Results 1 to 25 of 34
11-24-2012, 11:35 PM #1Member
- May 2011
- NYC
- 75
- 189.5
Another black/oily #6 plug. Anyone figured out why it happens?
Leaking valve cover gasket? Why would the plug be black though?
Changed my sparks today, those had around 15k on them.
Car ran fine, I'm not losing any oil. In fact I'll be due for 7k oil change soon and I still have 1/4 of original oil left in the iDrive thingie Changed sparks only because I had plugs sitting in closet for months and was bored.
M3.
Mazda3 that is
11-24-2012, 11:44 PM #2Member
- 4.6
Based on some other stuff I've seen that looks like what they call blow by. I'm not an engine builder or machinist though. Little extra oil getting burnt up in the chamber. May not be enough to matter. Is this the first set that has looked like that?
11-25-2012, 12:01 AM #3Member
- Jun 2012
- 1,177
- 801.6
- 14 Post(s)
- 9
Probably valve cover gasket... I can't imagine what else it would be. Although the discoloration on #6 insulator could maybe be fuel.
11-25-2012, 12:27 AM #4
11-25-2012, 12:58 PM #5
I'd be interested to see a collection of misfires from various cars to see if cylinder 6 was the most common. Maybe correlate that data with carbon build up on each intake valve, injector failures for each cylinder, etc.
Without any of that data, my guess would be that maybe cylinder 6 runs rich (possibly due to intake manifold design)? Or maybe it runs much cooler?
From what I remember, I'm pretty sure my #6 plug always looks like that too.
11-25-2012, 03:08 PM #6
When I changed my spark plugs, about 4k miles ago, I noticed that spark plug 3 or 4 had a little oil on the top of it, and there was also oil on one of the holes on top, but not much. Haven't giving it much thought since my car seems to be burning oil normally and runs fine. Might have a leaky gasket, but so far no problems, or running low on oil
John 3:16
11-25-2012, 04:06 PM #7
11-25-2012, 04:13 PM #8Member
- Strong Island
- 3,432
- 3,063.0
- 101 Post(s)
- 31
You will not get oil from the cylinder that far up the plug. You have a leaky valve cover gasket grommet or two...
11-25-2012, 11:45 PM #9Member
- Jun 2012
- 1,177
- 801.6
- 14 Post(s)
- 9
11-26-2012, 12:01 AM #10
11-26-2012, 01:30 AM #11Member
- Strong Island
- 3,432
- 3,063.0
- 101 Post(s)
- 31
11-26-2012, 02:32 AM #12Member
- Jun 2012
- 1,177
- 801.6
- 14 Post(s)
- 9
11-26-2012, 12:24 PM #13Member
- May 2011
- NYC
- 75
- 189.5
I have a spare injector, gonna replace it and see what happens.
M3.
Mazda3 that is
11-26-2012, 02:09 PM #14
11-26-2012, 02:45 PM #15
myst always says valve cover gasket and i always say injector , lol
my 135 had cyl 6 look like that bmw changed my injector never came back09 6AT 335i Coupe M-Sport - SOLD
Current - 16 Jeep Wrangler - Few Mods
Looking for a n54 project e90/e82
11-26-2012, 04:19 PM #16Member
- Jul 2011
- Omaha, NE
- 103
- 172.8
- 19 Post(s)
11-26-2012, 04:23 PM #17Member
- Jun 2012
- 1,177
- 801.6
- 14 Post(s)
- 9
11-26-2012, 05:26 PM #18Member
- 4.6
So can the injector be tested by moving it to cylinder 3 or 4 for example and seeing what that looks like after a few thousand miles? If it were mine I'd try that before throwing a part at it. Seeing that you have a spare injector though I suppose you might as well swap it out.
You are using a met kit correct? Is this something common from that cylinder when using meth? Makes me wonder about theoretical stuff with atomization and intake flow when using meth. Maybe getting an unequal volume to that cylinder or something? Probably nothing that complex. Hope the injector takes care of it.
11-26-2012, 06:28 PM #19Member
- May 2011
- NYC
- 75
- 189.5
Meth is used, valve cleaning was done about 10k miles ago.
M3.
Mazda3 that is
11-26-2012, 06:29 PM #20Member
- May 2011
- NYC
- 75
- 189.5
I also should mention that I have trouble starting the car sometimes. It cranks but doesn't start. I would get out, lock the car, unlock it and it start right away. LPFP isn't holding the pressure? Both HPFP and LPFP were changed recently. Also could be the tune? I have the contraption that goes in the second hole on the fuel tank (fuel pressure regulator) sitting in the closet, gonna replace it one of those days.
Once the car is up and running I have no fuel issues whatsoever and it's pushing down 470rwhp easy.M3.
Mazda3 that is
11-26-2012, 08:56 PM #21Member
- 4.6
Sounds like a blast to drive. If it were mine I wouldn't be too worried about it, especially seeing how you're not burning much oil at all if any. Swap out the injector like you said and just check it at oil changes or every 5k miles.
11-26-2012, 09:12 PM #22Member
- Jul 2011
- Omaha, NE
- 103
- 172.8
- 19 Post(s)
11-26-2012, 09:20 PM #23Member
- Jun 2012
- 1,177
- 801.6
- 14 Post(s)
- 9
11-27-2012, 01:11 AM #24Member
- San Diego
- 78
- 61.8
For those suggesting valve cover gasket: can you explain how oil from above the spark plug hole (where the gasket in lives) finds its way into the combustion chamber (where the tip of the plug lives)?
11-27-2012, 01:35 AM #25Member
- Strong Island
- 3,432
- 3,063.0
- 101 Post(s)
- 31
