Results 1 to 2 of 2
10-30-2015, 09:09 AM #1Supporting Vendor
- Jan 2010
- 1,403
- 674.6
- 41 Post(s)
Vargas (VTT) Stage 1/2 and 2+ Hybrid Turbos - FREE SHIPPING PROMO!! www.n54tuning.com
VTT N54 Stage 1 / 2 Hybrid Turbos (Fits All N54 Models LHD & RHD)
ORDER LINK
http://www.n54tuning.com/vtt-n54-sta...s-lhd-rhd.html
N54 Stage 2+ Hybrid (Fits All N54 Models LHD &RHD)
ORDER LINK
http://www.n54tuning.com/n54-stage-2...s-lhd-rhd.html
Stage 1 = WHP Level supported (with proper fuel, upgrades, and tuning) Stock - 470WHP
Stage 2 = WHP Level supported (with proper fuel, upgrades, and tuning) Stock - 525WHP
Stage 1 Hybrid upgrade: We start with a freshly rebuilt stock unit using all OEM spec internals, carefully machine the OEM compressor and bearing housings, to accept a TD04 14T compressor wheel. For the turbine side we clip the stock wheel to 7 degrees, we also remove the stock waste gate arm and flapper valve prone to rattling and boost loss issues and upgrade it with a 100% stainless steel piece to eliminate all of these known problems. These units also come with brand new factory OEM waste gate actuators. We chose the 14T wheel for the stage 1's because it is a much better match to the stock turbine than the 15T compressor wheel even though it means we have to set up differently to machine the different stages. Stage 1 is the perfect cost effective alternative to stock OEM replacement turbochargers.
TD04 upgraded thrust option: Add a performance TD04 upgraded thrust to your stage 1 upgrade to extend the life of the turbochargers. The stock thrust system has shown to be prone to failure and upgraded thrust parts were created to remedy this. The upgraded thrust option consists of an Upgraded thrust bearing, and a 30% increase in surface area on all complimenting thrust pieces. +$200 please select from the drop down.
VTT Billet compressor wheel option: Step up with your stage 1 upgrade, and add the amazing Billet VTT Compressor wheel option. These are fully forged billet wheels, utilizing the ultra-efficient 6x6 blade wheel design as well as extended tip technology to increase airflow a solid 20% over the cast 14T wheels. +$300 please select from the drop down
VTT Shotgun HPFP upgrade bundle: For those of you wanting to really step your N54 game up, the VTT shotgun HPFP upgrade will allow you to run 100% E85 with no HPFP pressure loss enabling your to make maximum power and do so while filling up at the pump. The single barrel kit will support 500-500WHP while running 100% E85 and will provide plenty of fuel for a stage 1 set up
Price does not include core charge of $300 for 335LHD models, or $600 for 135, 535, 1M, all RHD models, Z4. Core charge will be refunded upon receipt of cores in accordance with our core return policy.
(every set of 335LHD turbos comes with our rear intake bracket to keep that poorly designed rear tube in place.)
We also always recommend upgrading your PCV valve at the time of turbo upgrade or replacement, as the stock valve can be worn. This means it can stop functioning to its full potential, causing oiling issues with your BMW. This upgraded valve not only replaces the worn stock valve it is also much stronger and will help eliminate any future PCV issues.
Every set of VTT turbochargers comes with a 1 year limited warranty.
Stage2+
Stage2+ = WHP Level supported (with proper fuel, upgrades, and tuning) Stock-700WHP
We are proud to introduce the latest in our line of N54 turbocharger products the VTT Stage 2+ hybrid turbochargers. We take our already robust stage 2 design utilizing all its ground breaking features, and machine the compressor housing to take the highest flowing wheels in the TD04 family to provide the ultimate in N54 stock frame power potential. There is no another stock frame turbo option on the market that can match the power or reliability of our stage 2+ turbos!
TD04 upgraded thrust: Every set of stage 2+ turbos comes with a performance TD04 upgraded thrust to extend the life of the turbochargers. The stock thrust system has shown to be prone to failure and upgraded thrust parts were created to remedy this. The upgraded thrust option consists of an Upgraded thrust bearing, and a 30% increase in surface area on all complimenting thrust pieces.
VTT Billet compressor wheel choice: Take your pick of either an amazing 19T or 20T billet compressor wheel. These are fully forged billet wheels, utilizing the ultra-efficient 6x6 wheel design as well as extended tip technology to increase airflow into the 600+ WHP range. This also helps the turbos work less hard to make the same power, meaning you can make big power and not sacrifice reliability. Price includes 19T, +$100 for 20T. Please select from the drop down belowALL ER PRODUCTS ON SALE @ 10% OFF -
www.n54tuning.com - Email; [email protected]
NEW PERFORMANCE LINE N54 DOWNPIPES & M3/M4 & F30 ER DOWNPIPES NOW IN STOCK - ER N54 CHARPE PIPE SPECIALS - NEW JB4 G5 ISO for N54 and F30 N55 ON SALE - NEW S55 M3/M4 JB4 NOW SHIPPING
01-06-2016, 11:36 AM #2Supporting Vendor
- Jan 2010
- 1,403
- 674.6
- 41 Post(s)
Bump for a Great Deal @ www.n54tuning.com
and as always the LOWEST price Guaranteed!!
MikeALL ER PRODUCTS ON SALE @ 10% OFF -
