Results 1 to 4 of 4
    Mar 2014
    37 Post(s)
    Another Alpina transmission flash to try
    Hi guys,
    I've found another Alpina B3 flash for somebody to try. I've got a lot of stuff on the go at the moment and I sold the laptop that worked with DCAN cables (My Mac's USB3 ports with whatever "power saving" features they use these days means a working DCAN cable drops in and out). The ZB number is 100% an earlier Alpina B3 flash. I have attached a screenshot of the latest kmm_ATSH.txt file showing the list of ZB numbers for the Alpina B3 models up to 2010 (You'll notice that 7603537 is the latest which is the most recently discovered Alpina flash before now).
    I have attached a zip file which contains a GKE215 folder with the files needed for this flash from SP Daten v32. Temporarily rename your GKE215 folder in C:\EC-APPS\NFS\DATA and put this one in its place. then flash the following ZB number using WinKFP:
    7592076
    Obviously, there's a good chance that it will be much the same as the others we've already tried but IMAGINE if it had significantly higher D mode shift points! You just never know till you try.
    I look forward to hearing some feedback on this one soon.
    Cheers,
    Brad
    https://drive.google.com/open?id=0Bw...nRmajVES1NKbnM
    https://drive.google.com/open?id=0Bw...nZ4YWhmZU9YX1k
    AZ
    43 Post(s)
    So wait... Is this a new or older file?
    Mar 2014
    37 Post(s)
    Older
    Mar 2015
    22 Post(s)
    I have heard that 7601494 is a good one too. I might switch to it. I'm on 7603537 right now and the D mode is getting annoying.
