Results 1 to 18 of 18
Thread: analog boost signal location?
04-22-2014, 07:24 PM #1Member
- Jan 2013
- 5.1
anybody know where i could tap into the manifold pressure on a x5m?
im having a tough time finding a good port/vacuum line to t into for a electric boost gauge
04-23-2014, 12:10 AM #2
I would think any decent mechanic should be able to help with this.
So let's get somebody better than that @alex@ABRhoustonBRAND NEW IN BOX 991.2 standard/non-pse SPW cat bypass pipe for sale - $899 shipped
04-23-2014, 12:15 AM #3Member
- Jan 2013
- 5.1
you would be surprised..
im pretty decent, changed the smg clutch on both my e46 m3 and e60 m5... installed the as super charger on that m3 as well...
but i cant find a decent vacuuum line on this motor since its "backwards" the vacuum lines for the brake booster etc seem to be run from a vacuum generator pump, it almost seems as if i would have to drill/tap the intake manifold , or fab a spacer for the stock map sensor (or tap into its electronics)
04-23-2014, 12:26 AM #4
I don't doubt you. You may want to try @Terry@BMS as well.
04-20-2016, 01:38 PM #5Member
- May 2012
- 239
- 194.2
- 11 Post(s)
Bump for wanting the same info. Pre and post tune my OBDII/tablet setup still only read 17.4 PSI when I should be pushing 21 PSI.
04-21-2016, 02:22 AM #6
04-21-2016, 02:33 AM #7Member
- May 2012
- 239
- 194.2
- 11 Post(s)
That's what I'm trying to figure out. I randomly get a reduced power warning so I've got all new PCV lines coming to make sure I don't have boost leaks, but my tablet reads 17.4 max like clockwork, so either I've got a very accurate boost leak, the sensor feeding the OBDII is wrong or maybe some parameter within Torque is wrong. I figured my best course of action now is to connect a manual boost gauge and hope for the best.
04-21-2016, 02:42 AM #8
04-21-2016, 03:27 AM #9Member
- May 2012
- 239
- 194.2
- 11 Post(s)
Tuner has understandably thrown his hands up until I resolve the reduced power warning, otherwise he claims I should be pushing 21 +/- like clockwork...M5 guys are touching on 30 PSI/1000HP (with meth, heavy tuning, intake & exhaust) but they're using piggyback tools like JB4 and a wastegate actuator that only work on F series vehicles at the moment. For now I need to resolve my reduced power, push a stage 3 tune spraying meth and of Pure turbos and hopefully by then BMS will give the E__ bodies and non TU engines some love so I can start pushing beyond 21 PSI.
04-21-2016, 04:52 AM #10
04-22-2016, 03:59 AM #11Member
- May 2012
- 239
- 194.2
- 11 Post(s)
Lfundgren or something like that on the boards, the website is www.morepower.dk, send me an OBDII dongle, cord, software and then a modified file I flashed myself.
04-22-2016, 05:06 PM #12Member
- Aug 2015
- 613
- 1,442.9
- 14 Post(s)
- 15
I know the torque app reads boost wrong on N55s. Might be fine, it is just reading wrong. Can't help with the manual boost reading.
04-22-2016, 07:35 PM #13
Ah, @lfelunden. He should be helping you fix this.
04-22-2016, 09:25 PM #14Member
- May 2012
- 239
- 194.2
- 11 Post(s)
Him and I talk over WhatsApp...maybe thrown his arms up was a bad choice of words. I've gotta replace the remaining PCV lines to eliminate them as a possible vacuum/boost leak since smoke testing netted me zero results, then if I no longer get the reduced power warning, that'll be a big issue resolved.
I still need to find a location for where to drill & tap for an analog boost line. I've written P3 Cars about their vent gauge since it supposedly reads accurately, they include a way to convert analog to digital, they replied to my messages right up to the point where asked for a copy of their PDF since they've listed PDF's and/or videos for just about every other car they sell their gauges for.
05-22-2016, 02:18 AM #15
05-23-2016, 09:16 PM #16Member
- May 2012
- 239
- 194.2
- 11 Post(s)
No, I'm still doing a few more things before heading out to Bimmerfest on Wednesday before leaving from Seattle. I've replaced one of the PCV lines, I've got one of the drivers side I need to swap and I'm going to try and replace all the vacuum lines as well. I bought a custom intake tubing and filter kit, then plan on ultimately deleting all the PCV stuff for a catch can system. I'm at work now, but I'll post pics soon
05-31-2017, 04:36 PM #17Member
- Apr 2015
- 6.2
06-01-2017, 06:58 AM #18
