Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 56
    Apr 2011
    Jersey City
    75 Post(s)
    I guess I should have made it more clear, the OTS map wasn't a stage 2 aggressive map (ots was a stg2 sport map)....still solid gains though. I never said stg2 aggressive in the beginning of the thread, I apologize if people didn't realize that.
    What people will notice with a protune is how much better the car feels with optimized timing and whatever else he tuned. I've used the ots aggressive maps and they didn't feel like this. The power is a lot more useable at all rpms, it really transforms the drivability of the car.
    ESS 6XX kit
  2. #27
    www.bootmod3.com
    233 Post(s)
    Click here to enlarge Originally Posted by bobS Click here to enlarge
    Yes, running 93 Oct.
    How come you came on the dyno running the sport version of the stg2+ map and not aggressive? Did you have knock on the aggressive stg2+ with your octane? Just pointing it out as it'd make your starting baseline lower and a larger delta than if you had the OTS stg2+ aggressive on there to start out with.
    He has a partner in his business located in Md. Right DZ?
    Yep, Jake's in MD.
  3. #28
    Apr 2011
    Jersey City
    75 Post(s)
    Click here to enlarge Originally Posted by dzenno Click here to enlarge
    Yep, Jake's in MD.
    I was running that map bc my car didn't run well on the beta v4 aggressive tune....Cobb released it Out of beta with oscillation fix that day of my protune. Could I have had them flash it to the agg map and dyno...I guess but I really didn't think of it at the time. When I look at all the numbers of the dyno data base on their website, considering I dyNoed the car in 88 degree conditions, I'm very happy with the numbers. Not to mention this was the final pull after over a hour of tuning on the
    dyno and a bunch pulls
    ESS 6XX kit
  4. #29
    www.bootmod3.com
    233 Post(s)
    I was running that map bc my car didn't run well on the beta v4 aggressive tune....Cobb released it Out of beta with oscillation fix that day of my protune. Could I have had them flash it to the protune and dyno...I guess but I really didn't think of it at the time.
    Ya, no worries, what matters is you're happy and car's running strong!
  5. #30
    Apr 2011
    Jersey City
    75 Post(s)
    Yup...I'm very happy I did it
    ESS 6XX kit
  6. #31
    Stockholm
    61 Post(s)
    Stage 2+FMIC? or stage 2? just messing but really when talking about maps it should be precise :-)
    I was running Stage 2+FMIC SPORT V301
    Apr 2011
    Jersey City
    75 Post(s)
    Click here to enlarge Originally Posted by enrita Click here to enlarge
    Stg2 + FMIC sport v301
    ESS 6XX kit
  8. #33
    NJ
    318 Post(s)
    LOL, #'s this and #'s that.
    The one thing I learned about Bob over the past few years, is that he doesnt want or need to be the fastest, highest HP guy around (believe me, i tried)
    His ultimate goal, is max hP (obviously) but with ZERO compromises on drivability, longevity, and safety. And if a few ponies less are achieved in doing that, Im pretty sure he is more than fine with it
  9. #34
    Apr 2011
    Jersey City
    75 Post(s)
    Your correct sir....I'm going to be that guy that runs pump only rb's one day ha
    ESS 6XX kit
  10. #35
    NYC
    104 Post(s)
    Waste of money then, but to each their own.
  11. #36
    Apr 2011
    Jersey City
    75 Post(s)
    We'll see, I still haven't given up hope that Cobb will unlock fueling options to get more power out of the rb's or a better TT / single turbo setup will emerge.
    ESS 6XX kit
  12. #37
    columbia sc
    32 Post(s)
    Well I am finally going the meth route I just ordered an HFS-4 meth kit, I hope meth is all its touted to be and more... I want 11's bad. I am bored of 12.2-12.5 1/4 mile runs..
  13. #38
    Jul 2012
    Not if I beat you to it.
    Click here to enlarge Originally Posted by themyst Click here to enlarge
    Why's that? I'm not challenging, it's a legit question that I would like to hear opinions on before I drop the coin on it. If going FBO with a tune from Jake is the more logical choice, then it saves me $3600.
