Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 99
    May 2016
    44 Post(s)
    It was a blast, awesome seeing Payam again (and yes, he did make me a burger and I did eat it) and finally meeting Terry -a good time was had by all. I'm a little bummed that "all" we did was run 170.x but a record is a record, and 170 is screaming. We had such a good day. Click here to enlarge
    Turbos are maxed mass flow wise, and shaft speeds have to be "higher than recommended" but it goes to show what you can do when a carefully thought out combination of hardware and tune is chosen. To the guys on FB wondering about warranty's and things like that... 847 is a kill tune with those 19T's weeping silently to themselves at the beating we gave them; keep in mind how highly optimized everything was to get there. I am excited to see the Stage 3 on this motor.
    Again, was a blast. Great trip.
  2. #27
    Apr 2013
    Flexing in the mirror
    26 Post(s)
    Click here to enlarge Originally Posted by Chris@VargasTurboTech Click here to enlarge
    That...sounds like a double entendre
    Daily - '11 F02, 22" HR springs+links Click here to enlarge N54
  3. #28
    Apr 2015
    27 Post(s)
    Why aren't you releasing CG+ ? Steps on your stage 3 territory ? A bit like why bmw didn't put the S55 in the M2 ?
  4. #29
    May 2012
    Jacksonville, FL
    95 Post(s)
    Click here to enlarge Originally Posted by Traf Click here to enlarge
    Did you read what Tony said?
    2015 F10 M5 \ Alpinweiss
    Aug 2012
    Hayward, CA
    349 Post(s)
    ? Um not following. So you read the part about not releasing them, but not the part directly after it that said increased lag by 500-600 rpm, but made no more power? I mean if you want a set of GC's that spool slower, and make no more power we can do that for you? I mean but if that is what you are looking for, just buy any number of N54 single turbo kits already on the market..Click here to enlargeClick here to enlarge
  6. #31
    May 2016
    44 Post(s)
    Click here to enlarge Originally Posted by R.G. Click here to enlarge
    I know. It's painful but it needed to be said. I try not to think about it.
    Not about stepping on territory, it's about practicality of the design.
  7. #32
    May 2016
    44 Post(s)
    Click here to enlarge Originally Posted by Tony@VargasTurboTech Click here to enlarge
    Those are the GU's. Game Unchangers.
  8. #33
    Apr 2015
    27 Post(s)
    CG+ would only have had a larger compressor ? Then i got it
  9. #34
    @Payam@BMS yet you don't post your burgers in the burger thread or offer to make me any? Shame, SHAME!
  10. #35
    Jun 2015
    22 Post(s)
    Massive power at low boost. This is more like it. I think you're going to be looking at 900 soon enough. Massive shout you mate.
  11. #36
    Encino,CA
    311 Post(s)
    I want that head!!! Tony got any graphs before the headwork and same psi?? Its like 100whp gain from same boost is what it looks like.
  12. #37
    May 2014
    34 Post(s)
    You folks should also keep in mind that a significant part of the gains probably came from the bellmouth inlets which I suspect were without filters, with just a mesh screen for race use only. Tony can chime in and confirm/deny this...
  13. #38
    Aug 2012
    Hayward, CA
    349 Post(s)
    Click here to enlarge Originally Posted by hydra Click here to enlarge
    Actually none of the gains come from those. I have been running those for a while, when I swapped them out and retested on the same motor same turbos. Saw no gains. I just left them on, as its a hassle to change them
  14. #39
    Aug 2014
    Orlando
    4 Post(s)
    Its all in the head. Usually it takes about 35psi to make that kind of power on a stock head. Boost is nothing more the a measure of restriction. When you increase the VE you need less boost to make the same amount of power. Its the reason why you see those Honda motors make so much power on low boost. I only wish they got the cams to work. Might have been able to make that kind of power on @21psi lol
    Left hand on the steering wheel right hand on that RTD Shifter
    -2Chainz
    07 6spd TI ag E92
    Mods
    Boostbox, e85, RTD shifter, and a 6766
    #BuiltByHaborFreight
    Instagram Oss_Cah5
  15. #40
    Aug 2012
    Hayward, CA
    349 Post(s)
    I mean we made 776 on 21 psi stock cams. We will swap the cams back in, and make 850 at the same boost.... Hahahaha
  16. #41
    Aug 2014
    Orlando
    4 Post(s)
    I mean we made 776 on 21 psi... Hahahaha
    but 850 @21psi would have been beast mode lol
    -2Chainz
    07 6spd TI ag E92
    Mods
    Instagram Oss_Cah5
  17. #42
    Jun 2015
    Culver City, CA
    29 Post(s)
    so awesome. I can't imagine what a riot it must be trying to put that much torque down so early on. solid work!
