Results 1 to 15 of 15
Thread: Log Check?
    Feb 2012
    Naples, FL
    73 Post(s)
    Log Check?
    opinions? I cant graph them because the CSV grapher online does not work anymore.
    Attached Files Attached Files
    Dec 2011
    Roanoke VA
    54 Post(s)
    I'll check it out when I get to the house. Personally though, I prefer .CSV file attachments to graphs anyway.
    MOTIV750, MOTIV P-1000 PI, MOTIV/FUEL-IT! low pressure fuel system, AEM EMS/COBB AP, Aquamist HFS-3, ETS FMIC, SPEC stage 3+ clutch/SS flywheel, BC Racing coilovers and VMR wheels wrapped in Hankook RS3s.
    Feb 2012
    Naples, FL
    73 Post(s)
    I cant attach CSV on this forum
    Dec 2011
    Roanoke VA
    54 Post(s)
    Click here to enlarge Originally Posted by E90SoFlo Click here to enlarge
    Yeah, I know. I guess I should said CSV saved as TXT. I prefer the file, not the picture Click here to enlarge
    Apr 2012
    Click here to enlarge Originally Posted by rader1 Click here to enlarge
    can you save it in excel format? just makes it easier then having to convert txt to excel
    Feb 2012
    Naples, FL
    73 Post(s)
    Click here to enlarge Originally Posted by EastCoast335i Click here to enlarge
    Im on a mac, can I do this in textedit?
    Feb 2012
    Naples, FL
    73 Post(s)
    upload them here
    Meth and 93
    http://www.megafileupload.com/en/fil...h-93--csv.html
    E50 and meth
    http://www.megafileupload.com/en/fil...meth--csv.html
    There are some "idiot" advertisements on that megafileupload.
    Dec 2011
    Roanoke VA
    54 Post(s)
    CSV is excel format. Just click save as and then rename as .csv
    Feb 2012
    Naples, FL
    73 Post(s)
    Oh I didn't know that, the CSV files are attached above. (post 7)
    Dec 2011
    Roanoke VA
    54 Post(s)
    Ok, finally got a chance to look at your logs and i'm liking what i'm seeing(for the most part.)
    I just looked at the meth+e85 logs in the first post.
    It's obvious you prefer the timing>boost philosophy and i respect the hell out of that, but with all that octane i think you're leaving some power on the table with that conservative boost curve. I know you're pushing quite a bit timing but you had 0 corrections in either log so i would try upping the boost a little and see how the car likes it.
    IMO the car will make more power with a little more boost and a little less timing.
    Also, i would back the AFRs off a smidge. Personally like 12-12.2 but thats just me.
    The only thing that looks weird is that you were WAY below load/boost targets in datalog 6 but was fine in log 4. However, the car wasn't asking for any more WGDC to actually try and hit targets. I'm not sure what was going on there.
    Feb 2012
    Naples, FL
    73 Post(s)
    Blew a jet out of the charpipe on log 6
    Mar 2012
    8 Post(s)
    Racecar log, I approve.
    Dec 2011
    Roanoke VA
    54 Post(s)
    Ahh, that makes sense.
    Feb 2012
    Naples, FL
    73 Post(s)
    Someone post the graph so I can see it Click here to enlarge
    or explane to me how to make a graph like that. without the website
    Dec 2011
    Roanoke VA
    54 Post(s)
    Download Virtual Dyno(http://www.bradbarnhill.com/projects/VirtualDyno/) and then use the built in graphing feature. I actually prefer the VD graphing to using excel, it's faster and easier to add/remove channels.
