Results 1 to 8 of 8
    Aug 2017
    Question bimmerboost backend flash and coding question
    I've already downloaded the Bimmerboost back end flash for my jb4 single
    turbo setup, and I've had to replace my DME/CAS module before hand. I've
    recently started weeding through my huge list of fault codes and my current
    code I'm on is 2FA4 (Incorrect data record) and from what I've read from the
    minimal information out there is that this code will appear if the power
    levels from the CAS/DME aren't matching. Before I take my car back to the
    shop i had some questions, are they going to be able to scan my car with the
    BB flash installed? And Will they be able to change the power levels on the CAS/DME with the flash?
    Let me move this into the right section for you.
    Also, let me fix your formatting to make this easier to read.
    Aug 2017
    Anyone please help
    Dec 2016
    Houston, Tx
    71 Post(s)
    Yes they can do what they need to do for in to work. It would assist if you put up a screen shot of your error memory from INPA if you have one...
    Dec 2014
    Georgia, Tbilisi
    7 Post(s)
    I can fix that problem
    Aug 2017
    Trevor Lee was my savior and his generosity in meticulously weeding through the unnatural amount of error codes on my BMW was by far the most impressive and kind act that I've seen from someone in so many years. I've spent hundreds of dollars and spent so much time on shops and individuals that have yielded no results or solutions to this error code nightmare that I've been facing since 2011 and within a few short days Trevor was able to go in and reprogram the issues that have held down my vehicle from running. Without him I'd still be stuck trying to figure out what to do and how to do it, so Trevor I thank you so much for your time and magical coding powers to vanquish this BMW monster I've been fighting for so many years.
    Jun 2014
    24 Post(s)
    I'm sure you sent him lots of beer money, right?
    Dec 2016
    Houston, Tx
    71 Post(s)
    @Tgross88 thank you for the kind words. We still have more to code and program on your car, just let me know when you finish installing everything and we can tackle it for a hopefully last time! :-)
