Results 51 to 62 of 62
07-28-2013, 11:25 PM #51BRAND NEW IN BOX 991.2 standard/non-pse SPW cat bypass pipe for sale - $899 shipped
07-28-2013, 11:29 PM #522018 Mercedes-Benz E63 S AMG (W213)
07-28-2013, 11:43 PM #53BRAND NEW IN BOX 991.2 standard/non-pse SPW cat bypass pipe for sale - $899 shipped
07-29-2013, 08:24 AM #54
- NJ
- 13,412
- 58.0
- 318 Post(s)
there is no way he is trapping over 130 mph in the 1/4.... think about the situation before you try and debate this one...cant wait to see the masterminds argue about this one
07-29-2013, 02:06 PM #55
613 wheel horsepower at elevation can't trap 130 but less than 613 wheel horsepower can trap 130?
07-29-2013, 07:43 PM #56
- NJ
- 13,412
- 58.0
- 318 Post(s)
Edit, read the rules: http://www.germanboost.com/showthrea...1516#post51516
what was uncorrected again, barely 500 right? the car i would assume is doing 122-125mph up there. at a true 613 hp, 130+ mph is easy.. at sea level, or near it.. 458 is probably barely 120 up there
07-29-2013, 08:56 PM #57
Guy is making 613 wheel horsepower SAE correct at his elevation and barometric pressure not at sea level. Why he would trap less than cars making less power running 130 at sea level when he's making even more power at elevation?
At sea level, he would trap even more as his wheel horsepower at 9 psi would much higher than 613 whp considering that 600 whp can be hit at lower boost. So 9 psi on a stock internal M3 is going to make for a very strong car.BRAND NEW IN BOX 991.2 standard/non-pse SPW cat bypass pipe for sale - $899 shipped
07-29-2013, 11:30 PM #58
- Sep 2012
- 1,162
- 980.2
- 14 Post(s)
- 10
I think what lost is trying to say is he's not really putting down 613 to the wheels at his elevation. That number is corrected in SAE so its standardized to equalize reading and show what he should be putting down @
Air Density: 1.157kg/m3
Relative Air Density: 94.4%
Density Altitude: 1952feet
Virtual Temperature: 77F
Vapor Pressure: 0 inches Hg
His uncorrected number would look a lot different where he's at.
07-29-2013, 11:31 PM #59
- Sep 2012
- 1,162
- 980.2
- 14 Post(s)
- 10
07-29-2013, 11:34 PM #60BRAND NEW IN BOX 991.2 standard/non-pse SPW cat bypass pipe for sale - $899 shipped
07-29-2013, 11:40 PM #61
I haven't seen any uncorrected numbers from his car but the SAE corrected number all show much lower even though one would think SAE correction should read the same no matter what but it isn't here...
07-29-2013, 11:44 PM #62
Keep in mind temperature and barometric pressure have an effect as well. It's difficult to completely standardize as the numbers show.
