Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
    Very cool. Not sure I saw it but a mention of the flash option for BMS and Vishnu for additional fueling for larger turbos, and/or methanol. Vishnu is ship you ECU, BMS is flash at home but with need for Cobb Accessport.
    Rob Beck Turbos, PROcede Rev. 3, Procede Fueling Flash (via OpenFlash Tablet), PPS Methanol System (DO12/Aquamist Flow Sensor), DCI, Quaife LSD, BMW Performance Suspension, Autobahn Exotics Exhaust, Helix FMIC, AR Design Downpipes, BSH Catch Can, Forge Diverter Valves, P3cars Vent Boost Gauge, Alufelgen CSL Reps, Lux 5.1 H8 Angel Eyes, HPB HID Fogs, LTBMW M3 Side Skirts, BMW M3 Rear Spoiler, BMW Front Aero Lip, BMW Pedal Kit, BMW M Shift Knob, Autotecknic Matte Black Grilles.
  2. #27
    Sep 2011
    27 Post(s)
    Click here to enlarge Originally Posted by AltecBX Click here to enlarge
    Sticky. Trying to update the chart!
    Why does the chart show a check for "Custom Adjustsble Mapping" for the JB4? Unlike the COBB or Procede which are fully tunable, AFAIK, the JB4 is not (otherwise, I would have switched yesterday).
    IMO, they are all great but the key differences are:
    • The extra features (2-step, gauges, etc.) of the piggy backs (JB, Procede)
    • The expanded logging and ease of installation (zero install) of the Cobb
    • The fully tunable feature of the Procede and Cobb
    • The advanced auto-tuning of the JB4 (and to some extent, the same in the older Procede maps) is nice as well, albeit not as distinguishing as the prior points.
    Those are the key differences that should be called-out IMO.
    '10 335i - 830whp (Bruce Lee)
  3. #28
    NYC
    3 Post(s)
    Click here to enlarge Originally Posted by scottp999 Click here to enlarge
    I've yet to do testing on the stack up tunes from each party. As soon as I do, I will update the chart accordantly.
    Click here to enlarge Originally Posted by The Ghost Click here to enlarge
    You can adjust the JB4 mapping by adjusting Boost, etc in the "User Adjustment" tab in the software. Under "Engine Tuning software", you can see that the COBB can be custom tuned with the ATR.
    Most of these points are in detail in the bottom where each tunes has features they provide.
  4. #29
    Sep 2011
    27 Post(s)
    No, I am agreeing that Cobb is fully tunable as is the Procede (2D OL fuel, ignition, AFR target plus 1D boost). AFAIK, JB4 does not have that (1D adjustments are not what I'm talking about) which is the significant different (and it's main relatice shortcoming to its peers).
  5. #30
    UPDATED!
    So here it is guys and girls... This is an updated 2013 comparison chart to compare the popular tunes out for the n54 engine. For those of you that are ready to buy a tune for your vehicle (BMW 135, 335, 335is 535, X635i, Z435i), this comparison chart will help you narrow down to the tune of your choice. The chart is in .PDF format so you can go to links associated with the text. This chart goes in detail and defines all the properties of these tunes. On the second page, you will find a breakdown on the features that the JB4 and PROcede v5 have. Both camps have contributed to this chart as well as reviewed it for accuracy.
    I'll be collecting new data as time goes by and tuners come up with more features and improvements to implement to their respective tunes. The chart will be updated accordingly. That said the features listed in the chart are what is currently available in the market.
    Disclaimer:
    Anything aftermarket can void your warranty. Read your new vehicle warranty carefully before deciding to start upgrading your vehicle.
    You are protected under the Magnusson Moss Warranty act which states that a dealer must prove that a specific modification is causing an issue before refusing warranty service. This means that they cannot outright void the warranty because you have an aftermarket mod but must prove that for instance a blow off valve is causing engine problems.
    Attachment 27509
    Attachment 27510
    Attachment 27511
    Attachment 27512
    Attachment 27513
    Attachment 27514
    Attachment 27515
    Attachment 27516
    Attachment 27518
    That is some serious work... let me update the OP.
  6. #31
    OP updated
