Results 1 to 14 of 14
01-09-2016, 05:12 AM #1
IJE0S and IF80S E40 beta - 18psi, aggressive timing
Reuploading this due to posting the wrong file last time and this time am including an IA80S version as well. These are patched with Shiv\'s e40 XDF\'s. intended for an e40 mix which equates to roughly 50/50 blend of pump 93 and e85.
Peak boost around 18psi and pretty aggressive timing curve . I would make a few tweaks to the throttle which i will probably get around to in a couple weeks but for now this isn\'t a bad starting point. Recommended for FBO but can be used without. I have been running on stock downpipes. YMMV
02-12-2016, 11:50 PM #2
02-12-2016, 11:50 PM #3
02-12-2016, 11:50 PM #4
02-12-2016, 11:51 PM #5
02-25-2016, 06:43 PM #6
02-25-2016, 09:27 PM #7
02-26-2016, 12:02 AM #8
02-26-2016, 08:39 AM #9
- Feb 2013
- Germany
- 185
- 536.1
- 69 Post(s)
02-26-2016, 10:16 AM #10
- 2,495
- 1,970.5
- 204 Post(s)
I would honestly take these files down, they only work with Shiv's old garbage XDF's to apply a "patch" to your bin file. They are not compatible with the current XDF's
02-26-2016, 04:15 PM #11
I was wondering how random garbage bins would be policed. I hope people don't start loading up some flat timing 15.5d maps to melt engines.
2010|335i|LMB|E92|6MT|MSport|Logic7|335is Clutch|AE Performance|BMS|Inline Walbro|VRSF 7"|Inlets|-sold
1992|Pontiac Firebird|Mild 355ci|T56|-sold
2001|Chevrolet Camaro| T56 LS1| Bolt-ons| -Sold
-I will look on your treasures, gypsy. Is this understood?-
02-26-2016, 04:32 PM #12
- Dec 2012
- Florida
- 1,613
- 3,270.5
- 125 Post(s)
- 33
This can be arranged...
The shiv stuff sucks but is an ok starting point for people jumping into things on their own I'd say, or for people in the bbflash or oft only niche. Martial is right though if people want to flash these with mhd they should dig into them as some things have changed since they came out for the better.
02-26-2016, 07:24 PM #13
- 294
- 716.0
Yeah, this can be pulled. It was one of my first attempts at messing around with things and things have come a long way in a short time.
02-28-2016, 09:44 AM #14
There's no need to pull it as it's a jumping off point for people who want to do stuff themselves. Plus the file comments and the thread comments are synced so they can read and judge for themselves.
