Results 1 to 25 of 70
01-18-2014, 04:27 AM #1
- Jan 2014
- 119
- 197.1
Hello all! new member to the forum and i got some big plans that i would like to share and ask you about:>
hey all, I'm new to this forum and i own a 2007 y/m 335D E91, European model.
I´ve made an ESS Tuning stage 2 with DPFoff and a nastymean ecu that gives me 386hp and
780nm. :> But i want more! I'm aiming for around/close to 600hp, but will it hold and work?
My english isn't the best but hope u guys get it:>
On my to buy list:
Siemens Deka motoron 875cc injectors
Bigger mechanical fuel pump, build by dieselmeken.se
600x450x76mm IC (already bought)
Bigger turbo(s?) Im looking on a Garrett GT35(?!) for the bigger but what for the smaller?
Reinforce the tranny
Im also in the making of a 3,5'' stainless steel exhaust system
But will the engine hold or what els do i have to change?
Pistons?
Crank?
Drivetrain?
Turbine?
camshaft?
And so on, Fill me up with information and share what you guys think, what to do and ill show u all a nasty diesel!
Thanks in advance and i finally feel that i found an awesome forum that i can call home! cheers from Sweden!
01-18-2014, 07:10 AM #2
- Jan 2014
- 119
- 197.1
I found out that i will need a new stronger more powerful squirt, I'm gonna give LGspeed here in sweden a call on monday and ask about the myra squirt, that would fit perfect for my car, also i found a Garrett T67 racing turbo for decent money that i will buy
01-18-2014, 11:13 AM #3
- Jan 2014
- 119
- 197.1
01-18-2014, 06:06 PM #4
- Jan 2014
- 119
- 197.1
After some research and some phone calls i now know how to make all of this work, also tonight i ordered a Nira i3 squirt. And from what I've heard the engine will hold for the new Hp so fingers crossed and hope so
01-18-2014, 06:24 PM #5
Where are you from? Evolve could probably custom tune you if you got the car on a dyno and worked something out
01-18-2014, 08:02 PM #6
- Jan 2014
- 119
- 197.1
Sweden
Thanks for the reply!
ill keep posting my progres and show you guys how it developes,
Of:t can i earn rep quicker? I would like to post some links off my car
01-18-2014, 09:35 PM #7
Hi, and welcome. Here's some rep.
I like your plans for the car and want to see the diesel guys get some turbo upgrade options.
A GT35 would be sweet but since the stock setup is a compound turbo system I don't know if you can just take it all off and put a GT35 in its place. At least not without some serious lag? @alex@ABRhouston may be able to answer this better.BRAND NEW IN BOX 991.2 standard/non-pse SPW cat bypass pipe for sale - $899 shipped
01-18-2014, 09:50 PM #8
- May 2013
- 2,950
- 992.0
- 58 Post(s)
- 10
He's not, he's talking about for the larger turbo, but sounds like he talked to someone and got that figured out. He bought a T67 and not sure what he's doing for small turbo.
I'm really surprised we haven't seen some nice diesel setups, there must be some challenges I'm not aware of. I'd think a 335d xdrive could do some work2013 Audi S6 stock but shopping....
2014 RAM 2500 6.7 Cummins. Far from stock
01-18-2014, 09:52 PM #9
From what I understand you have to maintain a good balance between the two so I have no clue how he's doing this.
I'm surprised too. I would like to see far more diesel tuning. I've thought of doing a dedicated site just for diesel tuning but unfortunately dieselboost.com is taken.BRAND NEW IN BOX 991.2 standard/non-pse SPW cat bypass pipe for sale - $899 shipped
01-18-2014, 09:56 PM #10
- May 2013
- 2,950
- 992.0
- 58 Post(s)
- 10
I know there a lot ST and TT kits available for the diesel trucks, converting TT's or compound turbo setups. Most truck need injectors, duel pump setup, exhaust, tune, intake, head studs, big turbos, I know nothing about X5d or 335d motors, hell I don't even know the motor code. I'd think that fueling would be the major wall same as it is for us N54 guys. Just not the room under the hood for us like there is on trucks to easily fab up a duel HPFP setup.
01-18-2014, 10:01 PM #11BRAND NEW IN BOX 991.2 standard/non-pse SPW cat bypass pipe for sale - $899 shipped
01-18-2014, 10:44 PM #12
- Jan 2014
- 119
- 197.1
Thank you so mutch! Yeah im trying to figure out how to change/find a upgrade for the smaller one aswell, im gonna sit down tomorrow and do some serious research and erase that problem
i think thats the only thing left to get everything to work good. Atleast i hope so haha!
