
    Hayward, CA
    349 Post(s)
    Just search this forum there is a whole thread on it
  14. #439
    Dec 2014
    13 Post(s)
    I told him to post on here, but he said "Nah! I'm already on there enough"
    Click here to enlarge Originally Posted by Fishayyy Click here to enlarge
    I think it's more of a question of advertising at this point.
    He is getting plenty of free advertising and some vendors have complained about that and they are right.
    @steedspeed
  16. #441
    Aug 2012
    Hayward, CA
    349 Post(s)
    I don't understand why the Steed Speed update was just posted in CP-e's twin kit thread?
  17. #442
    Dec 2014
    13 Post(s)
    Ohhh I forgot it was CES kit that he was using his manifold on. That was my bad.
  18. #443
    No big deal, posts moved.
  19. #444
    Apr 2014
    8 Post(s)
    if they haven't fired it up yet, it might be some time before a result worth advertising. although i like his confidence and hope it all works out. anyone know who is tuning it for them? neither John or Leen would be spending their days discovering the finer points of n54 tuning at the 800rwhp level. as we all know there are so many hurdles to overcome to get those power levels and then possible gremlins to iron out during testing. i sent John an email a few weeks back asking about a realistic schedule and didn't hear anything. i'm sure he gets a lot of questions like that.
  20. #445
    Apr 2014
    8 Post(s)
    actually he said 800 "hp" not "rwhp". on a dynojet that might be more like 700rwhp?
    or in north america you guys just assume you are also talking about "rwhp"?
  21. #446
    Aug 2014
    Orlando
    4 Post(s)
    It's a 79lb/min turbo so it should be good for about 750-790ish whp with that iwg setup
    Left hand on the steering wheel right hand on that RTD Shifter
    -2Chainz
    07 6spd TI ag E92
    Mods
    Boostbox, e85, RTD shifter, and a 6766
    #BuiltByHaborFreight
    Instagram Oss_Cah5
  22. #447
    Jan 2015
    6 Post(s)
    Neither John or myself are touching the tuning. We have a very well known and respected tuner lined up for the task so as soon as we have the hard parts made we shall let him work his magic on the tune. Before getting into that I'd like John to at least take it for a rip to get some idea of how it is spooling though. At least then I'll be able to see how the manifold and turbo are working.
  23. #448
    Who?
  24. #449
    Aug 2014
    Orlando
    4 Post(s)
    Who?
    Don't tell sticky let it be a surprise LOL
    -2Chainz
    07 6spd TI ag E92
    Mods
    Instagram Oss_Cah5
  25. #450
    Click here to enlarge Originally Posted by Abacus38 Click here to enlarge
    I'm about to surprise you with a ban.
