Results 1 to 7 of 7
04-25-2019, 11:56 AM #1
How-To Clean & Restore Your BMW Headlights!
If your BMW's headlights need a refresh, I created a step-by-step guide to bring them back to life. I've done this many times with great results and have tried all the kits out there. This is by far the best method that holds up over time. Just thought I'd share!
3M Headlight Restoration Kit: https://amzn.to/2IUptsU
3M Automotive Masking Tape: https://amzn.to/2W3wRWl
Automotive Glass Cleaner: https://amzn.to/2Dy4ZCP
32oz Spray Bottle: https://amzn.to/2Dy2LDt
Meguiar's Microfiber Towels: https://amzn.to/2L2GO5m
Meguiar's Ultimate Quik Wax: https://amzn.to/2XGH3EH
Cordless Drill: https://amzn.to/2PtjDQs
Shop Towels: https://amzn.to/2IVOFz8
If you've done this before, let me know your experience!🚀 My 750HP 135i build: my1series.com
🔧 My budget 335i build: bmw335i.com
🏎️ My F80 M3 build: bmwf80.com
🎬 YouTube channel (35K+ subs): youtube.com/jakespence135
📷 Follow me on Instagram: instagram.com/jakespence
🏁 Shop BMW merchandise: bimmerstreet.com
05-24-2019, 09:50 PM #2
05-25-2019, 10:50 AM #3
Don't forget to wrap with a quality PPF to protect against UV. There are UV sealants like OptiLens but it doesn't last so PPF is the best way to go since it is UV + abrasion. Well worth the investment.
N54 Powered M5 Wagon:
- M5 Driveshaft, M5 LSD, M5 Axles, M5 Brakes
- M5 Front End, M5 skirts, M5 Mirrors, M-Tech Rep Rear
- KW V3, RD Sport Sways, UR Strut Braces, Forgestar F14 SDC
- Manual Swap, MFactory SMFW, Spec Stg 3+ Clutch, Shiftteck SSK
- EOS Port Injection Manifold, Fuel-It: Stg 2 LPFP +Lines +Ethanol Sensor
- N54B30, JB4, Hexon RR550s, Custom Y-Pipe Inlet, AR DPs, 3" Exhaust, VRSF 7" IC, ER CP, Tial BOV, RB PCV, BMS OCC
05-29-2019, 02:31 PM #4
05-28-2021, 09:35 AM #5
- May 2021
- 1
- 1.1
One of the quickest and most efficient methods I use: Hot soapy water, 800 grain sandpaper, glass cleaner, and acrylic enamel clear coat are the materials. Use sticky plastic floor mat or layer tape to cover headlights and surrounding panels.
05-28-2021, 11:04 AM #6
- May 2021
- 1
- 25.1
05-31-2021, 08:48 PM #7
- Oct 2017
- 29
- 97.7
So far the headlights on my car are clear and not foggy. You can also try to clean if with toothpaste it really works.
