Results 51 to 57 of 57
01-11-2018, 06:36 AM #51
01-11-2018, 06:38 AM #52
01-11-2018, 08:46 AM #53
Supporting Vendor
- Jun 2010
- St. Louis, MO USA
- 2,213
- 4,441.5
- 46 Post(s)
- 45
Here is the 108.xx MPH 1/8- will have to find the ~135mph slip later. This one wasn't his best 1/4 trap, but this was extremely impressive as most of these setups never seem to top 102-103mph in the 1/8th:
https://www.bimmerboost.com/showthre...8-4-in-the-1-8!
Unfortunately he only picked up 25mph on the back half on this pass, whereas a stronger "star aligned" backend performance this one would've netted a 137+mph trap.
Rob
EDIT: Here is another one with a 133.xx mph trap: https://www.bimmerboost.com/showthre...3-1-4-mile-run
Will have to text him to see if that was his best. Was pretty sure he had a 134.xx pass, may have not had the best ET however.
At the end of the day none of these cars are easily skating their way into the 133+mph range on any of these turbos offered today ("cast" or not). This particular car above made ~610rwhp IIRC on an apparently trustworthy dyno, which is another point as some make 700+rwhp on their respective dynos and then can barely eek out a 130+mph trap. IMHO these setups running 130+mph is likely beating all the hardware way too much, simply not worth stressing the components as such at that point. Possibly ok for an event but not realistic for the everyday/longterm.Last edited by Rob@RBTurbo; 01-11-2018 at 10:43 AM.
01-11-2018, 09:10 PM #54
01-11-2018, 09:10 PM #55
01-12-2018, 09:47 AM #56
Supporting Vendor
- Jun 2010
- St. Louis, MO USA
- 2,213
- 4,441.5
- 46 Post(s)
- 45
01-12-2018, 11:15 AM #57
- Jan 2015
- UK
- 1,113
- 1,621.9
- 45 Post(s)
- 17
Well it'd be interesting to flow test a GC turbo, mmp turbo and stock turbo.
The point about post turbine iats is very important. So is the back pressure.
I'm sure though if I try and flow more air through the same volume of tube (charge pipe) then the pressure will rise with the increased resistance. It definitely helps to have larger plumbing before and after the turbos etc. Within limits of course.
When talking trap speeds it very important to consider the fuel used, timing advance and weight of the car etc.Best:11.79@119mph on stock turbos.
11.74@129 on GCs.
FBO+Meth Port injection, GC Turbos, custom bucketless stage2, JB4, Trebila flash.
mask is now here!
