Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
    Jun 2012
    14 Post(s)
    Click here to enlarge Originally Posted by rwalker Click here to enlarge
    For those suggesting valve cover gasket: can you explain how oil from above the spark plug hole (where the gasket in lives) finds its way into the combustion chamber (where the tip of the plug lives)?
    It looks like both to me. If I had to guess.
  2. #27
    May 2011
    NYC
    8 Post(s)
    Ordering new injector today, not sure how good the spare one I have is.
    Also looking into getting a new battery, been getting slow cranks lately too.
    M3.
    Mazda3 that is Click here to enlarge
  3. #28
    May 2010
    South Jersey
    39 Post(s)
    Yes, this is why that theory doesn't make sense to me. For that to happen, the sparkplug would have to not be properly sealed against the head... which means you would also be leaking compression. The only way a gasket could cause this, is if the oil is pooling in the bottom of the spark plug well, which gets transferred to the plug while it's being unscrewed. Is that the theory?
  4. #29
    May 2011
    NYC
    8 Post(s)
    By the way - should I put anti-seize on plug's threads?
    Also what goes between the plug and coil? Mine looked like they had something there, a white powdery substance was in every coil.
    M3.
  5. #30
    May 2012
    Jacksonville, FL
    95 Post(s)
    Click here to enlarge Originally Posted by onebadmofo Click here to enlarge
    Do not use anything on the threads, but the white powder is most likely die electric grease, which you should use when installing new plugs or coils.
    2015 F10 M5 \ Alpinweiss
    Oct 2011
    NY
    49 Post(s)
    Click here to enlarge Originally Posted by Eleventeen Click here to enlarge
    that is also my reasoning behind always discrediting the valve cover theory, as well as no oil above the threads of the plug... just does not seem logical to me that it could be the valve cover, but i have been wrong plenty of times before...
    and my plug looked just like his and it was a leaky injector...
    09 6AT 335i Coupe M-Sport - SOLD
    Current - 16 Jeep Wrangler - Few Mods
    Looking for a n54 project e90/e82
  7. #32
    May 2010
    South Jersey
    39 Post(s)
    Click here to enlarge Originally Posted by ChuckD05 Click here to enlarge
    The injector seems like a good theory. My car is a 09/06 build, which I bought w/ 35,000 miles and I'm not sure if any injectors were replaced by the previous owner. I now have ~80k so it's probably time I pony up for some new injectors myself, for preventive reasons if nothing else.
  8. #33
    May 2011
    NYC
    8 Post(s)
    Swapped out #6 injector, car runs better, starts like stock and after 300 miles or so there's not a drop of oil on the new spark
    Thanks to everyone that said to swap out the injector!
    M3.
  9. #34
    May 2010
    Thanks for following up, so few people do.
