Results 1 to 14 of 14
06-20-2015, 03:58 PM #1Member
- Feb 2015
- 42
- 95.7
- 31 Post(s)
Dyno results for FBO 535i, JB4 Map 7, PI, 100% E85
Here are the results from some dyno pulls I did last week.
06-20-2015, 04:04 PM #2Member
- May 2012
- 288
- 411.6
- 21 Post(s)
06-20-2015, 04:09 PM #3Member
- Feb 2015
- 42
- 95.7
- 31 Post(s)
JB4 on map 7, BMS DCI, BMS OCC, BMS OCV, Turbosmart DVs, Dr. Euro DPs, 100% E85, Fuel-It Stage 2 LPFP, BMS Port Injection, BMS E85 MHD Flash, M-Sport Trans Flash, ER FMIC and CP, KW V3 ,MFactory LSD.
Numbers are pretty low for this setup. Terry had indicated it may possibly be wastegate leak related as I am evidently not hitting my boost targets.2010 535i 6AT| JB4 G5 ISO| BMS DCI | Pure Stage 2 | RB Inlets | VTT Outlet | BMS OCC | BMS OCV | Turbosmart DVs | Dr. Euro DPs | 100% E85 | Fuel-It Stage 3 LPFP | BMS Port Injection | BMS E85 MHD Flash | M-Sport Trans Flash | ER FMIC and CP | KW V3 | MFactory LSD
06-20-2015, 05:08 PM #4Supporting Vendor
Yes just needs more boost. After you do the inlets if boost doesn't get up to target then we'll do the vacuum line test to ensure you're pulling 22" as you should be at full PWM. Another degree or two of advance won't hurt either.
06-20-2015, 05:26 PM #5Member
- Feb 2015
- 42
- 95.7
- 31 Post(s)
Now that the new RBs are out of the bag, I feel like I should skip the inlets for OEMs and go straight for the upgraded turbo kit that has optimized inlets and outlets included. What would you do if you were me?
06-20-2015, 05:42 PM #6Member
- May 2012
- 288
- 411.6
- 21 Post(s)
06-21-2015, 02:05 PM #7Member
- Jul 2010
- 72
- 79.2
I am suprised. I expected more whp and tq. Or is this how much our 535i are putting down
dont 135's and 335i's put down that much or more power with less mods?
and if u have the money u want to waste, then get the upgraded turbos!'08 535i - Sport - Comfort Seats - Sport Trans - Navi - JB4 G5 ISO - Vishnu Intake -
'07 Suzuki GSXR750 - Akrapovic Titanium Exhaust - Mirror Delete - Tinted Double Bubble Windscreen
06-21-2015, 06:32 PM #82008 E90 335XI A/T. Mr.5 intake, gutted cats, self tuned, meth injection(625ml nozzle), 93 octane e10 fuel.
Best 1/4: 11.5@122
Best 1/8: [email protected] (1/8th mile only run)
06-21-2015, 09:02 PM #9Supporting Vendor
06-22-2015, 09:11 AM #10Guest Vendor
- Mar 2013
- 344
- 357.9
- 15 Post(s)
http://www.n54tech.com/forums/showthread.php?t=30448
442 whp and 466wtq on a FBO 531i running E70 with meth , with conservative AFRs.
06-22-2015, 09:21 AM #11Guest Vendor
- Mar 2013
- 344
- 357.9
- 15 Post(s)
06-22-2015, 04:47 PM #12Member
- Feb 2015
- 42
- 95.7
- 31 Post(s)
Those are the more conservative SAE readings as well. My SAE readings were as follows: 410hp / 436tq, 415hp / 442tq, & 410hp / 449tq. Also, I am on the BMS E85 backend flash. I feel like a lot of things need to be optimized for my unique setup. Maybe I am supplying too much fuel when PI kicks in and the turbos can't provide enough air for the demands?
06-22-2015, 06:14 PM #13
OP, if you insert your image inline it can then be clicked and expanded:
Stupid garbage VB attachment system.
06-22-2015, 06:17 PM #14Member
- Feb 2015
- 42
- 95.7
- 31 Post(s)
Oh nice, yeah it wouldn't let me attach the image at all because I didn't have enough rep. But then somehow it was attached anyway. I'll get it right next time.
