Results 1 to 8 of 8
    Apr 2016
    F/S Lots of Stock and Aftermarket Parts n54/n55
    Hi everyone – I have lots of parts for sale as I’ve done many upgrades over the years. I will list each item with the approx. mileage. Let me know what you’re interested in and I will send you detailed pictures, as the pictures listed may be distorted. All parts are best offer. I will update this thread once the part is sold.
    Message, text, or call – 201-982-0579 Sergio
    Parts from 2008 BMW 335xi Coupe, E92 N54
    Upgrades:
    -BRAND NEW OEM W0133-2188211 LUK flywheel (box opened for pictures, went with an upgraded flywheel/clutch)
    -BRAND NEW SPEC SB533H Stage 2+ clutch kit (box opened for pictures, went with an upgraded flywheel/clutch)
    -BRAND NEW vacuum hose
    -BRAND NEW Clutch Pilot Bearing
    -BRAND NEW various rubber couplers and v-band brackets
    -BRAND NEW eBay rear PDC sensor holders
    -Injen cold air intake – 20k miles
    -VRSF catless ceramic downpipes – 20k miles
    -VRSF 7” intercooler – 20k miles
    -“New” Walbro F900000274 E85 fuel pump – wires are cut and nipple is broken
    -VRSF chargepipe with stock diverter valves – 20k miles
    -Stage 3+ Dual Walbro LPFP
    Stock:
    -BRAND NEW throttle body gasket
    -BRAND NEW Front PDC trigger contact and bracket
    -Flywheel – 65k miles
    -Clutch fork lever – 65k miles
    -Shift knob with lever and black boot – 45k miles
    -Air intake – 45k miles
    -Charge pipe – 45k miles
    -Valve cover – 45k miles
    -Vacuum tanks – 65k miles
    -Exhaust and intake camshaft bearing ledges – 50k miles
    -Downpipes – 45k miles
    -Intercooler – 45k miles
    -Left and Right Engine mounts – 65k miles
    -“New” engine mount. Installed and snapped bolt while torqueing
    -Boost solenoids with bracket – 65k miles
    -Front & Rear turbo chargers – 30k miles (replaced under recall)
    -Inlet and outlet – 65k miles
    -Various oil and coolant pipes/hoses & brackets for original turbo – 65k miles
    -Oil level sensor – 65k miles
    -Air Intake Duct – 65k miles
    -Air Intake Tube – 65k miles
    -PCV Valve and screw-on cap – 45k miles
    -TMAP Sensor – 65k miles
    -Heating Element – 65k miles
    -Oil cooler thermostat – 65k miles
    -Oil filter cap – 65k miles
    -Power Steering bracket – 45k miles
    -Front Left and Right CV Axle – 65k miles (plastic chipped and threads damaged)
    -Front Left and Right wheel hub/bearing assembly – 65k miles (threads for ball joint damaged)
    -Front Left and Right tension strut – 65k miles
    -Front Left and Right control arm – 65k miles
    -Front Right sway bar link – 65k miles
    -o2 sensor – 65k miles
    -Power steering pulley – 65k miles
    -Rear PDC module – 65k miles
    -JB4 2015 24K22 Chip – 20k miles
    -Front passenger headlight bracket – 65k miles
    -Front driver air duct – 65k miles
    -Front Bumper w/black grilles
    -Rear Bumper w/PDC holes
    -Full Chrome Window Trim (plasti dipped black)
    -eBay low profile trunk lid painted space gray metallic – 45k miles
    -Silver interior trim, center console cut for CIC controller – 45k miles
    -4 LIKE NEW Bridgestone Blizzak LM32FZ 225/45R17 – 300 miles
    -2 fuel pumps – 1 is 65k miles and the other is unknown mileage as I bought used for the bucket
    -2 IBS sensors – unknown mileage. I bought them used to trace a wiring issue.
    Parts from 2011 BMW X5 35i, E70 N55
    -oil pan (damaged drain plug threads, needs repair) – 122k miles
    -Water pump – unknown mileage
    -Front right engine compartment support bracket – 122k miles
    -JEGS 80040 Engine Stand – Used once for engine removal
    Click here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlarge[ATTACH]
    GLWS
    Apr 2016
    Thank you!
    Apr 2016
    Both have been SOLD!
    Apr 2016
    Stock Downpipes have been sold!
    May 2014
    Socal
    How much for the Stage 3+ Dual Walbro LPFP and what brand? Thanks
    2008 335i: Docrace 6266, PR Coils, Stoptech ST60 and ST40 BBK, VRSF 7" fmic, ER charge pipe, forge dv, bms occ, Fuel-It Stage II Fuel pump, EOS PI, m3 control arms, Tune by Motiv via MHD.
    2007 N52 to N54 swapped e90: totalled :Click here to enlargesoon to be track car)
    Click here to enlarge Originally Posted by showcase199 Click here to enlarge
    @335xi2
    Apr 2016
    Sorry. Please see below of what I sold already. My post in a different forum, bimmer, is updated.
    -VRSF catless ceramic downpipes – 20k miles - SOLD
    -VRSF 7" intercooler – 20k miles - SOLD
    -VRSF chargepipe with stock diverter valves – 20k miles - SOLD
    -Stage 3+ Dual Walbro LPFP - SOLD
    -Downpipes – 45k miles - SOLD
    -Front & Rear turbo chargers – 30k miles (replaced under recall) - SOLD
