Results 1 to 3 of 3
02-26-2012, 04:23 AM #1
DLV-Engineering E39 530i turbo build thread
So I have been working on the car since March of 2011. Here is some high lights of the build with links to my photo albums. Low down of the project. All the work is done by myself(including the TIG welding) and with my fathers help. Turbo System:SPA T4 manifoldPrecision 6262 T4 .68a/r journalTial MVSCustom motor mount arm for turbo inletAll exhaust parts ceramic coated.3" 304SS exhaust to a Borla XR1 right behind the transmission the V banded to T6061 3" aluminum mid and rear section exhaust. Fuel system:E85 fuelDenso 1020 340lph pumpBosch 750cc injectors(may switch to ID1000's)8 an fuel feed lines to stock rail(modified with 8an fittings)Aeromotive regulator6an returnAll working with the stock tank and level sensors.Cooling and oil system:Aluminum rad for E46 M3 with normal coolant necks for 1.5" silicone hoseE39 528i thermostat housingCustom coolant tanksS54 oil filter housing with AN fittings welded on Engine management will be handled by a MegaSquirt 3X. On to the pics.
Oil catch tank
still needs a 12an bung and brackets to be welded onWhere it's going to sit
Thats the high lights, thanks for looking guysFor more pics here are the albums(updated almost weekly)Album 1
http://www.facebook.com/media/set/?set=a.10150173059582674.366687.553647673&type=3&l =f71739af05Album 2http://www.facebook.com/media/set/?set=a.10150553457932674.454651.553647673&type=3&l =37bf91fd76BMW Master Certified Tech - ///M Specialist & Diesel Specialist
- '02 BMW 530i/5 speed - 596WHP/558FT-LBS @ 22 PSI, E85 PTE6262
- '15 BMW X1 35i M Sport - Daily Driver
12-20-2017, 01:19 AM #2Member
- Jun 2017
- 1
- 0.1
02-28-2018, 09:32 AM #3
