Results 1 to 7 of 7
07-11-2014, 07:54 AM #1
EFS Combust - a new fuel additive ???
Has anybody tried this?
Www.efscombust.com
Composition is about 54% ethanol, 36% benzyl alcohol, and the balance a mixture of acetophenone, ethers and a carboxylic acid. Apparently 1 oz in 15 gallons of gas increases power and torque 5%. I found the patent if anybody is interested.2008 E90 335xi AT 62.5K MILES
MHD CUSTOM 93 MAP, N20 TMAP, FUEL-IT STG 2 LPFP, xHP Stage 3, cPE CHARGE PIPE, HELIX IC, FORGE DV, BMS DCI, BMS T-STAT DELETE, BMS OCC, RB PCV, KW-V1 COILOVERS, APEX ARC-8, 235/265 MICHELIN PSS, ALPINA B3 TCU, SCOOPS
TBI - SOLD
Next: Precision Raceworks Ignition System
07-11-2014, 12:26 PM #2
Sure it does.
1 fl. oz. = 1/128th of a gallon. So they're claiming a 1:1920 ratio of their product to unknown gasoline will increase power 5% over straight unknown gasoline?
Think I'll be sticking with an E60 blend and spending my money elsewhere. You would be wise to do the same (at least with the latter).
07-11-2014, 01:03 PM #3
I agree there is no octane effect. If there is any effect then it ***may*** have something to do with modifying the properties of the injected fuel mist. Small amounts of stuff can have a big effect on surface properties (like a drop of soap in a pot of greasy dishwater). Just for kicks I ordered a small bottle to test. I'll report back...
TBI - SOLD
07-12-2014, 05:29 PM #4
Moved to general automotive
03-20-2015, 02:27 PM #5
- Mar 2015
- 10
- 7.0
What was your experience with the product? Some Porsche guys in my area all use it on the track.
03-20-2015, 02:42 PM #6
03-20-2015, 10:03 PM #7
I still need to try it. The bottle has been sitting in my garage.
TBI - SOLD
Welcome...
