Results 1 to 11 of 11
Thread: Ice tank added to ESS 650 kit.
04-05-2017, 08:42 PM #1
- Mar 2017
- 97
- 92.1
- 3 Post(s)
I finally got around to adding the 5g ice tank to the system. I also reversed the flow of the system and added a Rule bilge. The ESS pump now pushes to the tank, the bilge pushes to the intercooler and then on to the heat exchanger back to the pump. IAT'S seem to be 100 driving around in everyday driving based off OBDII monitoring. The flow of the Rule bilge destroys the ESS stock pump. Here are some pics and a video of the setup.
https://photos.google.com/photo/AF1Q...NBEcGz2W4jHnSR
https://photos.google.com/photo/AF1Q...kfrZBxWqHqm_oK
https://photos.google.com/photo/AF1Q...JoO4YH8xirBDMS
https://photos.google.com/photo/AF1Q...am2uA6rAzA-aFF
https://photos.google.com/photo/AF1Q...JhEuZmk5DhWDJH
https://photos.google.com/photo/AF1Q...hCL7lTsigBT4sM
https://photos.google.com/photo/AF1Q...X2klJaEmgcceYV
https://photos.google.com/photo/AF1Q...lEXCVOP8I6vEuS
https://photos.google.com/photo/AF1Q...z1Gr4_7Zq7H7xe
https://photos.google.com/photo/AF1Q...5NaVs0Dr4rLaLW
Got FLOW!?
04-06-2017, 02:38 PM #2
Hey, your photos aren't showing @SPR12... looks like bad links?
04-06-2017, 02:45 PM #3
- Mar 2017
- 97
- 92.1
- 3 Post(s)
Hmm. I posted links from google photos. I'll see if I can upload without the resize battles.
04-06-2017, 03:03 PM #4
- Mar 2017
- 97
- 92.1
- 3 Post(s)
Here are the pics again manually uploaded. It wouldn't let me upload an MP4 of the ESS v. Bilge flow.
04-06-2017, 03:24 PM #5
^ There you go, that worked.
Google won't let you hotlink how you tried to do it. IMGUR.com is a better image host in those instances.BRAND NEW IN BOX 991.2 standard/non-pse SPW cat bypass pipe for sale - $899 shipped
04-07-2017, 01:41 PM #6
- Mar 2017
- 97
- 92.1
- 3 Post(s)
Thanks! Suggestion on posting the video of the smallest Rule destroying the stock ESS pump?
04-07-2017, 01:44 PM #7
- Mar 2017
- 97
- 92.1
- 3 Post(s)
Never mind. I just uploaded to Youtube. Here it is. I'm really surprised the tiniest Rule grossly outflows the ESS Bosch stock pump. Also, the flow didn't really change with the Bosch on or off with the Rule.
I should also add that the 5g tank with the long lines and intercooler and HE capacities came out at about 7g.
https://www.youtube.com/watch?v=W85G...ature=youtu.beLast edited by SPR12; 04-07-2017 at 01:55 PM.
04-07-2017, 04:12 PM #8
04-07-2017, 06:41 PM #9
- Mar 2017
- 97
- 92.1
- 3 Post(s)
04-13-2017, 01:03 AM #10
- Apr 2017
- 4.2
Where did you source your kit from? Was the install easy?
04-13-2017, 08:10 PM #11
- Mar 2017
- 97
- 92.1
- 3 Post(s)
I bought it from the prior owner of my 650 kit who had it made by Malik of MRF. We improved it by running the bilge and reversing the stock ESS flow and setup. It took about a day in the garage. You have to drop the entire exhaust and remove the tray in the trunk to drill the holes but it wasn't horrible.
