APR’s Flow-Formed Wheels are manufactured using the latest strengthening and weight savings techniques to provide an attractive solution ready for the street and track.
Product Page
Quick Facts:
  • Flow-formed aluminum design
  • 20x9.0" ET42 (19x8.5 ET45 also available)
  • Light-weight 23.6 LBS / 10.7 KG
  • Hyper Silver or Gunmetal
  • 5x112mm Bolt Pattern
  • 66.5mm center bore with included 57.1mm interlocking hub-centric ring
  • DOT, VIA, and JWL certified (TUV tests passed, pending certification)
  • Removable center-caps (Also fits VW 7L6601149B & Audi 8T0601170A center caps)
  • Designed for use with OEM-style and length ball seat lug bolts
  • Anti-slip machining feature to help prevent tire-to-wheel rotation
  • Finite Element Analysis (FEA) designed to minimize weight, yet retain a 700 KG load rating
  • Lifetime warranty against manufacturer defects and 1 year on wheel finish
  • Great Price: $449.99 Each!
Click here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlargeClick here to enlarge
