Results 1 to 25 of 25
10-08-2015, 07:45 PM #1
760 rwhp and 816 lb-ft for F10 M5 S63TU with the Pure Turbos Stage 1 turbo upgrade with JB4 + flash combo tuning
Just as in the BMW N54 world we are starting to see more piggyback and flash combinations on the S63TU platform. This F10 M5 is benefiting from such a tuning setup and it shows in its very strong 760 rear wheel horsepower and 816 lb-ft of torque at the wheels dyno pull.
Here are the mods on the car:
Flash + JB4 S2/BCM
AMS downpipes
RPI Exhaust
MSR Intakes
BMS Meth
Upgraded Clutch packs
Pure S1 Turbo upgrade
Now we would like to know who is doing the flash tuning. Additionally, there are still some issues to work out regarding misfires up top so the tuning is not yet perfect. Tuning for upgraded turbos is going to evolve over time but this is already a very good sign for the S63TU.
It is also important to note the meth injection here as the S63TU fuel system needs the methanol support at these levels and owners would be wise to use it until direct injection fuel system upgrades are available and commonplace on the platform.
Spectacular numbers regardless that should get even stronger over time. More details from the owner below:
Headed back to the dyno today down at EAS and strapped her on to try a few more things. Had Terry helping me online, so we were able to try several things out.
Had some misfires at the higher boost levels (28-29psi) which could be attribued to spark plugs (so need to figure that out). Anyways, car keeps making reasonable power.
A consistent map yields 740-750whp and 790-800 ft-lbs torque. A more aggressive map gets a solid 760whp and 820+ ft-lbs torque, but not very nice things happen after 5.5K... hence need to ramp boost down after 5.5K. Will try another set of plugs and will try an even more aggressive gap this time.
I will post the plot later, but the torque curve is NUTS its at 790-800 ft-lbs torque from 2.7K to nearly 5K. HP peaks in the 4K to 6.5K range. If we can fix the misfire up-top, I think it can start approaching 800whp and sustain top-end power longer in the RPM curve.
The turbos have been swapped to Pure S1 turbos. Their design (stock turbines) seem very capable of holding 30+psi to redline... just that the car doesn't really like it for some reason, so need to problem-solve.
10-08-2015, 07:57 PM #2
- Aug 2012
- Hayward, CA
- 9,218
- 3,666.1
- 349 Post(s)
What we knew it was capable of all along. Lets hope the S63 isn't the next N55 when it comes to these tuning issues. Nice work all around
10-08-2015, 08:30 PM #3
Pretty sure this is running the MSR Flash Tune, same one the previous WR S63 was running (Frozen Cashmere Individual M5 here on the East Coast). More interested to see if Xona Rotor releases something for the S63, since they've already upgraded the S55 turbos.
10-09-2015, 12:46 AM #4
I believe it is ESS flash tune.
10-09-2015, 11:36 AM #5
- May 2015
- Atascadero
- 403
- 609.1
- 41 Post(s)
10-10-2015, 07:20 AM #6
10-10-2015, 09:47 AM #7
10-13-2015, 11:55 AM #8
- Jun 2011
- Denmark, Copenhagen
- 608
- 592.3
- 40 Post(s)
This is allmotors M5, it has pure stage 1 turbos, ams dp, exhaust (not sure of brand), jb4 + flash and meth.
I helped him and another guy with their misfires, hopefully they are all gone now
10-13-2015, 04:38 PM #9
10-13-2015, 04:39 PM #10
- Jun 2011
- 608
- 592.3
- 40 Post(s)
10-13-2015, 04:44 PM #11
10-13-2015, 06:32 PM #12
- Jun 2011
- 608
- 592.3
- 40 Post(s)
By adjusting boost to not go above boost target. This is the "secret" that every tuner has spent countless hours to discover, it took me a couple of logs to realize that lol... For instance, simon motor sport wants 5500€ for a TUNE!!!
Allmotor and another guy had a flash + JB4, so we quickly fixed it by the JB4.
10-13-2015, 07:11 PM #13
10-13-2015, 07:12 PM #14
- Jun 2011
- 608
- 592.3
- 40 Post(s)
10-13-2015, 07:14 PM #15
10-13-2015, 07:14 PM #16
- Jun 2011
- 608
- 592.3
- 40 Post(s)
10-13-2015, 07:19 PM #17
10-13-2015, 07:22 PM #18
- Jun 2011
- 608
- 592.3
- 40 Post(s)
This is the guy!
You can run flash only to whatever boost you like, I personally use the JB4 (nice tool) as a logging tool as Jerry said. He said tuners were tuning in blind, he was right. It is much easier to see what is going on, this engine is very tough to tune on, the N54 for instance is seriously nothing compared to this.
10-13-2015, 07:23 PM #19
10-13-2015, 07:24 PM #20
- Jun 2011
- 608
- 592.3
- 40 Post(s)
10-13-2015, 07:27 PM #21
- Jun 2011
- 608
- 592.3
- 40 Post(s)
10-13-2015, 07:30 PM #22
10-13-2015, 07:31 PM #23
- Jun 2011
- 608
- 592.3
- 40 Post(s)
10-13-2015, 07:39 PM #24
10-13-2015, 07:41 PM #25
- Jun 2011
- 608
- 592.3
- 40 Post(s)
