Results 1 to 6 of 6
    Nov 2014
    Please help! ECU is bricked =[
    I got a full read of my original ECU but that took 7 hours! I went ahead and tried the flash and got all the way to step 2 and 1 second left. I downloaded the files directly from N54 tuning and received a 0x05 bad file code. Then tried to write my stock ecu back but again the same code.
    Plugged in charger with 40 amp automatic charger. Volts read 14 constantly.
    BT Cable Intel and AMD used.
    Followed the directions.
    Im thinking i will now need winkfp and a kdan cable to resort back? Any way i could do this without getting a kdan cable and only using the bt cable? Please help. I cant be stranded with no car for long. Thank you guys!
    Moved to the N54 section.
    Netherlands
    103 Post(s)
    Contact @WedgePerformance or @Cn555ic for help if you need it.
    You'll need the DCAN cable for WINKFP.
    http://www.germanboost.com/showthrea...510#post562510
    Gave you enough rep to do this.
    Feb 2013
    Germany
    69 Post(s)
    Zip and PM me your ECU read bin file so I can check it - 7 hours doesn't sound quite right.
    Dec 2012
    Florida
    125 Post(s)
    If it took 7 hours you shouldn't have continued, it should only take around 90 minutes. I'm guessing you have a 2007 and used a bad computer. My advice is go find another amd computer (some are finicky) or friend with a very new Intel with the haswell core. You'll likely be able to fix it np.
    Jan 2013
    Mexico
    13 Post(s)
    Intel Atom's will work with 2007 Kline as well
