Results 1 to 3 of 3
    MHD moved N55 E-Series flash tuner to open beta MEVD 1726
    Still need to bench flash first though right @martial@mhd?
    Click here to enlarge Originally Posted by MHD
    MHD Flasher late e-series open beta announcement.After extensive closed beta testing - we are now ready for the open beta. Just update your MHD Flasher N55 App to the latest 1.20 version.
    Since the procedure on late e-series cars (built after 03/2012) is a little bit different, we would like to describe the steps needed:
    1. OBD Unlock via a one time bench flash. This can be done only by professional partners which have access to special tuner tools. Ask your local tuner and we can provide them all the information they need in order to get your ECU unlocked. You can also send your ECU to our partners - if you are able to uninstall it yourself.
    2. Install MHD like on early e-series N55 and N54 models. Just be careful with the "flash back to stock" operation. If you use this function than your ECU unlock is deleted and MHD can only be installed after the ECU is unlocked again. If you want stock power than use the "Stage 0" map.
    Send us a PM if you have questions!
    Feb 2013
    Germany
    69 Post(s)
    yes, just like F series. The late E series n55 DME security is actually identical to the F series.
    Click here to enlarge Originally Posted by martial@mhd Click here to enlarge
    Ah, ok I got it.
