Results 1 to 15 of 15
Thread: Log Check?
12-08-2012, 01:26 PM #1
- Feb 2012
- Naples, FL
- 2,085
- 2,211.2
- 73 Post(s)
Log Check?
opinions? I cant graph them because the CSV grapher online does not work anymore.
12-08-2012, 03:43 PM #2
I'll check it out when I get to the house. Personally though, I prefer .CSV file attachments to graphs anyway.
MOTIV750, MOTIV P-1000 PI, MOTIV/FUEL-IT! low pressure fuel system, AEM EMS/COBB AP, Aquamist HFS-3, ETS FMIC, SPEC stage 3+ clutch/SS flywheel, BC Racing coilovers and VMR wheels wrapped in Hankook RS3s.
12-08-2012, 03:52 PM #3
- Feb 2012
- Naples, FL
- 2,085
- 2,211.2
- 73 Post(s)
12-08-2012, 07:00 PM #4
12-08-2012, 07:40 PM #5
- Apr 2012
- 10
- 4.6
12-08-2012, 07:57 PM #6
- Feb 2012
- Naples, FL
- 2,085
- 2,211.2
- 73 Post(s)
12-08-2012, 08:21 PM #7
- Feb 2012
- Naples, FL
- 2,085
- 2,211.2
- 73 Post(s)
upload them here
Meth and 93
http://www.megafileupload.com/en/fil...h-93--csv.html
E50 and meth
http://www.megafileupload.com/en/fil...meth--csv.html
There are some "idiot" advertisements on that megafileupload.
12-08-2012, 08:46 PM #8
12-08-2012, 09:11 PM #9
- Feb 2012
- Naples, FL
- 2,085
- 2,211.2
- 73 Post(s)
12-09-2012, 02:18 AM #10
Ok, finally got a chance to look at your logs and i'm liking what i'm seeing(for the most part.)
I just looked at the meth+e85 logs in the first post.
It's obvious you prefer the timing>boost philosophy and i respect the hell out of that, but with all that octane i think you're leaving some power on the table with that conservative boost curve. I know you're pushing quite a bit timing but you had 0 corrections in either log so i would try upping the boost a little and see how the car likes it.
IMO the car will make more power with a little more boost and a little less timing.
Also, i would back the AFRs off a smidge. Personally like 12-12.2 but thats just me.
The only thing that looks weird is that you were WAY below load/boost targets in datalog 6 but was fine in log 4. However, the car wasn't asking for any more WGDC to actually try and hit targets. I'm not sure what was going on there.
12-09-2012, 02:02 PM #11
- Feb 2012
- Naples, FL
- 2,085
- 2,211.2
- 73 Post(s)
12-09-2012, 02:27 PM #12
- Mar 2012
- 554
- 1,335.4
- 14
12-09-2012, 02:38 PM #13
12-09-2012, 03:07 PM #14
- Feb 2012
- Naples, FL
- 2,085
- 2,211.2
- 73 Post(s)
Someone post the graph so I can see it
or explane to me how to make a graph like that. without the website
12-09-2012, 04:45 PM #15
Download Virtual Dyno(http://www.bradbarnhill.com/projects/VirtualDyno/) and then use the built in graphing feature. I actually prefer the VD graphing to using excel, it's faster and easier to add/remove channels.
