Results 1 to 19 of 19
06-07-2015, 12:26 PM #1
- May 2015
- 6.5
Trying to Locate DME relay in 2008 BMW 335xi (12/2007 build)
I've been trying to find my DME relay...it's not in the ecu box. I also don't have the fuse carrier that says "motor sicherungen" on it. All posts I find about the ecu box do not look like mine, but my ecu box does look like the pics on how to install a JB4 in that I have a 50 amp fuse near the power wire and also a black relay which appears to be the electric fan relay. This pic shows what my ecu box looks like.
The Bentley manual image "electric fan" for my model does not look like this at all.
06-09-2015, 04:59 AM #2
06-09-2015, 06:59 AM #3
- Jan 2013
- Savannah GA
- 1,333
- 2,662.1
- 108 Post(s)
I looked it up in ALLDATA. I cant attach the pics from work computer, but it says its in the DME box upside down. Its a black relay K6300 designation. Its between the red or green fuse (cant remember off the top of my head) and the silver relay that is upside. It should be forward of the DME. If you cant find it remove the connectors on the DME, get the wires out of the way and take a picture of the inside of your box and we may be able to help more
06-10-2015, 05:01 PM #4
- May 2015
- 6.5
Thanks for checking into that for me. I've attached some pics of my DME. Unfortunately, doesn't look like what ALLDATA describes
06-10-2015, 05:31 PM #5
- Jan 2013
- Savannah GA
- 1,333
- 2,662.1
- 108 Post(s)
06-10-2015, 05:49 PM #6
Should be sky blue. Have you checked under the dme support? Only place left I can think of.
Here is a diagram
http://www.realoem.com/bmw/enUS/show...diagId=12_132707 335XI(A008006) 6AT ~105K miles JB4 G5 ISO VSRF DP's
09 135I(VK80379) 6MT. Race Project car.
1) Install Modified Motiv 600 Kit[HTA3076R w/ tial .82] 2) Moton 4 suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage possible rear diff upgrade 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system 7) Sequential maybe
06-11-2015, 07:32 AM #7
To confirm the function of that relay, by pass it by jumping contactor 3 and 5 together with male spade terminals.( relay removed of course and jumper on harness side) If the fan kicks on then its a fan relay, if the DME powers then its the DME relay.
06-11-2015, 07:44 AM #8
Black relay in your fuse panel is the "DME main relay". Located to the right of the panel, at least in my car. I have an 08 as well and went friggin nutz when I had problems with it. The black relay in the ECU box is the fan relay , as mentioned earlier.
Good luck!
06-11-2015, 11:08 AM #9
- May 2015
- 6.5
Thanks everyone for the input. I tested the black relay in the fuse panel and it tests as good. Brought to a local shop and they confirmed its a bad DME. Looking into RPM Motorsport to send them my DME to swap with a new "re manufactured" one for $1200. Much better than the $2300 I was quoted at the shop.
06-11-2015, 12:22 PM #1007 335XI(A008006) 6AT ~105K miles JB4 G5 ISO VSRF DP's
06-11-2015, 08:30 PM #11
- May 2015
- 6.5
It would crank for as long as I left my foot on the brake but would never turn over.
06-11-2015, 08:31 PM #1207 335XI(A008006) 6AT ~105K miles JB4 G5 ISO VSRF DP's
06-12-2015, 09:09 AM #13
- May 2015
- 6.5
Yup I actually had all six replaced before this happened. Got a 30bb code which is why I changed the mosfets. After the new mosfets were in I got different codes but no 30bb, so the issue must've been deeper than just mosfets (or the dude botched the job, it looked good though).
04-18-2018, 08:14 AM #14
- Apr 2018
- 15
- 11.0
Is this working now? I have the same problem I cannot find the relay my fusebox looks exactly like yours- Just spent a load on a newly programmed ECU and its performing the same way - I wish i knew how to create a thread!
11-12-2019, 11:20 PM #15
- Mar 2018
- 40.7
Sorry about bumping such an old thread but In dealing wit the same problem. Car cranks but wont start. Upgraded my dme to msd81 and still no start. Any help is appreciated. Currently going through all my wires and checking for any shorts because I have so many error codes. Thanks !
12-12-2019, 01:25 AM #16
12-12-2019, 01:41 AM #17
- Mar 2018
- 40.7
lol no, I did not want to spend any more money on the car so I decided to buy an F80 and part it out my single turbo e92.
12-12-2019, 01:43 AM #18
03-27-2020, 10:08 AM #19
- May 2015
- 6.5
Sorry guys I forgot all about this tread! For future knowledge I went online to https://www.rpmmotorsport.net/ and they sent me a new msd81 because they couldnt fix my msd80. Once I installed it I think I replaced a couple ignition coils and she ran better than ever.
