Results 1 to 8 of 8
Thread: temp drop = elevated fuel trims?
11-28-2012, 08:20 AM #1
- Mar 2012
- 490
- 601.5
- 11 Post(s)
Or is there something else going on?
First log is from a couple days ago in 55F, second log is from the summer in 95F. Both using a similar mixture of fuelLoe P.
-19' F82 M4cs
- 14' B8.5 Audi S5 3.0"T" S-tronic - gone
- 09' E90 M3 7-DCT- gone
11-28-2012, 09:22 AM #2
As temperature decreases, air density increases. Higher density equals more O2 molecules per unit volume. That is my guess.
11-28-2012, 11:06 AM #3
11-28-2012, 11:19 AM #4
- NJ
- 13,412
- 58.0
- 318 Post(s)
11-28-2012, 12:10 PM #5
Supporting Vendor
Absolutely. As others have said we use an absolute boost target system and colder air is denser so you get more oxygen squeezed in for a given PSI. Which needs more fuel, all else being equal.
11-28-2012, 07:58 PM #6
This is exactly what I've said a couple times on other forums, but everyone likes to jump on the "COOL TEMPS, MORE BOOST" train pretty fast lol. Generally speaking I down the boost a bit when winter kicks around, but most people seem to want to run more boost because of cooler temps. I guess it depends on how far you were pushing the threshold before winter kicks around.
jb4+fbo+meth
11-28-2012, 08:25 PM #7
Supporting Vendor
That is where auto tuning works out nicely. It will adjust boost, wastegate duty cycles, and open loop, as you go.
11-30-2012, 08:34 AM #8
- Mar 2012
- 490
- 601.5
- 11 Post(s)
thanks for the responses. My fuel trims remain the similar w/o methanol too when I logged last night. I would normally run w/ meth, but my Coolmist solenoid is "stuck" and won't flow w/ the in/out direction, only reverse. First methanol kit ever, and it's not been reliable.
sorry in advance for the short log. Summer fuel trims w/ E50 normally peaks at 30 in fuel trims w/o methanol.Loe P.
-19' F82 M4cs