  14. #39
    NYC
    104 Post(s)
    You're tapped out around 440-450 whp on 93 octane with RBs. To fully reap the benefits of those turbos you need meth or E85. I'd love for someone to prove me wrong.
    On the flip side, you could keep your stock turbos, get a meth kit and lose 20-30 whp in the process, save about $4500 total installed.
    Unfortunatrly, since jake and dzenno either do not have an RB turbo car OR E85 available to them locally, there won't be much movement on the E85 front until someone steps forward to be the guinea pig.
    If 20-30 whp is worth $4500 installed to you, like I said, to each their own.
    $3050 for RBs after domestic shipping
    $1000 installation labor, MUCH more if xi.
    $300 oil, coolant, installation parts
    $300 core charge
  15. #40
    www.bootmod3.com
    233 Post(s)
    $300 core charge
    You're looking at peak numbers though...look at the area under the curve with RBs especially up top...440-450 held to redline on RBs vs power coming down past 5700rpm on stockers i think
  16. #41
    Apr 2011
    Jersey City
    75 Post(s)
    I agree, 440-450 whp with power all over the curve and not dropping well before redline is nice. Now if we could get a little more with some tweaks from Cobb I'd be completely sold. Meth to me is just a headache but themyst is right, as of now it's the way to get the most bang for your buck with the RB upgrade...
    ESS 6XX kit
  17. #42
    www.bootmod3.com
    233 Post(s)
    On pump gas with RBs we're octane limited, not fuel limited. Adding more octane through race gas or E85 (if meth isn't your thing) will lift that number higher safely and with consistent results. I did manage to hit 470+whp (on a conservative dyno that baselines 275-280whp FBO stock boost on pump) but it was too aggressive for just pump gas IMO
  18. #43
    Apr 2011
    Jersey City
    75 Post(s)
    OK...thanks for the clarification. Are you still working on coming up with a different twin turbo upgrade than rb's?
    ESS 6XX kit
  19. #44
    www.bootmod3.com
    233 Post(s)
    Np. That's actually all @Mat Morkin , i'm just helping him out with advice from the tuning side and any questions he may have that i may have gathered over time in this 100lb big head of mine Click here to enlarge Actually talked to him today for a bit on the train coming back from work. His kit should be a really nice upgrade provided everything works out, easier said than done of course. If/when it does get done I'd love to slap it on and give it a whirl for sure..as well as his intake mani
  20. #45
    Apr 2011
    Jersey City
    75 Post(s)
    Np. That's actually all @Mat Morkin , i'm just helping him out with advice from the tuning side and any questions he may have that i may have gathered over time in this 100lb big head of mine Click here to enlarge Actually talked to him today for a bit on the train coming back from work. His kit should be a really nice upgrade provided everything works out of course, easier said than done of course. If/when it does get done I'd love to slap it on and give it a whirl for sure..as well as his intake mani
    OH ok cool.....I hope everything works out
    ESS 6XX kit
  21. #46
    NYC
    104 Post(s)
    Rob Irish gave me a little ATR 101 lesson today, so let's see how fast I blow up my motor Click here to enlarge
  22. #47
    May 2012
    Jacksonville, FL
    95 Post(s)
    0 out of 1 members liked this post. Yes Reputation No
    Care to share your notes? Did he give you the coveted race logic aka boost limit remover map?
  23. #48
    Mar 2011
    Any logs would be great for the community, i know you paid money to do this but dont be selfish share Click here to enlarge
  24. #49
    NYC
    104 Post(s)
    Then you forget about the effects of heatsoak and rising cylinder temps on pump gas only RB car vs a stock turbo car with meth/water mix, so a stock turbo + meth car would sustain power in longer runs Click here to enlarge
    We could go back and forth about this all day, but the end result is, getting RBs just to run them on pump gas is a waste of time for the money.
  25. #50
    NYC
    104 Post(s)
    Click here to enlarge Originally Posted by lulz_m3 Click here to enlarge
    I've had those for months now. Waste of time on stock turbos though like the PTF guys said.
