Results 1 to 24 of 24
07-19-2012, 10:44 PM #1Member
- Sep 2011
- SF
- 59
- 212.4
VAC Differential Cover: My Review
Pros:
- Cools the LSD gear fluid much better than stock
- Adds port to monitor differential temperature
- Adds drain/fill plug for easy fluid change
- Shiny
Cons:
- $800
- Can be low to the ground (no issues surprisingly even in horrible Philly roads)
This is merely my opinion. Link to VAC's thread for more information:
http://bimmerboost.com/showthread.ph...erential-Cover
Why bother with this?
This is one of those items that seem like a true enthusiast product for the "hardcore track junkie."
I thought the same until I discovered that I might be in serious need of such a product.
Many of you have LSD's in your OEM diff unit with BMW's "lifetime" gear oil.
Unfortunately, I recently discovered that this gear oil doesn't last anywhere near the "lifetime" of the vehicle, especially when coupled with a Quaife LSD and a few (15+ ) very hot track days.
My old unit had begun to spurt gear oil after track events.
After track events I would go under my car and find the pumpkin to be covered with gear oil. I would then clean it off and begin to worry. At first I thought it was the seals so we replaced those. Then after replacing the seals, the diff was still getting fluids all over itself after track events.
After some researching, I suspected it was because the diff oil was boiling and coming out of the top vent. After opening my diff up and seeing that the gear oil had gone to an extremely nasty shade of black, it was confirmed that I had cooked my gear oil and cooked it pretty bad.
Old Differential Cover: no Cooling options, fins, or drain plug
Which begs the question...
If I, an intermediate level driver at best, is cooking diff fluid in the New Jersey weather, how the hell is your diff fluid holding up if you live in a warmer climate, producing more power (all tuned n54...), or have more experience tracking?????
New Differential Cover
Driving Impressions:
This was the most surprising part. My Quaife unit felt like it was slightly more progressive, almost smoother with the new fluid and not boiling the fluid at the track. I hadn't expected a change at all but it was noticeable today at the track in 100+ degree weather when compared to just two weeks ago. This could also be attributed to the fact that my previous fluid had been boiled multiple times and was probably in horrible condition. Nevertheless, it's looking like this new differential cover will prevent that from occurring again.
On the street I've had zero clearance issues. I don't baby this car around the mean streets of Philly and South Jersey. Our potholes and bumps are legendary. I've seen a Ford F150 get stuck in a huge pothole in West Philly before. So far my lowered 335i has confirmed the VAC note that the race length (long finned) differential on a lowered vehicle generally has no clearance issues. Obviously if you ran through a curb that would take off your front bumper and various other underbody parts, you would probably scratch this differential cover. Best part is that even if you do hit it, it's made out of one piece forged billet aluminum so it's strong as hell.
Because Racecar
07-20-2012, 09:45 AM #2Member
- Sep 2011
- SF
- 59
- 212.4
A properly oiled LSD with proper cooling means you go faster and kill your tires more to the point where street tires give out suddenly. XD
07-24-2012, 01:46 AM #3
Nicely done review, thank you.
The track guys (we have a few) should definitely look into this and really everyone else as well. The fluid capacity gain alone is a major selling point.BRAND NEW IN BOX 991.2 standard/non-pse SPW cat bypass pipe for sale - $899 shipped
07-24-2012, 02:07 AM #4
07-24-2012, 03:55 AM #5
Great. Nice to hear from somebody who actually uses the car enough to notice the difference.
I do have a question for you.
How difficult is it to install?
What did you have to disassemble to install this?
I am considdering this as an upgrade.There are two theories to arguing with women. Neither one works
07-24-2012, 11:46 AM #6Member
- Sep 2011
- SF
- 59
- 212.4
1. Installation isn't too difficult. It involves lowering the differential in order to remove the OEM cover. It can be done on stands but it would be infinitely easier on a lift. Expect 1-2 hours of work total on a lift because some of the screws are a little tough to reach.
2. My exhaust was being annoying so we had to unbolt section 3 and push them out of the way. Otherwise that's it. Unbolting and lowering the differential was the main thing.
07-25-2012, 10:51 PM #7
07-26-2012, 11:08 PM #8Member
- May 2011
- NYC
- 75
- 189.5
07-27-2012, 04:35 AM #9
The differential cover is all nice and dandy but I'm surprised no one has asked the obvious: why not just switch to a higher temp oil such as Motul Gear Competition 75w140? That is what Wavetrac recommended me for serious track use. It may have been adequate to solve your overheating woes without putting a dent in your wallet.
[02/07 E92 335i 6MT] - Under Construction
07-27-2012, 04:53 AM #10
08-02-2012, 02:22 PM #11Guest Vendor
- Jan 2012
- Denver, CO
- 139
- 126.3
08-02-2012, 02:33 PM #12Some dude
- Jan 2012
- Northern VA
- 111
- 202.4
- 13 Post(s)
Indeed. The fluid volume of the E9x diff is REALLY SMALL, and even a moderate HP 335i will cook diff oil in a hurry. Even Motul Gear Competition fluid was black (starts blue) after every event in our GA 328i, and that car had 100HP less than any tuned 335i.
James Muskopf
RRT Racing
2007 E92 335i/6MT Procede Rev3 w/PWM meth, otherwise stock
E28 M5, R171 SLK320
07-04-2014, 12:30 AM #13Member
- Sep 2011
- SF
- 59
- 212.4
07-04-2014, 08:36 AM #14
07-04-2014, 09:52 AM #15
07-04-2014, 12:24 PM #16
07-07-2014, 12:04 AM #17Member
- Jul 2012
- 7.7
I had the rogue engineering mount on my Z and my butthole would pucker as if come to a dip or bump our pothole in the road.
Got rid of it after my first cruise. Mine was cast not billet. The one looks real nice.
07-07-2014, 10:34 AM #18Member
- Jan 2013
- Mexico
- 281
- 359.6
- 13 Post(s)
too bad you can't use this cover with the defiv lockdown kit
07-07-2014, 10:58 AM #19Member
- May 2013
- 2,950
- 992.0
- 58 Post(s)
- 10
X2 this is the deal breaker for me. Great looking product, but I would like to see it improved for use with the defivfab lockdown kit and better clearance. Maybe defiv would be interested in making one? @rick@defiv
2013 Audi S6 stock but shopping....
2014 RAM 2500 6.7 Cummins. Far from stock
07-07-2014, 11:02 AM #20
Why not just tap the factory cover and run an exterior cooler? Should be less than the price of the VAC kit and you can still use the lockdown kit...or am I missing something?
07-07-2014, 11:11 AM #21Member
- Jan 2013
- Mexico
- 281
- 359.6
- 13 Post(s)
07-07-2014, 12:58 PM #22
07-07-2014, 01:24 PM #23
07-07-2014, 08:15 PM #24Member
- May 2013
- 2,950
- 992.0
- 58 Post(s)
- 10
Yeah, you're right, a cooler would work well, but where would you put the cooler? And unless I'm mistaken there's no pump on the diff to move the fluid, so you'd need that too, so current draw, a pump, and then the cooler. Sounds like a PITA to be honest, but I may be wrong, I'm open to suggestions, maybe I'll even do it.
Let's point and laugh at Slaphappypal