One thing i really know is that i will not quit until i get it to work, i want a really mean diesel out on the roads!
Heres some pictures : http://www.garaget.org/?car=344310
and here's a short exhaustsound video: http://m.youtube.com/watch?v=b2QOvtnnLds
Edit: thanks again to all of you
01-18-2014, 10:46 PM #13
- May 2013
- 2,950
- 992.0
- 58 Post(s)
- 10
Just depends on how big you go. With the compression most diesels have you can get away with a pretty damn big turbo. I don't know much about the N57 except that it uses a similar fuel setup as the larger trucks do, as does our N54. Also keep in mind you're talking 6.0liter + motors. I'd have to ask my brother-in-law what he was doing, but I know he wants to get a duel HPFP and upgrade his large turbo to like a 72mm with a 1.14 A/R/ turbine was like 76mm or something as well. That was a "small" turbo upgrade for his truck...can't imagine a turbo that size on our cars...LOL
01-18-2014, 10:47 PM #14
- May 2013
- 2,950
- 992.0
- 58 Post(s)
- 10
01-18-2014, 10:54 PM #15
- May 2013
- 2,950
- 992.0
- 58 Post(s)
- 10
@Sticky here is an example of a upgraded low-pressure side turbo for a 6.4liter powerstroke. Wouldn't it be nice to have a drop-in turbo option like this for 200whp? LOL only in the diesel truck world....I swear I have a friend with a cummins and he just doesn't understand auto-performance outside the cummins world of simplicity. Diesel truck guys have it easy....a lot these guys replace these low-pressure turbos and keep the stock high-pressure turbo. Tony Vargas would actually be one of the best guys around for this stuff @VargasTurboTech
http://www.rudysdiesel.com/_e/Turbo_...6mm_Billet.htm2013 Audi S6 stock but shopping....
01-18-2014, 10:55 PM #16
01-22-2014, 04:56 PM #17
- Jan 2014
- 119
- 197.1
Alright, I got all of this figured out! Lets go crazy!
First of all I'm buying a Nira i7r motor system controller tomorrow to have full access and control of the car,
Second ill buy a cp3 twin pump /or another original pump that i will twin connect to the other one, and a Airdog pump so I'm sure ill get enough juice. and I'm talking to a company some where in the states that makes performance injectors I'm awaiting an answer from them if i can get performance Pietzo injectors or some injectors at all that will fit at as my original.
for the third i found my self a Holset he531ve that will replace my stock biturbo to a big ass single turbo setup
forth im gonna laborate with Meth/water injection cuz i don't have any roof at the newton scale in my ecu so i should be able to make another 100hp just from that!
This $#@! just got real and its gonna be one nasty car haha!
what you guys think about this? Im making a project thread somewhere on the forms so people that wanna se my progress can followLets do this!
01-22-2014, 05:01 PM #18
- Jan 2014
- 119
- 197.1
03-15-2014, 04:30 AM #19
- Jan 2014
- 119
- 197.1
I'm soon finished with my project!
ESS stage2 -386hp 780nm
other ++ mods:
600X300X76MM Intercooler
3,5'' full flow Stainless steel exhaust from turbo back. with 4,5'' end pipes
Water/meth Snow performance Stage2
Optimized BorgWarner twin turbos
Home made AEM 4,5''x9'' Cold air filter system (in progress I'm waiting for the items)
Going for the dynos on 19th of may this spring, Stay tuned for more videos! its soon time to fire her up!! gonna be a pretty sweet machine!Last edited by teddy; 03-15-2014 at 04:35 AM. Reason: more info
03-15-2014, 05:01 AM #20
- Jan 2014
- 119
- 197.1
03-18-2014, 09:46 AM #21
- Jan 2014
- 119
- 197.1
Bad picture i know, but here she is atm! Better pics is coming, i just need to get her out of the garage
Im also looking for a nice front lip that will cover up the IC, any sugestions? (:
03-18-2014, 04:26 PM #22
Talk to @ModBargains
03-30-2014, 05:45 AM #23
- Jan 2014
- 119
- 197.1
03-30-2014, 10:40 AM #24
04-02-2014, 12:09 AM #25
- Jan 2014
- 119
- 197.1
Weird, try this one its just a phone clip but i promise ill post a better one this weakend!
