Page 2 of 2 FirstFirst 12
Results 26 to 45 of 45
    Oct 2011
    Houston
    37 Post(s)
    I wish could rep you... Just have to donate instead.
  2. #27
    Aug 2013
    Sweet, I've only dreamed of disassembly!
  3. #28
    AZ
    43 Post(s)
    Click here to enlarge Originally Posted by Tony@VargasTurboTech Click here to enlarge
    Well well well. This is timed rather perfectly...Click here to enlarge
    So what is it timed well with?
  4. #29
    Click here to enlarge Originally Posted by shushikiary Click here to enlarge
    I can only hope that this may also be a foot in the door to dealing with the 23 or so PSI limit in the DME so we can use the N20 straight with the DME rather than using a JB4. If that's the case you're going to make me piss my pants in excitement.
    JB4 still has a lot more to offer. Click here to enlarge But if you really want to run flash only, we recently designed a cool device for Wedge that he intends to market as a flash only 3.5bar TMAP sensor alternative. It plugs directly in to the 3.5bar and then rescales the signal in such a way that MHD has programmed the flash side to convert to actual boost in logs. No need to enter DME box it plugs right in to the N20 sensor. Direct any inquires to Wedge. Click here to enlarge
  5. #30
    Sep 2013
    SC
    4 Post(s)
    The JB+ has been given a new life, lol.
    E92 335is DCT
  6. #31
    Jul 2014
    10 Post(s)
    This is so great
    N54 - FBO - MFactory LSD - 60% Corn Gas... 100% love
  7. #32
    Nov 2012
    18 Post(s)
    Great work! This is been a great year for n54 development for sure!
  8. #33
    Click here to enlarge Originally Posted by musc Click here to enlarge
    lol yes uses same chassis as a JB+. Only with an N20 TMAP connector on one end, and special firmware that alters the input according to a function that Martial provided to integrate with special MHD logic. It's a nifty and easy to use device. Not sure what retail price will I expect it will be very reasonable.
    I still think you guys are crazy not to use the JB4 in at least some capacity though. For example on the boost by gear, you can change them in seconds without flashing the DME, and during a run you just press volume down to "bypass" the limit. I use it all the time when using the 3rd gear limiter. Once the car gets traction I press the button to kill the limiter. Click here to enlarge
    On the flash developments, very nice work! There is so much potential now to improve things now that we have DAMOS file access and people willing to dig in to it. The knock tables alone are a god-send. The more stuff gets unlocked the better both stand alone flash and JB4 back end flash maps can perform.
  9. #34
    Nov 2012
    204 Post(s)
    Click here to enlarge Originally Posted by mastawyrm Click here to enlarge
    Since I have an IJE0S 335is I'm very curious how much needs to be changed just to get rid of that timer. Since I already have the overboost function enabled, is there still more than a simple value change to lose it?
    It ended up being a LOT more involved than a timer table, Josh@Cobb wasn't lying Click here to enlarge
    Great work Jake! Is this the same Overboost table just renamed or did you find a whole new table? I assume it's the overboost table with control of the timer? This is a huge development. If you need a INA0S_IS tester just let know.
    Yep, it is physically the same table, just has been renamed as it now serves a new purpose.
    Click here to enlarge Originally Posted by 7plagues Click here to enlarge
    Awesome work J! Quick questions, do the values in the load by gear table have to be the same all the way down the column? Or can it have different boost values at different RPMs for one gear?
    You do not need to have the same load all the way down, you can increase it as RPM's rise, for example Click here to enlarge
    Click here to enlarge Originally Posted by cloud9blue Click here to enlarge
    Sweet. What's next? Forced emission readiness? I would seriously donate a $#@! tons if you guys can pull that off!
    shhhh, we can't talk about this bc California lol. There may be something there though...
    There will be an announcement regarding this in a day or two, so keep watch. Don't want to get off topic in this thread though.
  10. #35
    Jan 2015
    Plantation, FL
    4 Post(s)
    Jake, to use this would we need to have the logic in your custom bin in addition to the new tables? That is have to start with your bin or is there a way to transfer the logic to our own bins?
  11. #36
    Nov 2012
    204 Post(s)
    Click here to enlarge Originally Posted by Cpt_Rum-bo Click here to enlarge
    Still working out these details. The easiest will probably be a flash-time checkbox, so all you will have to do it set up the Load Target and Load Target Adder by Gear tables in your bin how you want them, then check the option at flash time, and everything else will be done for you.
  12. #37
    Jan 2015
    Plantation, FL
    4 Post(s)
    Click here to enlarge Originally Posted by jyamona Click here to enlarge
    Sounds good, looking forward to it.
  13. #38
    Jul 2014
    10 Post(s)
    Has this load by gear logic been tested on 6AT?
  14. #39
    Nov 2012
    204 Post(s)
    Click here to enlarge Originally Posted by spxxx Click here to enlarge
    No not yet, just my car.
  15. #40
    Jul 2014
    10 Post(s)
    @Terry@BMS - the new XDF logic will now allow not only Load by gear but also by RPM (for each gear) which I asked for a long time ago. Are you willing to reconsider implementing the feature now? Click here to enlarge
  16. #41
    If you guys all have awesome results with it I'll reconsider. But for now I still see it the same way I saw it years ago when I tested it both ways, as unnecessary complication.
    To test these boost by gear tables out with the JB4 in place you'll just have to set your JB4 by gear boost limits lower than the lowest limit on the flash side and enable mode 4/3 so the JB4 takes the higher of its target and the flash target. Or I can just add in a FUD to allow it to work on 4/2.
  17. #42
    Aug 2012
    Hayward, CA
    349 Post(s)
    Click here to enlarge Originally Posted by klipseracer Click here to enlarge
    Trying to take the car to track, and not have 30 psi in 1st and 2nd gear with flash only
  18. #43
    Jul 2014
    10 Post(s)
    offtopic: Are inlets back in stock?
  19. #44
    Oct 2013
    16 Post(s)
    amazing how the progression continues on this platform.....and here i thought there would never be a fix for the dreaded post shift flatline.
  20. #45
    Dec 2013
    20 Post(s)
    Amazing work!
    2010 135i, 6MT, VRSF 7"FMIC/VRSF DP's/VRSF Charge Pipe/Stock DVs/Helix Style Hybrid intake/ JB4 E40
