Page 5 of 5 FirstFirst ... 345
Results 101 to 116 of 116
  1. #101
    May 2012
    Jacksonville, FL
    95 Post(s)
    I had the wotbox on my old car for over 4.5 years, not a single issue relating to the wotbox was had.
    2015 F10 M5 \ Alpinweiss
    Jul 2016
    5 Post(s)
    @tony:
    Everyone knows the N54, N55, and S55 crank hubs are not keyed.
    It's a real possibility that the rapid RPM fluctuations from sitting on the 2step loosened my crank bolt enough for the timing sprocket to slip. I had my WOTbox set at 3,500 rpm and logs show rpm jumping back and forth between 3,200 and 3,800 rapidly. I ran my car at 19-20psi for a good 10k miles without issue, doing pulls, banging gears, not exactly being gentle and it had no issues. Then when a mere 500 miles after I install WOTbox carnage happens, I think it's pretty clear what caused it even if the exact mechanism is unclear.
    However, if other members have had better luck, so be it. I don't drag race anyways, so I'll just learn to launch better without needing to build 5+ psi of boost.
    @bigdnno98:
    I had the stock DMFW when it happened. Do you think you could post or send a log of your rpms on the 2-step?
  3. #103
    Dec 2011
    Wiesbaden, Germany
    70 Post(s)
    Click here to enlarge Originally Posted by veer90 Click here to enlarge
    @tony:
    @bigdnno98:
    Not possible. That was 5-6 years ago and 3 computers ago. Sorry
    Damn, DMFW? That crushes the idea I had about vibrations.
    2016 340xi AT
  4. #104
    Aug 2014
    @veer90, what have you done to the mounts for the vehicle? Engine mounts, trans mounts, flex disc, differential mounts?
    Has anyone balance their crankshafts? @alex@ABRhouston, @Motiv guys (not sure the engine builder for you guys is on the forums) what are you seeing when you are having the engine built? I know the bed-plate has to machined after removing it, but are y'all balancing the crankshafts?
  5. #105
    Click here to enlarge Originally Posted by topher454 Click here to enlarge
    Some good questions here.
    Let's tag @alex@ABRhouston again.
  6. #106
    Jul 2016
    5 Post(s)
    At the time, the only upgraded mounts I had were transmission (UUC black), rear polyurethane diff and subframe mounts (SuperPro), and the revised BMW guibo with an aluminum body and smaller rubber bushings. Motor mounts were stock.
    After the slipped hub got fixed I upgraded to polyurethane engine mounts (ADE) and will be running a SMFW and upgraded turbos.
    Can anyone in this thread send me a RPM log of their 2-step in action? It's possible the WOTbox itself may be faulty / screwy since I bought it used and have no reference as to how it should behave.
  7. #107
    Jun 2013
    North Houston
    166 Post(s)
    Yes of course the rotating assembly is balanced. Typically almost no work is needed. We balance to .5 gram- crank/rods/pistons, and if the client has a flywheel/pressure plate available- it, too at the same time.
  8. #108
    Nov 2017
    Is this possible on a auto?
  9. #109
    Dec 2011
    Wiesbaden, Germany
    70 Post(s)
    Click here to enlarge Originally Posted by Bimmer5454 Click here to enlarge
    Why would you want it on an AT?
    2016 340xi AT
  10. #110
    Apr 2016
    Click here to enlarge Originally Posted by bigdnno98 Click here to enlarge
    Haha, you know why. Bang pow pow sounds.
    http://www.bimmerboost.com/showthrea...ot-box-on-auto
  11. #111
    Dec 2011
    Wiesbaden, Germany
    70 Post(s)
    It's not anti-lag. It's an RPM limiter.
    2016 340xi AT
  12. #112
    Nov 2017
    Ether way I would like to have it my turbos are smoking so their going out an i wouldn't liken to end their life in a fun way but not sure how to install this on a auto I have seen videos of people having it on a auto they just hasn't showed how something to do with cruise control on something
  13. #113
    Aug 2018
    Can anyone help tell me if I hooked my ignition wires up right? Also my yellow rpm wire is all wacky when hooked up and reads way above on rpm or reads none at all
  14. #114
    Apr 2015
    I just got my wot box I installed as such but instead of a red /black wire it's just red but after install tried to start the car cranks but will not start
  15. #115
    Jul 2011
    Germany
    just to be sure..
    RPM source is X60005 large black connector Pin 29, CPS-Signal.
    Is it not the crank signal?
    Click here to enlarge Originally Posted by _Calle_ Click here to enlarge
    just to be sure..
    Anyone?
