Results 1 to 14 of 14
09-19-2014, 02:33 PM #1Guest Vendor
- Jun 2011
- Denmark, Copenhagen
- 608
- 592.3
- 40 Post(s)
File Request for WinKFP - Software number 7609274
09-19-2014, 04:49 PM #2
I'll check for it when I get home. Just so it isn't a complete wild goose chase, what module is that ZB number for?
09-19-2014, 11:48 PM #3Member
- Jul 2013
- 18
- 48.4
09-20-2014, 01:51 PM #4Guest Vendor
- Jun 2011
- 608
- 592.3
- 40 Post(s)
09-20-2014, 05:51 PM #5Member
- Feb 2012
- Kuwait
- 45
- 67.5
09-20-2014, 08:06 PM #6Guest Vendor
- Jun 2011
- 608
- 592.3
- 40 Post(s)
I know you can choose just to update it (removes tune etc), when I look at the UIF, it shows 2 assembly numbers. The one I'm looking for now and the new I have installed. Is there any way to remove the second one? Because when I hit F3 it just goes back to what I already got, not the one I want!
09-21-2014, 12:02 PM #7Member
- Feb 2012
- Kuwait
- 45
- 67.5
I'm no expert bro, just to clarify when you choose comfort mode (F1), then Enter ZUSB (F1) type 7609274 does it give your error (704 Error on determining the ZB number!) in this case that mean its old version (7609274) and not available in current SP Daten file you are using now. maybe if you got older version of SP Daten files maybe it will work out. had the same thing when I flash my ECU it shows number does not exist in my list however the new number does exist.
if the file exist then i guess you can follow same steps used for alpina flash.
again im no expert just trying to help outLast edited by Oilphase; 09-21-2014 at 12:08 PM. Reason: re-writing
09-28-2014, 08:49 PM #8
09-30-2014, 07:00 AM #9Guest Vendor
- Jun 2011
- 608
- 592.3
- 40 Post(s)
09-30-2014, 07:33 AM #10Guest Vendor
- Jun 2011
- 608
- 592.3
- 40 Post(s)
10-01-2014, 04:53 PM #11Guest Vendor
- Jun 2011
- 608
- 592.3
- 40 Post(s)
10-01-2014, 07:40 PM #12Member
- Feb 2012
- Kuwait
- 45
- 67.5
Couldn't find v38.1 but found v38.0 maybe it will be useful, check link below click on the version you want then click on turbobit,
http://allautoinfo.org/diagnostic/73...stap-2400.html
10-02-2014, 06:19 AM #13Guest Vendor
- Jun 2011
- 608
- 592.3
- 40 Post(s)
10-02-2014, 08:52 AM #14Member
- Feb 2012
- Kuwait
- 45
- 67.5