  18. #43
    May 2016
    44 Post(s)
    4 out of 4 members liked this post. Yes Reputation No
    Tony sort of stole my thunder, the bastard, but here is my write-up.
    Just got back from a great trip to SHIFT S3CTOR in CA with the VTT gang. We had a hectic couple of weeks prior to the event with an engine failure on our hands, so last minute swapping in a new motor, troubleshooting, and finishing tuning with the current config kept us very busy!
    The day before the event we got the motor in, running, and put her on the dyno for some tuning before we left for the event on Saturday. This is our closed deck 9.5:1 compression motor, with fully built head, larger intake valves, Manley springs, TI retainers, etc. originally from ABR (the Punisher motor for those who were around back then). We had some issues with the motor when we received it, had those issues addressed via a local engine builder, and it made some serious power. Throw in a few sneaky but effective mods -like our velocity stacks- and we had a motor that ran like a top and just begged for more.
    With a little help by none other than VTT's favorite N54 tuning guru Justin (V8Bait) the car laid down a more than impressive 847WHP/726WTQ with an astounding 601WTQ by 3000 RPM held to redline, and 700WTQ held flat from 3500-6500RPM. This power, and tq was made with ONLY 25.4 psi at peak power RPM. We also made 776WHP at 21.62 psi boost at peak power! This is a perfect example of why we continually tell people boost is simply measurement of restriction; NOTHING else. Remove restriction, and power stays the same or goes up at the SAME boost pressure.
    We took the car out to Shift Sector on 2/25/17 with 6 tunes; low, medium, and high boost maps, each with a low and high timing version. Our first pass was with the low boost, low timing map and we ran 162.3x MPH. Our second pass was medium boost, low timing, and we ran 166.29 MPH with traction issues and missing 5th gear. We re-ran, nailed it and set a new N54 1/2 mile record of 170.49 MPH using the medium boost/low timing map (776WHP map with 3 degrees less timing). We're very pleased with this; 170 in the 1/2 -especially at a Shift Sector event (more strict)- is screaming.
    170.49 MPH On-Car Video Pass:
    After the 170.49 MPH pass we were ready to have some real fun. We tried to turn up the boost to the high boost/high timing map (850 WHP map), however something happened to the diff or alignment and the car was dangerously uncontrollable. After a few attempts we trailered the car and looked under -one of the alignment bolts for the rear suspension appeared to had moved significantly. Most likely that was our culprit, but it's also possible we cooked the M3 rear differential -we'll have to open it all up and look when we get some time. Even with the car near uncontrollable we managed a 168 MPH run. We belive the car would have been close to 175MPH with the 850WHP map in it, but "cudda" and "did" are two different things. We'll take the 170.49 MPH. Click here to enlarge
    Engine Specs:
    -Closed deck 9.5:1 compression N54 short block,
    -Forged Rods
    -Forged Pistons
    -Fully Ported head with oversized intake valves, Manley springs, Ti Retainer
    -Stock cams (wait until we get the big cams running!)
    -VTT GC turbochargers
    -Custom VTT inlets with 6" velocity stacks
    -Custom PCV system
    -Custom 4" exhaust
    -VTT Double Barrel HPFP system
    -EOS V2 intake manifold with top PI (we DID use the PI at very low duty cycle on this setup)
    -AD-E 1200WHP FMIC
    -Custom triple Walbro LPFP set up with Radium Surge tank
    -MHD tuner tuned by V8BAIT
    -100% E85
    Dynos/Graphs:
    847WHP graph
    AEM Log Grab (backpressure is off/not recording)
    776WHP graph
    Logs:
    AEM 847 Log
    http://www.datazap.me/u/vargasturbot...-5&zoom=96-420
    MHD 847 Log
    http://www.datazap.me/u/vargasturbot...-23&zoom=39-90
    AEM 776 Log
    http://www.datazap.me/u/vargasturbot...5&zoom=118-484
    We had an awesome time, and I met several of you again -always fun to put faces to names. Terry Burger of BMS tuning was there, along with the BMS crew -always a good time (and they made hamburgers... which were delicious). After the drive home we went out to celebrate and enjoyed some (many?) adult beverages.
