Page 1 of 2 12 LastLast
Results 1 to 25 of 30
    Jun 2016
    5 Post(s)
    Question Lambda replaced, still dodgy AFR readings on N54 335i
    Hi guys
    my car was throwing up errors on bank 1 sensor 1 and bank 1 sensor 2 lambda sensors. After much hassle I managed to use a flexible wrench with a flexible extension bar to an O2 socket to remove the sensor from the top of the engine bay and replace it, definitely bank 1 - as it was nearest to the front of the car, black lead, however, after replacement, and resetting the service light, it promptly came back and logging in MHD shows the same odd readings from this lambda sensor-
    http://datazap.me/u/threetirtyfive/3...g=0&data=17-23
    now the guy who sold me the car said that the modified program it was running was causing the lambda sensors in bank 1 to report faulty, BS I thought so I set about replacing them. Admittedly I only replaced b1s1 as I was more concerned with the AFR than the function of the cat, but perhaps his story wasn't wrong and it's indeed the program, anyone ever heard of this before?
    I had the fuelling checked whilst it was on dyno and it was fine, not too lean or rich, so I guess it's all being controlled off bank 2 right now. Also no idling issues, no hesitation, car makes good power.
    Jan 2015
    14 Post(s)
    Bank 1 wideband is not working. Did you damage the sensor, when trying to install it? You can break the heating element inside of the sensor, very easily..
    Jun 2016
    5 Post(s)
    I seriously doubt I damaged it as I inserted it (and tightened initially) by hand. Are there any other causes- such as wiring fault to ECU / modified program running in ECU?
    Nov 2012
    Florida
    33 Post(s)
    Another thing to check is the condition of the secondaries. I noticed before I disabled my secondaries that they affected the AFR_1 and AFR_2 signal in a similar manner to how you describe (and I was getting a failure message once in a while for one of my secondaries). Once I disabled them, the problem went away (also replaced both primaries as they were dead).
    08 E90, just boltons
    Jun 2016
    5 Post(s)
    Click here to enlarge Originally Posted by Sered Click here to enlarge
    Great OK thanks. I do have a new oem bank 1 sensor 2 so will try that and see if it affects the afr sensor. Odd thing is there is some signal from bank 1 sensor 1 as shown by the mhd log but it hovers around 15.
    Jan 2015
    14 Post(s)
    Click here to enlarge Originally Posted by threetirtyfive Click here to enlarge
    because it's dead. Mine showed the same AFR as yours, when mine went out.
    Jun 2016
    5 Post(s)
    @jt0407 - I guess I should swap the bank 2 sensor 1 connector with bank 1 sensor 1 - this will tell me for definite if it's the sensor or wiring, and do anther log - can't see it doing any harm? As I say it's a brand new sensor I just fitted, readings are almost identical to the old presumably broken one.
    Jan 2015
    14 Post(s)
    What codes are you getting?
    Jun 2016
    5 Post(s)
    I have p0030 and p0036.
    Jan 2015
    14 Post(s)
    Get MHD , so you can properly read codes.
    Jun 2016
    5 Post(s)
    I have it already, on that it gives 2c9c,lambda probe heating in front of cat input signal, 2c9e after cat, 2ef7 characteristic diagram thermostat controls
    Jan 2015
    14 Post(s)
    2c9c is a bad 02 and the heating element is damaged. I had the same code.
    Jun 2016
    5 Post(s)
    I just replaced bank 1 sensor 2 and STILL have the faulty heater fault on both. What other causes are there, where are the wires if I open the dme box and look for damage?
    Jun 2016
    5 Post(s)
    Just to add, I did reset the check light but it came back after ten min
    Jan 2015
    14 Post(s)
    May need to check your DME board, for any fried resistors or capacitors. It's a long shot,though.
    Jun 2016
    5 Post(s)
    I only want to lift the case from the box with the dme in not actually dismantle the dme itself looking for component damage. Do you know which wires enter the box that relate to the o2 sensors?
    Sep 2014
    I am now looking for resistor damage in the dme too.
    The heater elements are fused. Have you checked the 30A fuses in the glove box?
    Jun 2016
    5 Post(s)
    I don't know which fuse it is, the photo in bimmer boost in another post show a different fuse box. My e92 is different, not sure which fuse can you tell me? Are there different fuses for bank 1 and bank 2? Because bank 2 work fine.
    Sep 2014
    There should be a fuse map in your glovebox. The ECU has about 10 fuses. Its one the 30A ones. I believe the 2 banks are fused separately.
    WM
    Jun 2016
    5 Post(s)
    I checked the under hood (bonnet) fuses last night, all passed continuity test so none are blown from the black cube fuse holder in the DME box, where I understand on the coupe the fuses are. Still no closer to solving the issue unfortunately. Is it possible to test -from- the connector in the car loom that the signals are correct for the 02 sensor? (rather than testing the 02 sensor itself)
    Jan 2013
    Savannah GA
    108 Post(s)
    -Your in OL fueling so yes the car will run fine its programmed to do so.
    -I would remove both connectors on the DME and make sure none of the pins are pushed. Sometimes after installing/removing a piggyback the connector wont mate correctly and it pushes the pin back just enough to not get a good connection.
    -Your e92 has a single fuse for all 4 heaters. I forgot which 1 it was but if it was blown all 4 heater faults would be present.
    -in INPA go to adaptations then go to adaptations 1 and clear anything that says lambda, or NOX. Then make sure you hit <shift> F6 (or7) for learn variance. Back out of that menu go to adaptations 2 then select Clear ALL. Then do a DME reset. Easiest way is while your in INPA go to sleep mode then DME reset. Shut the ign off then start the car
    -All else fails buy another sensor. If the heater isnt working its most likely done anyways. Damage to the outside of the housing can cause it to short and fail internally.
    Feb 2012
    Boston, Ma
    32 Post(s)
    Click here to enlarge Originally Posted by Chris@CKI Click here to enlarge
    Just to clarify do you mean put the computer into sleep mode, like shut the lid, or is there a sleep mode option in INPA I've never seen before for the DME??
    2010 AW/BLK 135i VM 6465 Single Turbo w/ OCDworks Modified T51r Housing, JB4 + MHD, VRSF CP & Tial, Big Tom, Fuel-It PI + Stage 3 + Return + Ethanol Sensor, BMW PE, MFactory LSD, Spec 3+ & MFactory SMFW, RB External PCV, ADV sensors, and many more....
    RIP Click here to enlarge2008 AW/BL 135i
    Jan 2013
    Savannah GA
    108 Post(s)
    Click here to enlarge Originally Posted by BostonBeemah Click here to enlarge
    <shift> F10 is the DME sleep mode option. You'll see it on the main page for the N54 sub menu. once you click that itll have choices for reset all, reset DME only, etc. All you need is Reset DME only
  24. #24
    Feb 2012
    Boston, Ma
    32 Post(s)
    No way, all this time have never seen that. Hah must be half blind or something lol thanks!
    Jun 2016
    5 Post(s)
    This is great advice thanks guys, lots more to try out, I haven't used INPA other than successfully getting it to connect so far. (Used NCS expert for coding, that's about it).
