Results 1 to 13 of 13
    Jun 2012
    North East
    20 Post(s)
    Resetting Adaptations to correct fuel trims
    Hey Guys,
    I'm having a hard time with INPA Loader to reset adaptations on my 335i.
    A bunch of the screens are in german so if you guys can tell me which keys you hit to get this done that would be a big help.
    I was able to read and delete codes but I did not see where I can erase ALL adaptations.
    Thanks!
    For Sale:
    - NX Express complete wet kit with Plug & Play fuel adapter for BMW 335i
    - FBO parts here LINK
    Jan 2012
    Hi. Grab one of the English translated versions? Search for vasillalov.
    DIY: N54 Injector Coding Via INPA - BimmerBoost
    http://www.bimmerboost.com/showthrea...oding-Via-INPA
    I admit I haven't tried the reset but I have seen them. You can input the upgraded .IPO files and so on once the above gives you the basic menu structure
    Chris
    Jun 2012
    North East
    20 Post(s)
    Thx Chris, I actually started out with vasillalov software then updated the daten files.
    I can code no problem.. Just can't find the adapataions menu to reset all
    For Sale:
    Jun 2012
    North East
    20 Post(s)
    I read somewhere that this worked for another guy:
    After you have selected your engine, its under ERROR MEMORY (F4) and then ERASING ADAPTATION (F7)...
    Not for my car though Click here to enlarge
    For Sale:
    Jan 2012
    Here.... Shift F8 to get E90
    Pick engine, msd80
    Then f8 "delete adaptions value selective"
    F1 take you into the various adaptions you can delete for idle, knock, throttle, etc.
    F2 instead has cylinder sync, rough running, lamda, bank 1 and 2, and injectors.
    That second page on f2 has F6 = all adaptions in bold
    Chris
    Jan 2012
    The F4 link mentioned is error memory and fasta on my version.
    Jan 2012
    P.s. while I am there. Instead of going into F8 delete adaptions. If instead you go to F5 status analog/digital you can read the current adaption levels , obd readiness, and so on.
    I have a question. Does anyone know what on earth is the "Neural Network". Has Neo from matrix hacked my car?
    Jun 2012
    North East
    20 Post(s)
    I don't have a 2nd page to delete all Click here to enlarge
    For Sale:
    Jan 2012
    Click here to enlarge Originally Posted by boosted-M Click here to enlarge
    Is that on page F1 then?
    Jun 2012
    North East
    20 Post(s)
    Click here to enlarge Originally Posted by crypticc Click here to enlarge
    unfortunately no
    For Sale:
    May 2012
    Jacksonville, FL
    95 Post(s)
    Try resetting lambda control from that screen, F7
    2015 F10 M5 \ Alpinweiss
    Jun 2012
    North East
    20 Post(s)
    I reset all the adaptations on that page..
    Any other steps that I should have done after the reset???
    Car started but ran VERY rough. None of the STFT or LTFT were working and the O2's were stuck at 14.7.. Even in boost..
    SO I pulled over, check codes (0 codes) then restarted the car and no change.... I then reflashed my map and car started and O2's were working and fuel trims back in action.
    For Sale:
    Nov 2011
    17 Post(s)
    Same thing happened when I reset all adaptions. I started the car and it felt like it was revving itself. I then reflashed my Cobb map and I was good to go.
    PTF Tuned Cobb Stage 2+ | H&R / Koni Sport | BBS LM