    So what's next? Well, right now the plan is to put the stage 3's on the closed deck motor and make big power. We do have to figure out what's wrong with the suspension/differential, but hopefully that's not a complicated problem to solve.
    Q&A:
    Q: Can I get 847 whp from GC's?
    A: Not recommended. We optimized everything we could to make this much power, and the shaft speeds are very high. When I say "everything" I mean we even welded on a v-band clamp to the throttle to stop any chance of boost leaks at the charge pipe sort of attention to detail. Right now if you want 850 WHP and some longevity you're either looking at our Stage 3 setup or one of the many big single offerings out there (and everything else... including a built motor). Simply put the turbos were absolutely maxed out; 100% WGDC. Why? Oh come on... because racecar.
    Q: Why not run the GC+'s?
    A: We're canning the GC+ concept; our testing shows that particular turbine is maxed with the compressor wheels we have, and a larger turbine would require a different casting which likely would not fit stock location. Our larger compressor testing showed the same power but worse spool; not a good trade!
    Q: Are ball bearings still something you're looking at?
    A: Yes, but we had some setbacks that showed us we need to do quite a bit more testing before they're ready to be released (if ever). I'll post more about this as time and testing permits -we know there is an interest!
    Q: I thought you guys said the double barrel direct injection system was sufficient for 800 whp?
    A: It is, and even after 800 whp the system pressure is sufficient, however we're running out of injector and time to inject at these power levels. We turned on Port Injection for the 850 whp runs for safety and we needed more fuel than we could do purely with DI. It was close, but you don't take chances at these power levels. It is possible one of the MHD wizards could unlock some tables that help us but that's for the wizards to determine and not so much for me to guess about.
    Q: Do the velocity stacks help that much?
    A: They do help, but everything has to be in place for the advantage to show. At these power levels everything matters.
    Q: We thought you guys said the ported head didn't really make much of a difference?
    A: This ported head has larger intake valves, and it made a big difference. With a bigger cam we expect even better results. This is good news for the platform as a whole -especially big power chasers.
    Q: What's your favorite color?
    A: Blue
  19. #44
    Brisbane, Australia
    73 Post(s)
    This motor have a very small stroke. It does not even account for .1 increase in displacement. As for the head, I should have head our machine shop flow it, but didn't bother. As for GC+, we won't be releasing them. Another thing I have preached for years. Turbine size much much more important than compressor size. I put a much larger compressor wheel on the car with those big TD04 compressor housings some of the other guys use. Car picked up 500-600RPM of awesome lag, and no power. When the turbine is maxed, its maxed, doesn't matter how much compressor or compressor housing you throw at it...Click here to enlarge
    Aww was so excited to see GC+ wreck everything, but no power on the table with them at all?
    You think GC current wheel setup is your final word on that Style of turbo upgrade for the n54?
    GC BB still on the way?
    Edit: aaaand Chris's above post answered just about everything. Dammit! �� A touch disappointing really but oh well
    boop
  20. #45
    Dec 2009
    16 Post(s)
    Finally, an answer to his favorite color.
  21. #46
    Dec 2015
    California
    Figure out the schrick cams, turn the boost up to 30 and crush that n54 dyno record !
    POV is the best angle
  22. #47
    May 2014
    Houston
    13 Post(s)
    good work guys!
  23. #48
    Jun 2013
    North Houston
    166 Post(s)
    3 out of 3 members liked this post. Yes Reputation No
    Good job pushing the envelope.
  24. #49
    May 2012
    That might just be the fattest torque curve I've ever seen. Over 300 rwhp by 3k rpms and doesn't fall on its face up top!
  25. #50
    Excellent write up Chris!
