Results 1 to 6 of 6
Thread: Please help! ECU is bricked =[
11-12-2014, 01:57 AM #1Member
- Nov 2014
- 57.3
I got a full read of my original ECU but that took 7 hours! I went ahead and tried the flash and got all the way to step 2 and 1 second left. I downloaded the files directly from N54 tuning and received a 0x05 bad file code. Then tried to write my stock ecu back but again the same code.
Plugged in charger with 40 amp automatic charger. Volts read 14 constantly.
BT Cable Intel and AMD used.
Followed the directions.
Im thinking i will now need winkfp and a kdan cable to resort back? Any way i could do this without getting a kdan cable and only using the bt cable? Please help. I cant be stranded with no car for long. Thank you guys!
11-12-2014, 02:06 AM #2
11-12-2014, 08:27 AM #3
Contact @WedgePerformance or @Cn555ic for help if you need it.
You'll need the DCAN cable for WINKFP.
http://www.germanboost.com/showthrea...510#post562510
Gave you enough rep to do this.Last edited by DavidV; 11-12-2014 at 08:36 AM.
11-12-2014, 05:50 PM #4Guest Vendor
- Feb 2013
- Germany
- 185
- 536.1
- 69 Post(s)
Zip and PM me your ECU read bin file so I can check it - 7 hours doesn't sound quite right.
11-12-2014, 11:10 PM #5Member
- Dec 2012
- Florida
- 1,613
- 3,270.5
- 125 Post(s)
- 33
If it took 7 hours you shouldn't have continued, it should only take around 90 minutes. I'm guessing you have a 2007 and used a bad computer. My advice is go find another amd computer (some are finicky) or friend with a very new Intel with the haswell core. You'll likely be able to fix it np.
11-13-2014, 10:41 AM #6Member
- Jan 2013
- Mexico
- 281
- 359.6
- 13 Post(s)
