Results 1 to 11 of 11
    Stockholm
    61 Post(s)
    COBB Stage 2plus aggressive logs
    some logs i took this weekend. Lots of TPS action because probably of poor traction (cold / winter tyres)
    timing correction changes constantly , sometimes none, sometimes 1 cylinder and sometimes 2. Car runs very well but i can feel more power off meth (with meth AFR goes down to 11-11.5 and fuel mode 6 is triggered). Not spraying much, about 600 ml/min. No codes at all.
    Click here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlarge
    www.bootmod3.com
    233 Post(s)
    TP closures will subside as you do a few runs ..it's also evident in these logs, initially there was more and then by the last log they're next to none..
    Overall looks good to me, no flatlining, no misfires...600ml should be plenty in winter conditions ..
    52 Post(s)
    Enrita, are you going to try Procede with Cobb? I think this would be a good compo. And I don't think you need Vishnu help... it could be done now. I can make some initial map suggestions for you if you're interested.
    www.bootmod3.com
    233 Post(s)
    i just wish cobb had a nice/fast graphing tool...i don't like that web based one as it doesn't allow to set scaling properly at all and makes looking at things time consuming
    Stockholm
    61 Post(s)
    Click here to enlarge Originally Posted by JoshBoody Click here to enlarge
    no , dont think actually it can be done, map 0 is not full pass through as jb4 for example. I have asked Vishnu but they are reluctant in doing such a version. There are other options...
    NYC
    104 Post(s)
    Click here to enlarge Originally Posted by dzenno Click here to enlarge
    The OpenOffice charting tool is fast and excellent. I can get something charted in about 2 minutes tops. I prefer it for that purpose over Excel.
    Stockholm
    61 Post(s)
    Click here to enlarge Originally Posted by themyst Click here to enlarge
    do you have an openoffice template done that you can share? Basically just copy and paste over the new data to graph?
    52 Post(s)
    Click here to enlarge Originally Posted by enrita Click here to enlarge
    You don't need pass through... just zero out OL table and put AFR to 50, so Cobb fueling. You can 0 ignition for map1 and add advance for map2 (meth). You will not be able to use Cobb boost, but his is ok... procede has great boost control.
    It won't be a huge difference based on the Cobb public maps, but if you can get DZ's race maps for increase ignition then it could be very powerful on meth and conservative off meth.
    I think it would be a great combo... of course I would start very conservative at first and see how everything is meshing. Supposedly you can use stock procede with some minor map finetuning in the 1M, IS, etc... so dumby signal should be mirroring the different tuning just fine.
    NYC
    104 Post(s)
    You would just open the CSV in OO, Insert > Chart > Chart Type > Line > Finish.
    Then you can click on the various lines to delete the unnecessary ones, right click the axis to scale as needed.
    I wish I could scale the bottom to RPM instead of time so I can get more data, but I'm not that well-versed in all of this....
    Chicago Burbs
    21 Post(s)
    Meh, excel takes bout 2 mIns to graph as well with practice.
    Thanks for the logs Enrita.
