Results 1 to 4 of 4
    28 Post(s)
    Post-Bimmerfest Gintani E43 M3 S54 Supercharger Special
    Post-Bimmerfest Gintani Supercharger Special on ALL Models (E46 M3, E6X M5/M6, & E9X M3)
    After Bimmerfest 2014, we noticed a large interest and positive response from enthusiasts in our products. We feel this is the perfect time and opportunity to give back to the community by providing special pricing to those who are thinking about cranking up the power in their beautiful ride!
    Gintani has always thrived on churning out the best products by utilizing top-of-the-line hardware, largest cooler cores, building the largest displacement intake manifolds, TIG welding everything, and constant track testing of our kits.
    E46 M3 Stage 1 & 2
    Stage 1: 8 psi (Approximately 525 HP/340 TQ)
    Stage 2: 10 psi (Approximately 575 HP/360 TQ)
    Kit Includes:
    •Vortech V3 Si Trim supercharger
    •Black Hard Anodized CnC Supercharger Bracket
    •Blow off valve
    •Air to liquid integrated intake manifold (Available in custom colors)
    •Bosch water pump
    •Water lines XRP AN fittings and Reservoir Tank
    •Front mount heat exchanger
    •Six High Flow Fuel Injectors
    •Spark Plugs
    •Eight Rib CnC machined crank pulley (Hard anodized)
    •Eight Rib idler pulley/Rib tensioner pulley
    •Air Filter
    •One silicone coupler
    •Custom ECU Remapping
    •Clamps all other miscellaneous parts
    Retail price: $10000
    Special price: $8500
    *Methanol Injection System available at $500 or $1000 (depending on which meth kit you are interested in).
    Apr 2014
    Click here to enlarge Originally Posted by [email protected] Click here to enlarge
    http://www.benzboost.com/images/impo...767d8d_n-1.jpg
    E46 M3 Stage 1 & 2
    Kit Includes:
    •Blow off valve
    •Bosch water pump
    •Spark Plugs
    •Air Filter
    http://www.benzboost.com/images/impo...2b191a_c-1.jpg
    Have you guys ever worked on a turbo kit for the s54? Or is there one in the makings?
    Encino,CA
    311 Post(s)
    Click here to enlarge Originally Posted by B00stGeek Click here to enlarge
    They have made a one off custom kit before. I'm not sure if they're willing to do another one.
    Click here to enlarge Originally Posted by fastgti69 Click here to enlarge
    It's a bitch. If you want a turbo probably better to go with one of the kits out there.
