Results 1 to 7 of 7
    Jun 2012
    20 Post(s)
    Exclamation ***VIDEO***Mercedes SLS AMG vs Turbo 427 LSX Chevrolet Camaro
    AWD75 proudly presents another Exotic VS Domestic battle, which is made up of 2011 Mercedes Benz SLS AMG and 4th GEN Z28 Camaro. Last time these cars did couple of pulls camaro wasnt completely ready so it wasnt performing as it should but, now, it is fully finished and ready for some action.
    -SLS had 1 passenger and 1 driver, camaro had only driver.
    -Due to high DA (3077ft) all NA car(s) in the video(SLS) lost 10% of its power while FI car(s) lost only 1%.
    Detailed Mod List of Cars:
    SLS AMG:-Bone Stock-510hp(@3077ft)-3600lbs(1620kg)
    Z28 Camaro:-7.0l LSX Block-Callies billet main caps-Lunati stroker kit-Diamond pistons-Cometic head gaskets- EZ-94X billet heat shielded turbo-Turbosmart 60mm waste gate & blow off valve-AFR 225 heads-ARP studs-Manley valves-Compcams valve springs-Compcams lifter set-Manley timing chain kit-Compcams cam-Melling blueprinted LS6 oil pump-2 adet B&M Oil cooler-ATP harmonic balancer-LS6 intake manifold-İskender manifold-exhaust-Built D&D T56 transmission-Strange S60 Dana rear end-UMI (lower control arms with relocation brackets, adjustable torque arm with relocation brackets, driveshaft loop, adjustable panhard bar)-Diamond subframe connectors-Spoohn solid engine mounts-Griffin intercooler-Koyo radiator-1800+HP custom fuel system (aluminum race tank, weldon pump, nasty performance fuel rails, magna fuel stainless lines) -AEM injector driver-LG Motorsports coil over kit-powerslot rotors, hawk brake pads-AEM wideband-AEM Tru-boost
    Much more videos are on the way including IMPORTS, DOMESTICS & EXOTICS.
    Please dont forget to COMMENT, SHARE & SUBSCRIBE for more!!!
    Disclaimer: All of this footage is computer generated and enhanced with visual effects... Please do not attempt to try what you see in this video...
    May 2013
    58 Post(s)
    Actually surprised the SLS was so close, I guess driver error made a big difference, but that only seemed to be the case in one pull.
    2013 Audi S6 stock but shopping....
    2014 RAM 2500 6.7 Cummins. Far from stock
    Bone stock Mercedes SLS AMG versus a 900+ horsepower built motor twin turbo 427 LSX fourth gen Camaro
    On paper, this is a huge mismatch. In one corner you have the SLS AMG which is a very fast car and has been proving itself against stout competition. It's 563 horsepower M159 V8 and dual clutch transmission transmission are no slouch even in stock form but here it is going up against a twin turbo built motor 427 cubic inch LSX V8 stuffed into a fourth generation Camaro. There is what you call fast and then there is really fast.
    The Camaro features a 94mm single turbo (BIG) at only 13 psi so it could be cranked up way further than this. It is estimated that 13 psi is good for the ~900 horsepower range. It also has a built T56 manual transmission to handle the torque. So, yep, it's a beast.
    To no surprise, the SLS gets walked and walked quickly. The race it at elevation with DA estimated at 3000 feet. So, the naturally aspirated SLS is at a further disadvantage versus the turbocharged Camaro. One thing the SLS shows thow is at lower speeds once it is time to shift the dual clutch transmission does a nice job of mitigating the power advantage. Once at higher speeds though and spending more time in gear with less frequent shifts, it's quickly over and the power disparity shows.
    Sure, this may be a pointless race to some. It does however show the difference between a fast factory car and just how fast an aftermarket built car can be these days. It would be interesting to see the Camaro at full strength, whatever horsepower level that may be.
    Thank you to @AWD75 for the video.
    SLS AMG:
    -Bone Stock
    -510hp(@3077ft)
    -3600lbs(1620kg)
    Z28 Camaro:
    -7.0l LSX Block
    -Lunati stroker kit
    -Diamond pistons
    -AFR 225 heads
    -ARP studs
    -Manley valves
    -Compcams cam
    -Koyo radiator
    -AEM wideband
    -AEM Tru-boost
    Mar 2013
    Ugly car who cares how much HP! haha
    Click here to enlarge Originally Posted by Gondon Click here to enlarge
    Beauty is in the eye of the beholder. It's obviously built for performance. What are you going to get that will hold power better than an LSX?
    Jun 2012
    20 Post(s)
    For sure every person has their own taste, but for me, that camaro is not my cup of tea. Anyway, i still think that sls did pretty good against the disadvantages. I dont think that maro has 900hp tho...
    Click here to enlarge Originally Posted by AWD75 Click here to enlarge
    The SLS definitely did well.
    There is no reason that Camaro can't have way more power. 13 psi with a 90mm turbo on an LSX block? Heh.
