Results 1 to 25 of 66
11-08-2011, 07:57 PM #1
- NJ
- 13,412
- 58.0
- 318 Post(s)
RB Turbos @ Atco-Street trim-126mph
pump/meth, full street trim (full weight, 19" wheels)
plaaying with 17, touching 18 psi
so far 12.5@126
12.4@126
12.0@125
and now added some ms103 bumped to 18.5/19 psi @5k rpms, all runs tapering to 16.5 psi @ 6k rpms.
12.0 @123- didnt log, laptop got disconnected., hit kickdown and misfired
probably only gonna do 1 more run, im gettiing a misfire in 4th up top. probably time to change plugs again..Last edited by LostMarine; 11-08-2011 at 08:04 PM.
11-08-2011, 08:07 PM #2
- NJ
- 13,412
- 58.0
- 318 Post(s)
oh, and DA from kestrel 4000 says +200 for first 2 runs, down to -200 for 3rd and about even for 4th run
vbox is reading +3mph in the 1/8 and -2mph in the 1/4, and ET is .1 slower, so tonight, Atco might be a "fast" track
11-08-2011, 08:08 PM #3
Awesome dude. I didn't know tracks were open on Tuesday night. Are you video recording as well?
11-08-2011, 08:17 PM #4
11-08-2011, 08:23 PM #5
11-08-2011, 08:28 PM #6
11-08-2011, 08:29 PM #7
- www.bootmod3.com
- 6,711
- 3,356.0
- 233 Post(s)
Damn plugs...I'd suggest trying out the NGK 5992 mini plugs that I'm running now...gap them to 0.6mm (they come with 0.8mm gap and stock are 0.7mm)...should put less strain on the coils at high boost which should also prolong coil life over time and as they're 1 heat range colder they should allow for heat to escape from the cylinder faster/less chance of pre-ignition...cheap thing to try but obviously with some logging...
I've done more runs on these plugs gapped at 0.6mm and high boost with RB turbos than I think all runs put together on stock turbos...previous problems that ppl had with these plugs were IMO falsely attributed to plugs either due to an improper/large gap or other issues (hpfp/injectors), or in enrita's case due to a huge boost spike in high gear and low octane for extended runs such as airfield events
I won't go back to stock plugs that's for sure
11-08-2011, 08:34 PM #8
11-08-2011, 08:35 PM #9
Temps are in the high 50's low 60's. Not sure what the temps were the last time, but the OP's car hauls.
11-08-2011, 09:56 PM #10
- NJ
- 13,412
- 58.0
- 318 Post(s)
so im back, last run was 12.0@125 19-16 psi at redline, tried short shifting to 5th but still misfired. i know the car would have done 127 if i could rev it out..
ill post details in a few
on good note +32mph on the back end with misfires aint too shabby
its good to know how my car performs in everyday trim- now just gotta prep for the private rentalLast edited by LostMarine; 11-08-2011 at 10:04 PM.
11-08-2011, 10:21 PM #11
- www.bootmod3.com
- 6,711
- 3,356.0
- 233 Post(s)
11-08-2011, 10:23 PM #12
11-08-2011, 10:25 PM #13
- Dec 2010
- Murrland
- 287
- 489.1
You going seats out, race gas, track wheels and 20+psi for the private rental?
07 e92 335i Best run: 11.83@ 120.04 w/ 1.84 60' & 2127 DA
11-08-2011, 10:30 PM #14
- www.bootmod3.com
- 6,711
- 3,356.0
- 233 Post(s)
11-08-2011, 10:36 PM #15
- NJ
- 13,412
- 58.0
- 318 Post(s)
msifires are 99% probably due to plugs, i havent changed them in a while and idle is kinda rough.
for the private day? HELL YES ALL OUT!!!
another good note is the trans seems to be holding up perfectly
11-08-2011, 10:39 PM #16
11-08-2011, 10:42 PM #17
- Dec 2010
- Murrland
- 287
- 489.1
11-08-2011, 10:44 PM #18
11-08-2011, 10:50 PM #19
- NJ
- 13,412
- 58.0
- 318 Post(s)
as long as DA is good. i was trapping today on 17 psi pump/meth what i did before basically on 19 psi race/meth
11-08-2011, 11:33 PM #20
- AZ
- 2,826
- 43 Post(s)
11-08-2011, 11:35 PM #21
11-08-2011, 11:48 PM #22
- 325
- 467.6
There's a private rental at MIR on 18 Nov. I guarantee it's the best prepped track you've ever seen. Come down.
11-08-2011, 11:50 PM #23
- 880
- 594.0
- 23 Post(s)
insane times as usual congrats brotha....seems like your car could easily put the blown M3's around here to shame on street trim haha
11-09-2011, 12:09 AM #24
- www.bootmod3.com
- 6,711
- 3,356.0
- 233 Post(s)
11-09-2011, 12:56 AM #25
