Results 51 to 60 of 60
08-10-2012, 01:11 AM #51
- Feb 2012
- 26
- 73.0
thanks for the response.
I have been runnign the jb4 happily for about a year, but recently started going to the track and every session i get misfires on multiple cylinders. I have swapped out all plugs/coils and still under pressure the misfires keep coming back, but only at the track not on the street. interestingly temps are a little over mid way so thats not the issue.
I was thinking the cobb may fix the misfires but i would still like to keep the jb4 for meth.
08-10-2012, 08:09 AM #52
- www.bootmod3.com
- 6,711
- 3,356.0
- 233 Post(s)
What codes do you get? You shouldn't have swapped the coils out just like that, waste of money. They either work or not and will consistently misfire if bad.
08-12-2012, 08:10 PM #53
- Feb 2012
- 26
- 73.0
I got all the misfire codes. the only ones i recall though were 29ce and 29cf for cylinders 2 and 3, but i got the special 'misfire on multiple cylinders' as well and that gave me a little laugh
As I said these were all on the track only, normal driving all is fine. I swapped the coils out and it got a lot better for a little while but now it is back
So I got to thinking it might be the jb4 and i'd give the corn cobb a go, but keep the jb4 stacked for meth.
08-12-2012, 08:42 PM #54
Supporting Vendor
If you have fueling problems, just use our Cobb backend map. Then the JB4 continues to operate as normal only without the fuel control burdens.
08-13-2012, 01:18 AM #55
- Feb 2012
- 26
- 73.0
09-20-2012, 05:16 PM #56
Supporting Vendor
This info is all obsolete now. Someone delete this thread. I'll make another on how to use the JB4 w/ our backend flash later.
09-20-2012, 05:18 PM #57
09-20-2012, 05:43 PM #58
- Boston
- 876
- 891.7
- 63 Post(s)
09-25-2012, 11:18 AM #59
- Boston
- 876
- 891.7
- 63 Post(s)
09-25-2012, 02:12 PM #60
world record dynos need to be acompanied with a TRAP SPEED !!!!! or a 60-130!!!! lmao...
but id love to see the graphs anyway
