Page 5 of 5 FirstFirst ... 345
Results 101 to 116 of 116
  1. #101
    May 2013
    58 Post(s)
    I'm very interested to see numbers as well and see how it compares to current n54 stage 2 cars
    2013 Audi S6 stock but shopping....
    2014 RAM 2500 6.7 Cummins. Far from stock
  2. #102
    Oct 2012
    Did you get it mocked up?
  3. #103
    Aug 2012
    Hayward, CA
    349 Post(s)
    Click here to enlarge Originally Posted by curare Click here to enlarge
    I created a new thread for progress, I will be posting it there. Asking for updates is not necessary, they will be posted as we make progress.
  4. #104
    Sep 2013
    Link/title for the thread?
    2011 535xDrive MSport
    BMS METH 2.3, AA CP, COBB N55 IC, BMS SCI
    RSI CTLS DP, MEISTERSCHAFT GTS EXT,
    JB4 STG 2, Cam2 100, Michelin PSS
  5. #105
    Click here to enlarge Originally Posted by DinoNac Click here to enlarge
    Just look in the N55 forum...
  6. #106
    May 2013
    Click here to enlarge Originally Posted by VargasTurboTech Click here to enlarge
    When you tried running what? So far the DME is fine with the fuel system on their. Sometimes I get the fuel pump idrive warning on start up. But I get that with just an intank walbro at times
    Really? On an N55? I had the continuous Fuel-pump error with the E85 walbro fuel pump sadly. IS there a fix in order? Perhaps a relay or something to trick the fuel pump ecu that the voltage has not changed?
    2011 BMW 335i xDrive, 12.3 @ 110 (N55 XDrive Record)
    Stage 2, Map 7/e85 mix, JB Intake, Vishnu Catted DP, ETS FMIC, CPe Chargepipe
    1994 Toyota Supra, Baltic Blue, 6-speed, mods...
    1200rwhp/875rwtq, 3.4L Stroker
    Mar 2013
    Israel
    3 Post(s)
    Still waiting on some driving videos Click here to enlarge
  8. #108
    Aug 2012
    Hayward, CA
    349 Post(s)
    Click here to enlarge Originally Posted by Tamut Click here to enlarge
    Looks like Terry might have to post those. They are sending the truck for the car tomorrow.
  9. #109
    Feb 2013
    Yep. Car has a VANOS failure like many N55s have. Let's hope they get it resolved fast
  10. #110
    Encino,CA
    311 Post(s)
    @VargasTurboTech
    Did you change anything on the exhaust turbine side? Wheel or housing? Or did you only swap the compressor wheel.
  11. #111
    Aug 2012
    Hayward, CA
    349 Post(s)
    Click here to enlarge Originally Posted by fastgti69 Click here to enlarge
    @VargasTurboTech
    ? Where have you been dude? Haha, its a Garrett GTX3076 CHRA in the stock housings, machined to take the bigger CHRA.
  12. #112
    Encino,CA
    311 Post(s)
    I wasn't sure lol. I was reading it all over again to double check. I only came up with CHRA and compressor turbine. I didnt think the exhaust turbine would fit in that.
  13. #113
    Aug 2012
    Hayward, CA
    349 Post(s)
    Oh yeah these things hav nice beefy turbine housings. They take the GT30 wheel with room to spare...Click here to enlarge
  14. #114
    Encino,CA
    311 Post(s)
    Did you check back pressure?
  15. #115
    Aug 2012
    Hayward, CA
    349 Post(s)
    these things have no issue with back pressure, learning from the N54 with the teeny tiny housings and big TD04 parts you don't even cross 2:1 til way way up in the rev range at high boost. You can run all the boost you want down low and it stays in a good range. All he would have to do is target a lot of boost down low and if it won't make it something is either bleeding it of holding the flapper open, that's it. Again there is no magic, it is possible BMW has gotten really tricky and has figured out a vanos to use the vanos and valvetronic to bleed the boost if it doesn't like what's it's seeing, but again this would be a tuning issue, not a turbo issue.
  16. #116
    Encino,CA
    311 Post(s)
    these things have no issue with back pressure, learning from the N54 with the teeny tiny housings and big TD04 parts you don't even cross 2:1 til way way up in the rev range at high boost. You can run all the boost you want down low and no stays in a good range. All he would have to do is target a lot of boost down low and if it won't make it something is either bleeding it of holding the flapper open, that's it. Again there is magic, it is possible BMW has gotten really tricky and has figured out a vanos to use the vanos and valvetronic to bleed the boost if it doesn't like what's it's seeing, but again this would be a tuning issue, not a turbo issue.
    Guess we just have to wait and see what happens.
