Results 1 to 19 of 19
Thread: Boost seems way to high. Help!
02-22-2014, 03:34 PM #1
- Feb 2014
- 16
- 49.3
Help!
Running Cobb Stage 1 Drive map. Drop in high flow air filter is the only other mod. Otherwise stock.
3rd gear 2500 RPM to redline and 4th gear 2500 RPM to nearly redline. It was 69 degrees out and I am running about 95 oct at the moment. Typically would be 91 oct Arizona. I have attached the datalogs and graphs from virtual dyno software. It feels fairly slow to be honest but, I have higher boost levels than expected still. What can we make of this? I really do not want to destroy the engine. There were no negative timing corrections however so that looks good.
Something to keep in mind. This car has new turbos and waste gates factory replaced. It has a new thermostat ( not sure that matters ), all new coils and all new spark plugs. It previously had a JB+ on it but was removed and car started and stop cycled prior to flashing with Cobb AP V3.
02-22-2014, 04:16 PM #2
Any chance you could load your logs to Datazap.me? These are pretty tough to read without labels on the axes.
02-22-2014, 05:12 PM #3
- Feb 2014
- 16
- 49.3
02-22-2014, 05:24 PM #4
- www.bootmod3.com
- 6,711
- 3,356.0
- 233 Post(s)
Your boost there on the graph says 13.x psi. Stage 1 OTS targets that range, nothing abnormal at first glance. Datazap is a great tool definitely use it next time.
02-22-2014, 06:30 PM #5
- Feb 2014
- 16
- 49.3
Datazap - Cobb St 1 Drive is the first screenshot and Cobb St 1 Aggressive is the second. Do these look with in range of normal?
02-22-2014, 06:34 PM #6
- www.bootmod3.com
- 6,711
- 3,356.0
- 233 Post(s)
02-22-2014, 09:09 PM #7
- Feb 2014
- 16
- 49.3
http://www.datazap.me/u/rtaylor/stag...5i-n54-1?log=0 is the OTC Drive
http://www.datazap.me/u/rtaylor/stag...5i-n54-1?log=1 is the OTC Agressive
02-22-2014, 09:21 PM #8
Aside from some mild overboosting and HOT chargebair temps it looks good to me. Boost isn't excessively high it's just a little over target, if that makes sense.
MOTIV750, MOTIV P-1000 PI, MOTIV/FUEL-IT! low pressure fuel system, AEM EMS/COBB AP, Aquamist HFS-3, ETS FMIC, SPEC stage 3+ clutch/SS flywheel, BC Racing coilovers and VMR wheels wrapped in Hankook RS3s.
02-22-2014, 09:56 PM #9
- Feb 2014
- 16
- 49.3
02-22-2014, 10:13 PM #10
- Jan 2014
- 36
- 127.6
02-22-2014, 10:53 PM #11
02-22-2014, 10:55 PM #12
02-23-2014, 02:29 PM #13
- Jan 2014
- 36
- 127.6
Still seems low. At 5700rpm he's only at 111F and it dips down to 1.9. Peaks temps at the end of the run are 131F which is very hot but 3.4 at 6800rpm seems low to me even at those temps.
02-23-2014, 09:08 PM #14
- Feb 2014
- 16
- 49.3
Would you all recommend FMIC upgrade, Intake, and Pro tune in this order or should I consider a pro tune first and add the others later?
02-23-2014, 09:14 PM #15
02-23-2014, 09:16 PM #16
- Jan 2014
- 36
- 127.6
If you get the Protune first you'll need to get Protuned again after you get the hardware.
02-23-2014, 09:29 PM #17
- Apr 2011
- Jersey City
- 3,850
- 3,654.6
- 75 Post(s)
- 37
Yup, parts first then protune. The protune wakes the cobb tune up tremendously, almost like the OTS cobb tune does over stock. Try not to run the base ots cobb tune for too long, bc you're missing out!
ESS 6XX kit
02-24-2014, 05:45 AM #18
02-24-2014, 10:47 PM #19
- Feb 2014
- 16
- 49.3
Can't really afford a FMIC at the moment but, will soon lol. I may pay for a protune from PTF this week and go from there with re tune after the bolt on parts. I should still see gains I assume prior to the FMIC?
